[Solved] Domoticz on Docker - Error Writing dzVents Script to /opt/domoticz/userdata
mjab 1077 1
  • Docker volume permissions blocking dzVents script generation
    #1 20522179
    mjab
    Rate: 15
    I installed Domoticz in Docker from the image "domoticz/domoticz:2021-beta.13738" and I need to run (previously working correctly on another machine) the script dzVents.
    However, the script does not work and I have in the logs such an error : Error: EventSystem: problem writing file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/jHeating_TERMOSTATS.lua
    The script looks like this :
    local TERMOSTAT1 = 'Set Temp. Living Room'
    local TERMOSTAT2 = 'Set Temp. Bathroom'
    local TERMOSTAT3 = 'Set Temp. at Philip's'
    local TERMOSTAT4 = 'Set Temp. Bedroom'
    return {
    on = {
    devices = {
    TERMOSTAT1, TERMOSTAT2, TERMOSTAT3, TERMOSTAT4
    execute = function(dz, device)
    if (device.name == TERMOSTAT1) then
    local SetTemp = dz.devices(TERMOSTAT1).setPoint
    dz.log('The thermostat in the living room was set to '. SetTemp , dz.LOG_INFO)
    dz.openURL({
    url = 'http://192.168.0.6/ustaw/set_salon=' ... SetTemp,
    method = 'GET',
    end
    if (device.name == TERMOSTAT2) then
    local SetTemp = dz.devices(TERMOSTAT2).setPoint
    dz.log('The thermostat in the Bathroom was set to '... SetTemp , dz.LOG_INFO)
    dz.openURL({
    url = 'http://192.168.0.6/ustaw/set_lazienka=' ... SetTemp,
    method = 'GET',
    end
    if (device.name == TERMOSTAT3) then
    local SetTemp = dz.devices(TERMOSTAT3).setPoint
    dz.log('The thermostat at Philip's has been set to '... SetTemp , dz.LOG_INFO)
    dz.openURL({
    url = 'http://192.168.0.6/ustaw/set_ufilipa=' ... SetTemp,
    method = 'GET',
    end
    if (device.name == TERMOSTAT4) then
    local SetTemp = dz.devices(TERMOSTAT4).setPoint
    dz.log('The thermostat in the Bedroom was set to '... SetTemp , dz.LOG_INFO)
    dz.openURL({
    url = 'http://192.168.0.6/ustaw/set_sypialnia=' ... SetTemp,
    method = 'GET',
    end
    end
    Can someone help me? :) .
    Jabłoński KOMPUTERY
    Ogrodowa 3a, Rypin, 87-500 | Tel.: 507XXXXXX (Show) | Company Website: https://www.k.j.pl
  • #2 20522185
    mjab
    Rate: 15
    OK, problem solved you need to create all folders i.e. :
    mkdir scripts
    mkdir scripts/dzVents
    mkdir scripts/dzVentsgenerated_scripts
    then give :
    chmod -R 777 scripts
    chmod -R 777 scripts/*
    then restart the container with Domoticz and it worked.
    Of course we use the exec console :) .
    Jabłoński KOMPUTERY
