Tuya Aubess Touch wall switch Aliexpress recommendations and experience?
tonyb62 1011 2
  • Asking for Tuya switch experience and OBK flashability
    #1 20591636
    tonyb62
    Has anyone had experience with these?
    I'm looking at trying a few different variants out, or do I stick with the Bunnings Deta brand ones?
    I'm also assuming these will be using a Tuya chip and be flashable with OBK.
    https://www.aliexpress.com/item/1005005042523...%21AU%214095064597&curPageLogUid=lRKkvL4jdfR6
  • TuyaMCU likely compatible with OBK
    #2 20591735
    Rate: 12994
    I don't know this particular device, but feel free to try it. It may be like that:
    Or maybe that one?
    Link: https://www.elektroda.com/rtvforum/topic3948202.html
    It may be TuyaMCU, but this also works well with OBK. Good luck! You can order one piece for a start and we will see how it goes
  • #3 20592682
    tonyb62
    Thank you, looks exactly the same.
    Appears it has a similar touch IC as the Delta switches I've already dismantled. These ones are just a bit more budget-friendly.
