Installation of an electro-valve and draw-off valve in a garden irrigation system.
eryk.tomaszewski 849 2
  • Using a valve switch to control the pump
    #1 20805687
    eryk.tomaszewski
    Rate: 69
    Hi. I have made a system for watering from rainwater. Pump etc. I have brought the blue pipe, but also the control cable to the middle of the garden and a garden hose for this.
    I have now made a simple key like this to run the pump.
    I would like to do something such that at the end of this pipe on the garden side, I put on some electro-valve, plus some tap valve, and that this would start the pump for me and when I close the valve that the electro-valve would cut off the voltage given to the pump. . Is this possible? And will it work?
  • #2 20805716
    radex324
    Help: 50
    Rate: 206
    sonoff wifi relay, you can set links between relays and switch-on times etc.
  • #3 20832095
    eryk.tomaszewski
    Rate: 69
    radex324 wrote:
    Sonoff wifi relay, you can set the links between the relays and the switching time etc.
    A I will look.
