GPIO fail-safe in ESP with reed switch on long twisted pair cable (25-30m)
jajen 888 3
  • #1 20535286
    jajen
    Rate: 1258
    I have already stoned the gpio in esp 2x in 3 years. This concerns the gpio to which the reed switch is connected between ground and the gpio monitoring the opening of the gate. That it's a gate, the cable from esp to reed switch is like 25m-30m (twisted pair). I suppose sometimes some surge will be generated on it and this is the reason for the gpio getting stoned. Can anyone advise how to protect the gpio?
  • #2 20535311
    xury
    Automation specialist
    Help: 878
    Rate: 1494
    As standard as anything. Opto-isolation.
  • #3 20535347
    78db78
    Help: 1805
    Rate: 3262
    You do the separation on the relay.
  • #4 20535467
