Handling 8080 Bus Display with ESP32: Setting GPIO Pins for 8-bit Values
TvWidget 1080 4
  • #1 20500268
    TvWidget
    Help: 472
    Rate: 699
    For example, let's assume that a display with parallel access via the so-called 8080 bus is connected to the ESP32. The individual signals of this bus are connected to different GPIOs in the ESP32. How is such a device handled from the software side? If you want to write an 8-bit value, you need to set the appropriate GPIO pins. How to do this effectively?
    ESP32 I2S LCD mode for fast 8080 transfers
    #2 20509446
    rb401
    Help: 750
    Rate: 984
    TvWidget wrote:
    How to do this efficiently ?
    If by efficiently, you mean large and fast transfers (e.g. graphic displays), then in the ESP32 the only actually hardware support of the 8080 parallel bus (to some extent) is the LCD mode of the I2S periphery (in this context the name I2S is misleading). And there you actually select the pins on which you have a display and make writes with single operations or whole blocks e.g. using DMA.
    That's why I suggest looking for a solution just under the heading ESP32 I2S LCD or similar, because there is a bit of a thing.
  • #4 20510376
    TvWidget
    Help: 472
    Rate: 699
    Thank you for the valuable information. I didn't know that a parallel bus could be handled this way in the ESP32.
  • #5 20556575
    TvWidget
    Help: 472
    Rate: 699
    In the ESP32S3, has the 8080 parallel bus support been moved from I2S to LCD_CAM ?
