[Cloudcutter] Cannot flash Openbeken to Hama E27
bgx 2205 1
Treść została przetłumaczona german » english Zobacz oryginalną wersję tematu
  • 3.3.31 firmware appears patched against Cloudcutter
    #1 20899615
    bgx
    I hope someone can help me. I bought a handful of E14s from Hama the other day and successfully flashed them to Openbeken with Cloudcutter.
    Now I've got a few more E27s from Hama and wanted to flash them to Openbeken with Cloudcutter too. Unfortunately, I always get the error message:
    Scanning for open Tuya SmartLife AP
    Found access point name: "SmartLife-ABCD", trying to connect...
    Device 'wlan0' successfully activated with 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx'.
    Connected to access point.
    [!] The profile you selected did not result in a successful exploit.
    I have the one from the device list Hama E27 176584.
    When I connect it to the Tuyaapp it spits out MCU version 3.3.31.
    How can I proceed?
    Thanks for your help.
    Added after 9 [hours] 49 [minutes]:
    I don't see an answer, but I already got the solution on GitHub. 3.3.31 is probably no longer feasible via cloudcutter, as it has already been patched. I have now bought a few more E14 and will use them with E27 adapters.
  • #2 20900403
    Rate: 12937
    Unfortunately Tuya-cloudcutter does not support newer firmware versions. It's worth trying to rip a 2MB flash from one of the tubes and see if it's susceptible to this exploit.
    If not, flash like this:
