How to recover dead Nedis smart plugs after OTA? BK7231T help
sebastian48 1812 5
  • Need for non-soldering recovery after failed OTA
    #1 20734334
    sebastian48
    Hey everyone. I've been happily using my three Nedis smart plugs with HomeAssistant for about a year. I then tried to do an OTA upgrade but it seems to have broken something. Either way the smart plugs will not boot up anymore so I think I will need to reset and/or manually UART firmware again. Is there any way of not needing to solder and UARTing? As in resetting the firmware? The firmware write did seem to work, it then rebooted but never really came up again...
  • #2 20734372
    Rate: 12914
    Maybe they are back to AP mode?
  • #3 20734402
    sebastian48
    That was my first guess but unfortunately not.
  • #4 20734444
    Rate: 12914
    Try doing 5 quick power off/on cycles.
  • #5 20734506
    sebastian48
    It worked! What did I just do?
    Thank you!
  • #6 20734569
    Rate: 12914
    It is called safe mode, we have an try in FAQ for that:
    https://github.com/openshwprojects/OpenBK7231T_App/blob/main/docs/faq.md
    Text instructions in safe mode on the FAQ page.
