[BK7231T] Setting Up TreatLife DS02F Ceiling Fan Controller - Non-ESP Flashing
rb2k 2946 19
How can I configure a TreatLife DS02F BK7231T ceiling fan controller flashed with Cloudcutter/OpenBeken so the fan power and speed controls work correctly?
Configure it as a TuyaMCU device in OpenBeken: collect the dpIDs from the debug log, then map dpID 1 as a boolean toggle for fan power and dpID 3 as an enum for fan speed [#20463990][#20464363][#20464532] Use an `autoexec.bat` with `startDriver TuyaMCU`, `tuyaMcu_setBaudRate 115200`, `setChannelType 1 toggle`, `setChannelType 3 OffLowMidHigh`, `linkTuyaMCUOutputToChannel 1 bool 1`, and `linkTuyaMCUOutputToChannel 3 enum 3` [#20464532] The captured log showed dpID 1 switching 0/1 for off/on, and dpID 3 switching 0, 1, 2, 3 for the speed steps [#20464363] If you want the toggle and speed selector to stay in sync, add change handlers so setting speed to 0 turns the toggle off and setting speed above 0 turns it on [#20464563][#20466185] For persistent state across reboots, one suggestion was to use another channel or a special flash channel as a memory slot, since `setChannel 200 123` stays stored after reboot [#20466188]
  • Cloudcutter template works for TreatLife DS02F BK7231T
    #1 20463901
    rb2k
    Grabbed one from here: https://www.amazon.com/gp/product/B08P5D3ZKW/
    Was flashable using tuya cloudcutter and this template: https://github.com/tuya-cloudcutter/tuya-clou...r/devices/treatlife-ds02f-fan-controller.json
    Apparently used to be an esp device (as seen over here: https://templates.blakadder.com/treatlife_DS02F.html)
    I'm new to non-ESP flashing and I'm still trying to figure out how to correctly set this up based on the existing templates or similar treatlife devices. Does anyone have any idea? Would this require a teardown? :)
  • TuyaMCU logging needed to map dpIDs
    #2 20463990
    Rate: 12906
    Hello, this fan controller is a TuyaMCU device. Most likely very similar to that one:
    [BK7231T] TreatLife 3 Way Smart Dimmer Switch (DS02S)
    You will need to know dpIDs of each function, so we can write a config.
    I'd suggest this approach - go to Launch Web Application, LittleFS tab, create autoexec.bat, enter this content:
    startDriver TuyaMCU
    save the file.
    Then, we will need log from reboot. Go to Log tab, then reboot device, clear the log, keep log tab open, set log level to "Debug", and once device reconnects and new log shows up, try pressing buttons on the device, etc, etc. Then copy paste full log here. The log will contain received TuyaMCU packets and we can look at their IDs and then write config to display them on screen.
    You might also want to see this:
    Tuya 5 Speed Fan Controller by TEQOOZ - Home Assistant
    QIACHIP Universal WIFI Ceiling Fan Light Remote Control Kit - BK7231N - CB2S
  • TuyaMCU dpIds for fan power and speed
    #3 20464363
    rb2k
    Not 100% sure if it accepted me setting things to 'debug', but these are the ones I could see:
    Button to turn fan off/on:
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: processing dpId 1, dataType 1-DP_TYPE_BOOL and 1 data bytes
    0 = off, 1 = on
    Button to set faster/slower fan speed:
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: processing dpId 3, dataType 4-DP_TYPE_ENUM and 1 data bytes
    Seems to be value 0 (slow) to 3 (fast)
    Other things I saw:
    Info:TuyaMCU:TuyaMCU_ProcessIncoming[ver=3]: processing command 0 (Hearbeat) with 8 bytes
    Info:TuyaMCU:TuyaMCU_ProcessIncoming[ver=3]: processing command 7 (State) with 12 bytes
    Here's the full logs:
    Info:TuyaMCU:TUYAMCU received: 55 AA 03 00 00 01 01 04
    Info:TuyaMCU:TUYAMCU received: 55 AA 03 07 00 08 69 02 00 04 00 00 00 0B 8B
    Info:TuyaMCU:TuyaMCU_ProcessIncoming[ver=3]: processing command 7 (State) with 15 bytes
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: processing dpId 105, dataType 2-DP_TYPE_VALUE and 4 data bytes
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: raw data 4 int: 11
    Debug:TuyaMCU:TuyaMCU_ApplyMapping: id 105 with value 11 is not mapped
    Info:TuyaMCU:TUYAMCU received: 55 AA 03 03 00 00 05
    Info:TuyaMCU:TuyaMCU_ProcessIncoming[ver=3]: processing command 3 (WiFiState) with 7 bytes
    Info:TuyaMCU:TUYAMCU received: 55 AA 03 07 00 05 01 01 00 01 01 12
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: raw data 1 byte:
    Debug:TuyaMCU:TuyaMCU_ApplyMapping: id 1 with value 1 is not mapped
    Info:TuyaMCU:TUYAMCU received: 55 AA 03 07 00 05 03 04 00 01 01 17
    Debug:TuyaMCU:TuyaMCU_ApplyMapping: id 3 with value 1 is not mapped
    Info:TuyaMCU:TUYAMCU received: 55 AA 03 07 00 05 03 04 00 01 02 18
    Debug:TuyaMCU:TuyaMCU_ApplyMapping: id 3 with value 2 is not mapped
    Info:TuyaMCU:TUYAMCU received: 55 AA 03 07 00 05 03 04 00 01 03 19
    Debug:TuyaMCU:TuyaMCU_ApplyMapping: id 3 with value 3 is not mapped
    Info:TuyaMCU:TUYAMCU received: 55 AA 03 07 00 05 03 04 00 01 00 16
    Debug:TuyaMCU:TuyaMCU_ApplyMapping: id 3 with value 0 is not mapped
    Info:TuyaMCU:TUYAMCU received: 55 AA 03 07 00 05 01 01 00 01 00 11
    Debug:TuyaMCU:TuyaMCU_ApplyMapping: id 1 with value 0 is not mapped
  • dpID mapping for fan power and speed channels
    #4 20464532
    Rate: 12906
    Very good! As you can clearly see, the dpID 1 is a boolean that controls the power on/off state of the fan, and the dpID 3 is an enumeration that seem to control speed of the fan. With that dpID information, you can update your autoexec.bat:
    startDriver TuyaMCU
    // fan on/off channel
    //fan speed channel
    // linkTuyaMCUOutputToChannel dpId varType channelID
    // link output 1 to channel 1
    // link output 3 to channel 3
    Please try it out, if there is a problem, I'll help you fix it.
    The config above assumes that speed setting is using OffLowMidHigh enumeration, so it has following options:
    - off (0)
    - low (1)
    - mid (2)
    - high (3)
    If you need different enumeration, let me know.
    Please reboot your device after making autoexec changes.
  • #5 20464561
    rb2k
    That worked!
    One slightly weird behavior:
    If I set the speed to "off", the fan stops spinning, but the 'toggle' still shows it as "ON"
  • Autoexec rule to turn power off with speed 0
    #6 20464563
    Rate: 12906
    This seem to be by Tuya design, but if you want, we can hack it to behave better.
    Maybe something like that could help:
    addChangeHandler Channel3 == 0 setChannel 1 0
    It basically says: when channel 3 becomes 0, then set channel 1 to 0.
    And it basically means: when speed is set to off, then also set power to off.
    Put that in autoexec and reboot, and let's see if it works.s I hope that I haven't done any syntax errors.
  • Channel3 change handler toggles fan power
    #7 20464565
    rb2k
    That also worked!
    It does a bit of a weird 'double click', but that's fine with me :)
    I guess I could do the other way around as well: If I set the speed to low/medium/high, it should turn on the toggle
    I tried
    addChangeHandler Channel3 != 0 setChannel 1 1
    and it works o/
    The only odd thing left:
    If I just trigger the toggle, it will resume at whatever the previous speed was, but the speed selector doesn't update. Not sure if that can be handled or if it doesn't matter because I'll just surface the speed selector to homeassistant anyway
  • Clarifying speed retention after toggle or reboot
    #8 20465812
    Rate: 12906
    I am not sure if I understand. If you set speed to level 3, and then turn off and on the toggle, then the speed level should be remembered by OpenBeken itself, since it wasn't changed.
    Or am I making some kind of logical error here?
    One of the possible solutions would be to catch the toggle setting to 1 event (again change handler) and then default speed to lowest one...
    Or do you mean... after reboot?
  • ChangeHandlers sync fan toggle with speed state
    #9 20466185
    rb2k
    I think this might clarify it:
    / Make sure that speed set to off turns the toggle off too
    // Make sure that turning on as speed also triggers the toggle
    // Set speed to "off" when toggle is set to off
    addChangeHandler Channel1 == 0 setChannel 3 0
    // Set speed to lowest when turning on via toggle
    addChangeHandler Channel1 == 1 setChannel 3 1
    It bothered me that when I turned the fan 'off', it still showed a speed rather than the 'off' position.
    I guess that's just how tuya set this up. With the ChangeHandlers I set up, I lose the memory, but at least I can tell that it's off :)
    Using flash-retained channels as script memory
    #10 20466188
    Rate: 12906
    It should be possible to script it to have the memory, for example, you could just use another channel (let's say channel 10) as a memory slot.
    You could also use one of the special-flash channels which are kept after reboot, just in the same way, as a memory slot.
    Code: C / C++
    If you do setChannel 200 123 then value 123 will be still at $CH200 even after reboot.
  • Clarifying 4-speed fan enumeration and toggle behavior
    #11 20470082
    mattj
    Rate: 16
    - off (0)
    - low (1)
    - mid (2)
    - high (3)
    Hey there @p.kaczmarek2 - thanks for this. I have this same device, but I have a different understanding.
    This fan has 4 active speeds (5 if you include off). Think of it as OFF or ON-lowest, ON-low, ON-med, ON-high —> naming however you’d see fit. That said, I don’t seem to see any similar enumeration that would fit here.
    For example, Toggle 1 = “ON” Speed = “OFF” is actually the lowest speed. Toggle 1 is correctly overriding the speed setting to turn it on or off.
    Side note: My unit suddenly started showing a flashing red light on it - not sure why. The web UI still works, as do the physical controls.
  • #12 20470714
    rb2k
    Mine flashed red too, but then it stopped.
    Works fine still.
    Very odd, I could swear that for me, it’s just 4 speeds. The 5th one didn't move the blades. Might be a side effect of the fan I use though
  • #13 20470742
    Rate: 12906
    Maybe LED blinks when it thinks it's not paired?
    OBK tells MCU it's paired when you have both WiFi and MQTT on.
    You can override it with:
    tuyaMcu_defWiFiState 3
    Refer to Tuya docs to see what the 3 is. If you set it, then device will all the time think it's pairede and configured and that it has server connection.
    Is there anything else I may help you with?
  • Speed off maps to lowest fan speed
    #14 20471532
    mattj
    Rate: 16
    Is there another enumeration which might apply better here? More of an aesthetic thing vs. functional - in the web UI.
    Speed = "OFF" is actually Speed 1 or "Lowest".
    Also: sharing my YAML in case anyone needs it (and or has corrections - though it seems to work)
    fan:
      - unique_id: "ceiling_fan"
        state_topic: "fan/1/get"
        command_topic: "fan/1/set"
        percentage_state_topic: "fan/2/get"
        percentage_command_topic: "fan/2/set"
        speed_range_min: 1
        speed_range_max: 3
        qos: 1
        payload_on: 1
        payload_off: 0
        retain: true
        optimistic: true
  • Home Assistant config for four fan speeds
    #15 20471724
    rb2k
    Ok, I'm finally back home and I have confirmed: Speed 0 ("Off") does indeed still move the blades!
    It seemed like it wasn't but the slowdown does indeed stop at some point and still spins them ever so slightly!
    I guess the 'off' in the selection is a bit confusing
    Added after 24 [minutes]:
    Currently trying to beef up the homeassistant config. It's not perfect yet, but I can select all 4 speeds:
      fan:
        - name: "Kid's Room Ceiling Fan"
          unique_id: "obk089F14CA"
          icon: mdi:ceiling-fan
          availability:
            - topic: "obk089F14CA/connected"
          payload_on: 1
          payload_off: 0
          state_topic: "obk089F14CA/1/get"
          command_topic: "obk089F14CA/1/set"
          percentage_state_topic: "obk089F14CA/3/get"
          percentage_command_topic: "obk089F14CA/3/set"
          percentage_value_template: '{{ (value | int   1) * 25 }}'
          percentage_command_template: "{{ ((value | int - 1) / 25) | int }}"
          preset_modes:
            - "lowest"
            - "low"
            - "medium"
            - "high"
          preset_mode_command_topic: "obk089F14CA/3/set"
          preset_mode_command_template: '{{ value | replace("lowest", "0") | replace("low", "1") | replace("medium", "2") | replace("high", "3") }}'
          preset_mode_value_template: '{{ value | replace("0", "lowest") | replace("1", "low") | replace("2", "medium") | replace("3", "high") }}'
          qos: 1
          retain: true
  • #16 20471958
    Rate: 12906
    Very good question! I can add anything you want, but today I also added FULL documentation, take a look here:
    https://github.com/openshwprojects/OpenBK7231T_App/blob/main/docs/channelTypes.md
    Also see here:
    https://github.com/openshwprojects/OpenBK7231T_App/tree/main/docs
    Soon we will also have a docs page.
  • Proposed 4-speed fan controller enumeration
    #17 20472523
    mattj
    Rate: 16
    Thanks so much! Documentation is much appreciated, and has been one of the gaps, but now it'll be easier to reference in posts.
    On the enumeration, I think there is the potential to add a new one. Today we have essentially options for a 3-speed and 5-speed controller. But this is a 4-speed one.
    3-Speed:
    * LowMidHigh
    * OffLowMidHigh
    5-Speed:
    * LowestLowMidHighHighest
    * OffLowestLowMidHighHighest
    Proposed 4-Speed:
    * Low, Mid, High, Highest
    * Off, Low, Mid, High, Highest
    (Alternatively could be "Lowest, Low, Mid, High" or "Lowest, Low, High, Highest" - personally I have no preference.)
    Thanks for all the amazing work - the pace at which OpenBeken's been growing has been great.
  • #18 20472547
    Rate: 12906
    Thanks, I have added those channel types as you requested. I also updated docs, now there is a small readme:
    Docs are also automatically generated into JSON, so I can also feed them into some other system or dedicated website in the future
  • Missing OffLowMidHighHighest channel after OTA update
    #19 20474902
    azsoccerpop
    Hi @p.kaczmarek2 I upgraded to the latest firmware version 1.15.565 using OTA but I do not see the 2 new channel types. I have it defined in autoexec.bat as
    //fan speed channel
    setChannelType 3 OffLowMidHighHighest
    // map dpid3 to channel3, var type 4 (enum)
    linkTuyaMCUOutputToChannel 3 4 3
    And I have rebooted but still only see the original OffLowMidHigh which was originally configured. Thank you for any help and your work on this project. I was glad not to have to desolder and replace the Tuya chip with an ESP-12.
  • #20 20475035
    Rate: 12906
    Thank you for reporting the issue. The string names were indeed not refreshed in the build. Please get the next release, I have made sure that they are present now. The automatic github build should be ready within 10 minutes.
The discussion revolves around setting up the TreatLife DS02F Ceiling Fan Controller, which is identified as a TuyaMCU device. The user successfully flashed the device using Tuya Cloudcutter and a specific JSON template. They sought assistance with configuring the device for non-ESP flashing, particularly in identifying dpIDs for various functions. The community provided guidance on creating an autoexec.bat file to manage the device's settings, including power and speed controls. The user shared logs that revealed the dpIDs for fan control, leading to a configuration that allowed for toggling power and adjusting fan speed. Several change handlers were implemented to synchronize the toggle and speed settings, addressing issues with the device's behavior. The conversation also touched on the device's speed settings and the potential for adding new enumerations for better functionality. Documentation updates and firmware improvements were discussed to enhance user experience.
TL;DR: Set TuyaMCU to 115200 baud and map dpID 1/3; "dpID 1 is a boolean; dpID 3 is an enumeration." Configure OpenBeken autoexec for 4‑speed control and add change‑handlers for sync. [Elektroda, p.kaczmarek2, post #20464532]
Why it matters: This helps DIYers who flashed a non‑ESP DS02F get stable fan power/speed control and Home Assistant integration.
How do I configure OpenBeken TuyaMCU on the DS02F?
Use autoexec with TuyaMCU and map dpIDs.
  1. Add: startDriver TuyaMCU and tuyaMcu_setBaudRate 115200.
  2. Add: setChannelType 1 toggle and setChannelType 3 OffLowMidHigh.
  3. Link: linkTuyaMCUOutputToChannel 1 bool 1 and linkTuyaMCUOutputToChannel 3 enum 3, then reboot. [Elektroda, p.kaczmarek2, post #20464532]
Which dpIDs control power and speed on the DS02F?
dpID 1 is a boolean for fan on/off. dpID 3 is an enum for speed with values 0–3 as Off, Low, Mid, High. This maps cleanly to OpenBeken channel types and gives immediate UI control. “dpID 1 controls power; dpID 3 controls speed.” [Elektroda, p.kaczmarek2, post #20464532]
How do I discover dpIDs if my unit differs?
Enable TuyaMCU at 115200, open the log, set log level Debug, and press the device buttons. Reboot with the Log tab open to capture packets. The log shows dpIDs and types as messages arrive, so you can map them accurately. [Elektroda, p.kaczmarek2, post #20463990]
Speed set to Off stops the fan, but toggle shows ON. How do I sync them?
Add a change handler so Off speed also turns power off. Use: addChangeHandler Channel3 == 0 setChannel 1 0. This updates the power toggle whenever speed equals zero, keeping UI and state aligned. Reboot after editing autoexec. [Elektroda, p.kaczmarek2, post #20464563]
How do I ensure speed changes also turn the fan on?
Add a second change handler so any non‑zero speed turns power on. Use: addChangeHandler Channel3 != 0 setChannel 1 1. This keeps user actions on the speed selector consistent with the power toggle. [Elektroda, rb2k, post #20464565]
Can I make the toggle set Off or a default speed automatically?
Yes. Add two handlers: addChangeHandler Channel1 == 0 setChannel 3 0 and addChangeHandler Channel1 == 1 setChannel 3 1. This sets speed to Off when turning off, and to Low when turning on via the toggle. [Elektroda, rb2k, post #20466185]
How do I preserve or recall last speed reliably (even after reboot)?
Use special flash channels as persistent memory, for example CH200–CH264. Store your last speed in CH200 and restore it on power‑on via handlers. “If you do setChannel 200 123 then value 123 will be still at $CH200 even after reboot.” [Elektroda, p.kaczmarek2, post #20466188]
My unit’s LED flashes red. What does it mean and how can I stop it?
The MCU thinks it is not paired. OpenBeken reports paired when both Wi‑Fi and MQTT are active. To override, set tuyaMcu_defWiFiState 3 in autoexec so the MCU sees a permanent server connection. [Elektroda, p.kaczmarek2, post #20470742]
Does setting Speed 0 actually stop the fan?
One user confirmed Speed 0 can still move blades very slightly after slowdown. Treat “0” as Off in the UI, but the motor may still coast. This is an edge case to note during testing. [Elektroda, rb2k, post #20471724]
Which channel type fits the DS02F’s 4‑speed behavior?
Use LowMidHighHighest or OffLowMidHighHighest, depending on whether you want an explicit Off value in the enum. These were added specifically for 4‑speed fan controllers like DS02F. Update firmware to access them. [Elektroda, p.kaczmarek2, post #20472547]
I upgraded to 1.15.565 but don’t see the new channel types. What now?
Update to the next release. The string names for the new types were not refreshed in that build. After the corrected build publishes, the new enumerations will appear normally in the UI. [Elektroda, p.kaczmarek2, post #20475035]
How do I integrate DS02F with Home Assistant via MQTT?
Publish power on Channel 1 (state_topic/command_topic) and speed on Channel 3 (percentage or preset). You can map presets Lowest/Low/Medium/High and convert percentages 0–100 to enum 0–3. See working YAML using channels 1 and 3, QoS 1, retain true. [Elektroda, rb2k, post #20471724]
Is the DS02F a TuyaMCU device?
Yes. It communicates through a TuyaMCU co‑processor and exposes features as dpIDs over UART. Configure OpenBeken’s TuyaMCU driver and map dpIDs to channels for control. [Elektroda, p.kaczmarek2, post #20463990]
Can I flash DS02F OTA without opening the device?
Yes. Users successfully flashed it using Tuya Cloudcutter with the TreatLife DS02F template JSON. Earlier batches were ESP‑based, but the posted unit was flashed OTA as a non‑ESP device. [Elektroda, rb2k, post #20463901]
What do the TuyaMCU log messages “Heartbeat” and “State” mean?
Heartbeat (command 0) confirms link status. State (command 7) carries dpID updates like dpID 1 (bool) and dpID 3 (enum). Use the Debug log to observe values as you press buttons and change speeds. [Elektroda, rb2k, post #20464363]
Is DS02F similar to the TreatLife DS02S dimmer for TuyaMCU mapping?
Yes, the mapping approach is very similar. You still enable the TuyaMCU driver, set baud, and map dpIDs to channels. The technique transfers between these TuyaMCU devices cleanly. [Elektroda, p.kaczmarek2, post #20463990]
