ESP8266, Modbus RTU data reading, Preview in VIRTUINO - your experiences?
tomleszno 1830 2
  • #1 20463414
    tomleszno
    Help: 19
    Rate: 61
    Hello colleagues. Have any of you tried, using ESP, to read data from a device with Modbus RTU and preview everything on VIRTUINO?
  • #2 20469864
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    Of course he tried except for the last one. I have no idea what Virtuino is.
    I, for example, read data from a PV inverter using ESP32 with rs485-uart converter. Then in nodered I transfer to the influxdb database to then display it in Garafan.
  • Blynk used successfully with RS485-UART converter
    #3 20476437
    tomleszno
    Help: 19
    Rate: 61
    such an application for the phone:)
    https://virtuino.com/
    I previously used blynk https://blynk.io/ and everything worked for me, I read data from a GREE heat pump just like you I use an RS485-uart converter.
    A little has changed since I started this thread as I have managed to get the communication working and I am slowly getting myself up and running with the following application elements
