KNX: Separate control of two LED strips on the same channel
rafnizp 522 0
  • #1 20839434
    rafnizp
    I have LED strip 1 connected to the KNX dimmer
    I have added a second LED strip 2 on the same channel (see diagram attached)
    The On/Off telegram turns both strips on and off at the same time which is ok
    Question:
    Does anyone know how to disconnect LED 2 with a separate telegram from the bus?
    I am able to turn off LED 2 by putting a regular switch on the plus side between the LEDs.
    • LED.pdf (27.49 KB) You must be logged in to download this attachment.
