Building a 0-10V PWM Dimmer for MeanWell HLG LED Driver: Arduino, ESP32 Projects & Schematics
rusudanion 2967 0
  • Asking whether firmware supports 0-10V dimming
    #1 20545706
    rusudanion
    Level 4  
    Hello to all, I need to build a 0-10v or 10v pwm dimmer to be able to control the brightness of the leds. The leds are powered by a MeanWell hlg driver which gives the possibility to dim the light, we need a 0-10v dimmer or a potentiometer from 100k. I found some Arduino and esp32 projects on the net. I have one that works well, I need to build another io with esp32 or any other mcu that I can flash. Can someone kindly tell me if your firmware can handle a dimmer 0-10v?
    MY DIMMER
    http://www.urbi.com.es/wp-content/uploads/2021/04/ESP-DATA-SHEET-WIFI-1-10-DIMMER.pdf
    MY LED DRIVER
    https://www.meanwell-web.com/en-gb/ac-dc-sing...ed-driver-mix-mode-cv-cc-with-hlg--120h--48ab
    ESP32 DIMMER SCHEME
    https://github.com/TechSmartSolutions/0-10v-lighting-controller-for-Home-Assistant
