Tasmota on ESP8266: Compilation of distribution for OLED display, BH1750 and BMP280 sensors and IR
Nargo 2190 4
  • Need for a combined Tasmota build with display, sensors, and IR
    #1 20637469
    Nargo
    Help: 45
    Rate: 206
    I am trying to make on a single Wemos chip (ESP8266) and Tasmota, a module for a room, which will display on an OLED-I2C display the data from the sensors plugged in (BH1750 and BMP280) in the room and the control of the air conditioning with an IR diode.
    For the display I need the distribution "DISPLAY".
    For the sensors "SENSORS".
    For the air-conditioning "IR".
    Is it possible to compile one distribution containing all these packages?
    How to do it in a different way.
  • Use my_user_config.h or user_config_override.h
    #2 20638171
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    It is possible.
    I usually compile myself online on gitpod.
    It is true that the developers do not recommend, but the easiest way is just to select the appropriate options in my_user_config.h
    Otherwise move everything as they recommend to the file user_config_override.h
    I do not recommend combining all three distributions. It's better to select only what you are interested in.
    Attached is my example file.
    • user_config_override.h (5.07 KB) You must be logged in to download this attachment.
  • #3 20639469
    Nargo
    Help: 45
    Rate: 206
    I am trying to compile with such a file user_config_override.h
    However, I cannot add support for the air conditioner.
    I am using the platformio run -e tasmot command
    • user_config_override.h (5.08 KB) You must be logged in to download this attachment.
    Use #ifdef and false flags to trim IR support
    #4 20639546
    xury
    Help: 878
    Rate: 1498
    What kind of an air conditioner is it?
    I don't know if you understand the principle of adding and excluding options:
    e.g. if you want it not to compile a certain module you do
    Code: C / C++
    and now if you want DHT support to be compiled:
    Code: C / C++
    And e.g.. to paste support for all IR codes we add:
    Code: C / C++
    and if we don't want any of the codes then underneath we add e.g.:
    Code: C / C++
    itd.
    For example, I turned on everything and then turned off everything I didn't need:
    Code: C / C++
