LSC Smart XXL LED Strip 10m - Customise configuration and control
theborg0815 2652 2
Treść została przetłumaczona german » english Zobacz oryginalną wersję tematu
  • Pin mapping issues on LSC Smart XXL strip controller
    #1 21423888
    theborg0815
    Hi, I have an "LSC Smart XXL LED Strip" here, the 10m version with the new controller. Unfortunately I haven't found anything about it, but I was able to flash it, unfortunately I can only manage the config semi well.
    Problems:
    - Blue and green are reversed
    - P22 switches the power supply, how do I manage to use this to switch off the LEDs, possibly also with the button on the device and in the web interface?
    - The controller for WW/CW is sometimes there and sometimes not, depending on what I set
    I would be very grateful for any tips.
      "vendor": "Tuya",
      "bDetailed": "0",
      "chip": "BK7231N",
      "board": "TODO",
      "flags": "1024",
      "keywords": [
        "TODO",
        "TODO",
        "TODO"
      "pins": {
        "6": "PWM;0",
        "16": "SM16703P_DIN;0",
        "20": "Btn;0",
        "22": "AlwaysHigh;0",
        "24": "PWM;0"
      "command": "delay_s 5\r\n\r\nstartDriver SM16703P \r\n\r\nSM16703P_Init 40\r\nSM16703P_SetPixel 0 0 255 0\r\nSM16703P_Start\r\n\r\ndelay_s 5\r\n\r\nstartDriver PixelAnim\r\n",
  • #2 21512122
    info207
    Is there any news here?
  • Working config and autoexec for LSC Smart XXL LED strip
    #3 21650046
    nevoness
    Level 4  
    Heya, the strip runs great with this config
    The button also works well if you set it to Btn_SmartLED
    And you have to create an autoexec.bat:
    BR
