mH-DEVELOPER F&F Hybrid Installation: Interface Relay for Local and Online Control?
chudy698 861 0
  • Using interface relays for local and online control
    #1 20725256
    chudy698
    We have come up with a smart installation at home using mH-DEVELOPER. Wires from the roller shutter lamp circuits are brought to the switchboard, the same from the roller shutters. The same from the roller shutters. In two boxes, one for switching the lighting and the other for switching the roller shutters, we wanted to have a hybrid installation, i.e. it should be controlled online and locally in the event of a failure of the main module. To this end, we added 3x1.5mm2 to the boxes and now I am wondering how to splice it. I'm wondering if I should use some kind of interface relay where I feed 230V through a short-circuit switch and after the relay there will be 24V and it will then go straight to the main module. Will this solution be good, or can anyone suggest any other ?
