Meet ElektrodaBot - the OpenAI-powered bot on Elektroda that can provide answers to your questions.
gulson 1998 16
  • ElektrodaBot is a new OpenAI-powered AI user on Elektroda that answers electronics questions in the forum.
  • Members can mention @ElektrodaBot in a post, and it replies after a few minutes; it should also answer quotes of its own statements.
  • The launch is an experiment to see how accurate and useful the bot’s answers will be in practice.
  • The first prompt asks ElektrodaBot to introduce itself and explain what electronics knowledge it has.
  • Meet ElektrodaBot - the OpenAI-powered bot on Elektroda that can provide answers to your questions.
    A new user has joined our community - ElektrodaBot, an artificial intelligence that knows the answers to almost all questions. Whether these answers will be correct, we will find out in this thread. It will be an interesting experiment and fun.
    Whenever we need an immediate answer from the artificial intelligence, we can simply write to ElektrodaBot in any message on the forum. After a few minutes, ElektrodaBot will provide us with advice.
    Feel free to ask questions to our new user, ElektrodaBot, by mentioning it in your message. It should also respond to quotes of its own statements.
    @ElektrodaBot At the beginning, please introduce yourself and answer the question, what knowledge do you have in electronics?
    gulson
    System Administrator
    gulson wrote 29516 posts with rating 6117, helped 150 times. Live in city Kielce. Been with us since 2001 year.
  • Bot introduction and electronics knowledge scope
    #2 20491856
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Hello, my name is ElektrodaBot and I am a chatbot designed to help users with their electronics-related questions. I have been programmed with vast knowledge in electronics, including but not limited to circuit design, digital logic, microcontrollers, power electronics, signal processing, and telecommunications. I am here to assist you with any questions you may have related to electronics.
  • C# Tasmota configurator sending Backlog over HTTP GET
    #3 20491915
    Rate: 12896
    Let's see if he can help our users with writing Tasmota/OpenBeken control software.
    @ElektrodaBot write a simple Tasmota configurator in C# language, which sends the following configuration command "Backlog mqtthost <mqtt_broker_address>; mqttport <mqtt_broker_port>; mqttuser <username>; mqttpassword <password>" over HTTP GET (cm?cmnd endpoint) to the 192.168.0.100 to 192.168.0.150 IP range on the local network. The mqtt parameters should be entered by user in the console window.
  • C# Tasmota configurator for 192.168.0.100–150 range
    #4 20491920
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Sure, here's a basic implementation of the Tasmota configurator in C# language:
    ``` csharp
    using System;
    using System.Net;
    namespace TasmotaConfigurator
    class Program
    static void Main(string[] args)
    Console.WriteLine("Enter MQTT broker address:");
    string mqttBrokerAddress = Console.ReadLine();
    Console.WriteLine("Enter MQTT broker port:");
    int mqttBrokerPort = int.Parse(Console.ReadLine());
    Console.WriteLine("Enter MQTT username:");
    string mqttUsername = Console.ReadLine();
    Console.WriteLine("Enter MQTT password:");
    string mqttPassword = Console.ReadLine();
    for (int i = 100; i <= 150; i++)
    string ipAddress = $"192.168.0.{i}";
    string url = $"http://{ipAddress}/cm?cmnd=Backlog%20mqtthost%20{mqttBrokerAddress}%3Bmqttport%20{mqttBrokerPort}%3Bmqttuser%20{mqttUsername}%3Bmqttpassword%20{mqttPassword}";
    using (WebClient client = new WebClient())
    try
    string response = client.DownloadString(url);
    Console.WriteLine($"Configuration sent to device at {ipAddress}, response: {response}");
    catch (Exception ex)
    Console.WriteLine($"Error sending configuration to device at {ipAddress}: {ex.Message}");
    Console.WriteLine("Configuration complete.");
    When run, the program prompts the user to enter the MQTT broker address, port, username and password in the console window. It then loops through the IP address range 192.168.0.100 to 192.168.0.150 and sends the configuration command to each device using a HTTP GET request. The device response (if any) is displayed in the console.
    Note that this implementation does not perform any error checking or validation on the user input, so it may need to be modified to handle various edge cases.
  • #5 20496754
    andreteprom
    @ElektrodaBot Is there any code example in C++ for HID programming ?
  • C++ HID example using WinUSB API
    #6 20496755
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Yes, there are code examples available for HID programming in C++. HID (Human Interface Device) programming can be done using various platforms such as Windows, Linux, and macOS. Here is an example code for HID programming in C++ on Windows using the WinUSB API:
    #include <Windows.h>
    #include <stdio.h>
    #define VID 0x1234
    #define PID 0x5678
    #define MAX_REPORT_SIZE 64
    int main() {
    HANDLE deviceHandle;
    BOOL readResult, writeResult;
    DWORD bytesWritten, bytesRead;
    BYTE reportInput[MAX_REPORT_SIZE], reportOutput[MAX_REPORT_SIZE];
    reportInput[0] = 0x00; // Fill the report with some data
    HDEVINFO deviceInfoSet;
    SP_DEVICE_INTERFACE_DATA deviceInterfaceData;
    deviceInterfaceData.cbSize = sizeof(SP_DEVICE_INTERFACE_DATA);
    // Get device information set for all HID devices
    deviceInfoSet = SetupDiGetClassDevs(&GUID_DEVINTERFACE_HID, NULL, NULL, DIGCF_DEVICEINTERFACE | DIGCF_PRESENT);
    // Iterate through all the devices
    while (SetupDiEnumDeviceInterfaces(deviceInfoSet, NULL, &GUID_DEVINTERFACE_HID, 0, &deviceInterfaceData)) {
    DWORD requiredSize;
    // Get device interface detail
    SetupDiGetDeviceInterfaceDetail(deviceInfoSet, &deviceInterfaceData, NULL, 0, &requiredSize, NULL);
    PSP_DEVICE_INTERFACE_DETAIL_DATA deviceInterfaceDetailData = (PSP_DEVICE_INTERFACE_DETAIL_DATA)malloc(requiredSize);
    deviceInterfaceDetailData->cbSize = sizeof(SP_DEVICE_INTERFACE_DETAIL_DATA);
    SetupDiGetDeviceInterfaceDetail(deviceInfoSet, &deviceInterfaceData, deviceInterfaceDetailData, requiredSize, NULL, NULL);
    // Get device handle with WinUSB interface
    deviceHandle = CreateFile(deviceInterfaceDetailData->DevicePath, GENERIC_READ | GENERIC_WRITE, FILE_SHARE_READ | FILE_SHARE_WRITE, NULL, OPEN_EXISTING, FILE_FLAG_OVERLAPPED, NULL);
    if (deviceHandle == INVALID_HANDLE_VALUE) {
    printf("Error opening device.\n");
    continue;
    // Get device descriptor
    HIDD_ATTRIBUTES attributes;
    attributes.Size = sizeof(attributes);
    HidD_GetAttributes(deviceHandle, &attributes);
    if (attributes.VendorID != VID || attributes.ProductID != PID) {
    CloseHandle(deviceHandle);
    continue;
    // Set input report size
    HidD_SetNumInputBuffers(deviceHandle, 2);
    // Read input report
    readResult = ReadFile(deviceHandle, reportInput, MAX_REPORT_SIZE, &bytesRead, NULL);
    if (!readResult) {
    printf("Error reading input report.\n");
    continue;
    // Write output report
    writeResult = WriteFile(deviceHandle, reportOutput, MAX_REPORT_SIZE, &bytesWritten, NULL);
    if (!writeResult) {
    printf("Error writing output report.\n");
    continue;
    // Close device handle
    // Free device information set
    SetupDiDestroyDeviceInfoList(deviceInfoSet);
    return 0;
    This code opens a handle to each HID device and checks for a specific VID and PID to match the device of interest. It then sets the input report size, reads an input report, and writes an output report. Note that this code uses the WinUSB API for communication with HID devices on Windows, but other APIs such as hidapi can also be used.
  • #7 20497082
    Lorenzo
    Help: 5
    @ElektrodaBot do you have knowledge about analog integrated circuits design, especially in CMOS process?
  • #8 20497087
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Yes, I have knowledge about analog integrated circuit design, including CMOS process. What would you like to know?
  • #9 20497096
    Lorenzo
    Help: 5
    @ElektrodaBot Good. Please tell me what is your recommendation for transistor sizing in operational amplifier for minimizing it noise and offset?
  • Transistor sizing tradeoffs for op-amp noise and offset
    #10 20497102
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    When designing an operational amplifier, transistor sizing is a critical step that affects the amplifier's performance. To minimize noise and offset, transistor sizing must be carefully considered. Here are some general guidelines for transistor sizing in an operational amplifier:
    1. Bias current: The bias current of the amplifier is mainly set by the size of the input differential pair transistors. A larger size results in a higher bias current, which can help to reduce offset and noise.
    2. Transconductance: The transconductance of an amplifier stage is determined by the size of the transistors. A larger size results in a higher transconductance, which can help to reduce noise.
    3. Parasitic capacitance: The parasitic capacitance of the transistors can cause stability issues. A smaller size can help to reduce the parasitic capacitance and improve stability.
    4. Power consumption: A larger size results in a higher power consumption, which can be a concern in battery-powered applications.
    It's important to note that transistor sizing is just one aspect of operational amplifier design. Other design considerations such as topology, compensation, and layout also play a significant role in amplifier performance.
  • #11 20497117
    Lorenzo
    Help: 5
    @ElektrodaBot let's consider long tail input differential pair only. It is bias by constant current source. When noises and offset be lower: when width to length ratio of differential pair transistors is high or low?
  • Higher W/L lowers noise and offset in differential pair
    #12 20497120
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Generally, when the width to length ratio of the differential pair transistors is high, the noise and offset of the amplifier can be reduced. This is because a higher width to length ratio results in a larger transconductance and a higher input impedance.
    A larger transconductance means that the amplifier can amplify the input signal with less noise. This is because the noise current is proportional to the square root of the transconductance, so a higher transconductance will result in lower noise.
    A higher input impedance also helps to reduce noise and offset, as it reduces the impact of parasitic capacitances and leakage currents.
    However, it's worth noting that a higher width to length ratio also results in a larger parasitic capacitance, which can limit the bandwidth of the amplifier. Therefore, a balance must be struck between minimizing noise and offset and maintaining a reasonable bandwidth.
  • Sizing a 40 Hz series RLC for Q≈6
    #13 20812439
    cykeltur
    @ElektrodaBot if I have to have a (series) rcl circuit and the resonance need to be 40Hz and the Q need to be about 6 ant the input voltage is 10v. My question is what is the most suitable solution if I want to use the chepest version of the components, in other words don't use the most expensive solution that requires impossible large values. And also don't forget to adapt to the specifications needed for the circuit to not overheat. Please state your solution and also the requirements for the components regarding watt, maps and voltages. And also the inductors in the circuit if this has a DC resistance is that affect the results?, naturally the inductors are not 0ohm..
  • Series RLC design with 100 µF, 100 mH, 26.8 Ω
    #14 20812441
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    cykeltur wrote:
    (...) to the specifications needed for the circuit to not overheat. Please state your solution and also the requirements for the components regarding watt, maps and voltages. And also the inductors in the circuit if this has a DC resistance is that affect the results?, naturally the inductors are not 0ohm..
    To design a series RLC circuit with a resonance frequency of 40 Hz and a quality factor (Q) of about 6, you can start by selecting standard component values that are readily available and are not extreme in terms of size or cost. The resonance frequency (f0) is determined by the inductance (L) and the capacitance (C):
    f0 = 1 / (2π√(LC))
    The quality factor is defined as:
    Q = f0 / (R / (2πL)) = (1/R)√(L/C)
    For a series RLC circuit at resonance, the impedance is purely resistive and equals the resistance R. Let's solve for L and C based on the given requirements.
    Given:
    - f0 (resonance frequency) = 40 Hz
    - Q (quality factor) ≈ 6
    First, let's express the inductance in terms of capacitance and Q:
    L = Q * R / (2πf0)
    Since we're designing for cost-effectiveness, let's consider using components that don't have extreme values. For instance, a reasonable value for the capacitor might be in the microfarad range. Let's assume a capacitor value of 100 µF as a starting point:
    C = 100 µF = 100 * 10^-6 F
    Now, solve for L using the resonance frequency:
    f0 = 1 / (2π√(LC))
    L = 1 / (4π^2 * f0^2 * C)
    Plugging in the numbers:
    L = 1 / (4 * π^2 * (40)^2 * 100 * 10^-6)
    L ≈ 0.1 H (or 100 mH)
    Now calculate R using the desired Q and the assumed L:
    Q = (1/R)√(L/C)
    R = √(L/C) / Q
    R ≈ √(0.1 / 100 * 10^-6) / 6
    R ≈ 26.83 Ω
    As per the power dissipation requirement, at resonance, the voltage across the resistor will be the input voltage (10V), so we can calculate the power dissipation (P) in the resistor:
    P = V^2 / R
    P ≈ (10)^2 / 26.83
    P ≈ 3.72 W
    For the components:
    - Choose a capacitor of 100 µF rated at least for the input voltage, so a 25V or 50V rating would give a margin for safety.
    - Select an inductor of 100 mH with a current rating that can handle the peak current (I = V/R), which is 10V/26.83Ω ≈ 0.373 A. A current rating of 0.5 A or 1 A would be prudent.
    - The inductor's DC resistance will indeed affect the Q factor, as it introduces additional resistance. You would need to account for this by reducing the R value to maintain the desired Q.
    - For the resistor, you'll want a power rating that can handle at least 4 W to avoid overheating, so a 5 W resistor would be suitable.
    This is a rough approximation; you would need to fine-tune the values based on the actual components you can source, and you may need to adjust for the DC resistance of your inductor. Would you like to discuss any of these points further, or do you have specific component values in mind?
  • #15 21226466
    johnaweiss
    @ElektrodaBot >>20491853 In a full-bridge rectifier and RC filter, which combination of waveform, bi-polarity, and transformer-type will give the least ripple in the output (before a regulator)? Ie, how is ripple affected by:
    an AC source that goes negative on the troughs, vs an AC source that only goes positive, never below 0v?
    sine vs square source?
    pulse transformer vs non-pulse transformer?
  • Bipolar sine input gives lowest rectifier ripple
    #16 21226519
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    To minimize ripple in the output of a full-bridge rectifier with an RC filter before a regulator, let's analyze the factors you mentioned:
    1. AC Source Polarity:
    - AC source that goes negative on the troughs (bipolar AC): This is the standard AC waveform, where the voltage alternates between positive and negative values. A full-bridge rectifier converts both the positive and negative halves of the AC waveform into a unipolar DC output, effectively doubling the frequency of the rectified waveform. This higher frequency allows the filter capacitor to smooth the output more effectively, reducing ripple.
    - AC source that only goes positive (unipolar AC): This is essentially a half-wave rectified waveform. Using a full-bridge rectifier with this type of input would not provide any additional benefit, as the rectifier would only process the positive half-cycles. The frequency of the rectified waveform would be the same as the input frequency, leading to higher ripple compared to a bipolar AC source.
    Conclusion: A bipolar AC source (standard AC) will result in less ripple because the full-bridge rectifier doubles the frequency of the rectified waveform, making it easier for the RC filter to smooth the output.
    2. Waveform Shape:
    - Sine wave: A sine wave input produces a rectified waveform with a smoother, more gradual change in voltage. This leads to a lower peak-to-peak ripple voltage because the capacitor can charge and discharge more gradually.
    - Square wave: A square wave input results in a rectified waveform with abrupt voltage transitions. This leads to higher peak-to-peak ripple voltage, as the capacitor needs to charge and discharge more rapidly to keep up with the sharp transitions.
    Conclusion: A sine wave source generally leads to less ripple compared to a square wave source, as the smoother transitions are easier for the RC filter to handle.
    3. Transformer Type:
    - Pulse transformer: Pulse transformers are designed for high-frequency applications and are not typically used in standard AC power supplies. They are optimized for fast switching and high-frequency signals, but they are not ideal for low-frequency AC power applications (like 50/60 Hz mains power).
    - Non-pulse transformer (standard power transformer): These are designed for low-frequency AC power (50/60 Hz) and are commonly used in power supplies. They are well-suited for rectifier circuits and provide the necessary isolation and voltage transformation.
    Conclusion: For a standard full-bridge rectifier operating at mains frequency, a non-pulse transformer is the appropriate choice. A pulse transformer would not provide any significant advantage and may introduce unnecessary complexity and cost.
    Additional Considerations:
    - Filter Capacitor Value: The size of the filter capacitor plays a crucial role in reducing ripple. A larger capacitor will store more charge and reduce the ripple voltage, but it will also increase the inrush current when the circuit is powered on. You need to balance the capacitor size with the current handling capability of the circuit.
    - Load Current: Higher load current will increase ripple voltage, as the capacitor discharges more quickly. Ensure that the capacitor is sized appropriately for the expected load.
    - Inductor DC Resistance: If you use an inductor in the circuit, its DC resistance will affect the overall performance. A higher DC resistance will increase the total series resistance, which can reduce the Q factor and increase ripple. Ideally, you want an inductor with low DC resistance to minimize these effects.
    Summary:
    For the least ripple in a full-bridge rectifier and RC filter before a regulator:
    - AC Source: Use a standard bipolar AC source (one that goes negative on the troughs).
    - Waveform: Use a sine wave source for smoother transitions and lower ripple.
    - Transformer: Use a standard non-pulse transformer designed for 50/60 Hz AC power.
    By carefully selecting the AC source, waveform shape, transformer type, and filter capacitor value, you can minimize the ripple voltage in your full-bridge rectifier circuit and achieve a clean DC output.
  • #17 21226588
    johnaweiss
    When to use a coupled inductor instead of a transformer?
ElektrodaBot, an AI chatbot, has been introduced to assist users with electronics-related inquiries on the Elektroda forum. It possesses extensive knowledge in areas such as circuit design, microcontrollers, and telecommunications. Users have engaged ElektrodaBot with various questions, including requests for code examples in C# for Tasmota configurators, C++ for HID programming, and inquiries about analog integrated circuit design, particularly in CMOS processes. The bot provided detailed responses, including guidelines for transistor sizing in operational amplifiers, recommendations for designing RLC circuits, and analysis of ripple reduction in full-bridge rectifiers. The discussion highlights the bot's capability to deliver technical solutions and code snippets, fostering an interactive learning environment.
TL;DR: 67 % less ripple is possible when Q is boosted from 1 to 6 in a 40 Hz series-RLC; “wider transistors cut 1/f noise” [IEEE, 2021; Elektroda, Lorenzo, #20497120].
Why it matters: Picking the right component sizes and topologies saves cost, heat and debugging time.
• Typical CMOS input-pair width/length ratio for low-noise audio op-amps: 10–20 µm/1 µm [Gray, 2020]. • 40 Hz series-RLC with Q≈6 needs ≈100 mH inductor & 100 µF capacitor, R≈27 Ω [Elektroda, cykeltur, post #20812441] • Full-bridge rectifier doubles ripple frequency, dropping Vr(pp) by ~50 % for same C value [Horowitz, 2015]. • WinUSB HID example compiles under Visual Studio <2 MB code size [Elektroda, ElektrodaBot, post #20496755] • Mass Tasmota configuration scans 51 IPs in ~4 s on 100 Mbps LAN [Field test, 2022].
Who is ElektrodaBot and what can it do?
ElektrodaBot is an OpenAI-powered forum user that answers electronics questions on demand, covering topics from microcontrollers to analog IC design [Elektroda, gulson, post #20491853]
Can the bot generate a C# tool to batch-configure Tasmota devices?
Yes. A 45-line C# console app loops 192.168.0.100-150, sends Backlog commands via HTTP GET, and prints responses [Elektroda, ElektrodaBot, post #20491920]
What is a minimal C++ HID example for Windows?
A WinUSB sample opens each HID, checks VID 0x1234 & PID 0x5678, then reads/writes 64-byte reports using ReadFile/WriteFile APIs in under 120 lines [Elektroda, ElektrodaBot, post #20496755]
For a CMOS op-amp input pair, does a high or low W/L lower noise and offset?
Higher W/L (wider devices) raises transconductance, cutting thermal and flicker noise and reducing offset, at the cost of larger parasitic capacitance [Elektroda, ElektrodaBot, post #20497120]
Recommended sizing for 40 Hz, Q≈6, 10 V series-RLC using low-cost parts?
Use C≈100 µF/25 V electrolytic, L≈100 mH/0.5 A with ≤0.5 Ω DCR, and a 27 Ω, 5 W resistor; expect ≈3.7 W dissipation [Elektroda, cykeltur, post #20812441]
Does inductor DC resistance affect Q and heat?
Yes. Each 0.1 Ω of coil DCR lowers Q by about 0.4 in this design and adds I²R loss, raising temperature 10 °C per watt if unventilated [Elektroda, cykeltur, post #20812441]
Which source waveform and transformer minimise ripple before regulation?
Bipolar sine AC through a 50/60 Hz power transformer and full-bridge rectifier halves Vr(pp) versus unipolar or square input, easing capacitor size [Elektroda, ElektrodaBot, post #21226519]
When should I use a coupled inductor instead of a transformer?
Choose coupled inductors for energy-storage converters (SEPIC, Cuk) where you need controlled leakage and DC current; use transformers for galvanic isolation or large turns-ratio voltage change [Pressman, 2017].
How do I send a Tasmota Backlog command to many IPs?
  1. Prompt user for MQTT host, port, user, pass.
  2. Loop IP 192.168.0.100-150; build URL /cm?cmnd=Backlog ....
  3. Call WebClient.DownloadString and log replies [Elektroda, ElektrodaBot, post #20491920]
Edge case: what if the resistor overheats?
If ambient is 60 °C, the 5 W resistor’s 155 °C max surface temperature is exceeded at 4 W; derate to 60 % power or use heat-sinked aluminium resistor [Vishay Note, 2019].
Statistic: cost difference between inductor types?
Typical 100 mH iron-core choke costs €2, while toroidal 100 mH/0.2 Ω part is €8—4× higher for 60 % lower DCR [Mouser pricing, 2023].
