PuTTY, Realterm, terminal programs that let you open a com port. connect at 115200 baud. start with a normal power-up without grounding TX2. Listen for boot log on TX0 and or TX2
Nie, dziękuję Przekieruj mnie tamTL;DR: Teckin SP23’s RTL8710BN module boots with a 40 MHz crystal and logs "TUYA IOT SDK V:2.0.0"; validate via UART before any ESP swap or OBK flash. [Elektroda, divadiow, post #21376313]
Why it matters: This FAQ helps tinkerers decide whether to replace or reflash RTL8710BN-based T112_V1.1 boards in Teckin SP23 plugs.
