Flashing TYWFC6-14 for 4-Channel RGBW Integration in Home Assistant
meav33 789 2
  • 4-channel RGBW MQTT YAML not generated correctly
    #1 20898794
    meav33
    I flashed a 4-channel RGBW controller (TYWFC6-14) with the openBK firmware. (this one: https://device.report/m/cb83b8d16a1226f220c9c54c2ba36cdec3655cad0582d41ec4a18ed605c6321d)
    Everything works well, but I have a problem with the Home Assistant integration.
    If I integrate it as a 4-channel RGB controller or as a 6-channel RGB+CT, it works. But I'm unable to integrate it as a 4-channel RGBW controller.
    How can I make it so it has RGB plus a white channel but not a second white channel?
    With 6 channels set, the generated YAML is:
    Code: YAML
    But if I change it to 4 channels, the YAML changes to the following (which does not work):
    Code: YAML
  • #2 20899781
    Help: 658
    Rate: 12780
    Hello, would you like to integrate it as RGB + W , or maybe as emulated RGBCW? There is a flag for RGBCW emulation with RGBW in OBK.
  • #3 20908932
    meav33
    Ideally, I think I would like it to completely ignore the color temperature. Meaning warm white and cold white should both map to the single white LED.
