Setting Up OpenBeken 1.17.459 MQTT for Domoticz with BK7231T Relay
LeFranc 2955 2
  • #1 20978262
    LeFranc
    I would like to congratulate all the actors of the transformations and programming, it's a good job.
    I flashed a relay BK7231T, with the tutorial here.
    Everything went well, I can now order it with Domoticz in wifi.
    I'm now looking to set up the (OpenBeken 1.17.459) MQTT for Domoticz, and... I can't do it!
    Is there a tutorial somewhere?
    Yours sincerely, thank you.
  • #2 20990070
    Rate: 12883
    I assume that you are referring to OpenBeken and not to Tasmota?
    If so, we had recently similiar request:
    https://github.com/openshwprojects/OpenBK7231T_App/issues/1100
    It seems that we are still missing some MQTT syntax for Domoticz, but I don't know what kind of syntax is required.
    Can you tell which MQTT adjustements you need for Domoticz to work? I can add them for you quickly.
  • Domoticz MQTT topics for gateway and Tasmota autodiscovery
    #3 20991267
    LeFranc
    Thank you for your response, it’s nice.
    Yes, it is indeed "OpenBeken" error on my part, sorry.
    By sniffing the Raspberry MQTT broker, we can see this:
    domoticz/in {"idx":831,"nvalue":1,"svalue":"","Battery":100,"RSSI":6}
    stat/tasmota_AFCE1F/RESULT {"POWER":"ON"}
    stat/tasmota_AFCE1F/POWER ON
    This is an item under Tasmota esp01 which is currently working.
    Start of code with "domoticz/in {"idx..." corresponds to domoticz MQTT hardware>
    MQTT Client Gateway with LAN interface
    the following code > "Stat/tasmota_...." corresponds to domoticz MQTT hardware>
    Autodiscovery of Tasmota Devices
    If that can help you?
    Sincerely.
