Temperature setting in 0.5 degree increments in the Tuya app and thermostat - possibilities and alte
lopab 1683 2
  • Tuya week schedule limited to 1-degree steps
    #1 20849385
    lopab
    I have a problem with the Tuya app and thermostat, namely the thermostat connects to the app and everything is ok. The problem is in setting the heating temperature in the week programming, because I only have by full degrees, while in the description of the thermostat it is every 0.5 degrees. The 0.5 degree manual control works, I can set the temperature in 0.5 degree increments on the fly and in programming it is only in 1 degree increments.
    Please help where the problem is - is it in the Tuya version? Or is there another app that will allow programming every 0.5 degrees?
    Touchscreen thermostat display showing temperature.
  • #2 20849687
    bubu1769
    Help: 1177
    Rate: 2368
    Check out the Smart Life app.
  • #3 20849690
    lopab
    It's the same there. On videos from 2 years ago tuya I see that it was every 0.5 degrees
