Esp8266 with WLED 0.14.1 resets - problem with WS281B LED settings
Rfck 1728 7
  • Suspect power instability causing random ESP8266 resets
    #1 21015599
    Rfck
    I have a problem with esp8266 bought on Aliexpress. After installing WLED via:
    https://install.wled.me/
    Installing version 0.14.1
    Everything works, I connect to my Wi-Fi network. The problem is that the controller randomly resets and I have to set the color, effect, zones etc. from scratch.
    I can't find the reason why this happens...
    I have a WS281B addressable LED strip connected to this.
    Power supply via 5V3A USB charger.
  • #2 21015764
  • #3 21016261
    Rfck
    One diode needs 60 mA for full white light, there are 60 diodes.
    The power supply has only 3 A, so until it is replaced I do not light at maximum, only half.
  • #4 21018173
    JacekCz
    Help: 760
    Rate: 1464
    Not a power supply but a charger *)
    This has e.g. different dynamics, and flashing is certainly a dynamic situation.
    *) truthfully such a guinea pig.
  • #5 21021018
    Rfck
    I've read this more than once somewhere that a charger is a different thing to a power supply, so perhaps you could explain what the differences are and whether a charger can be used for anything other than charging a phone/battery?
  • #6 21021040
    HD-VIDEO
    Help: 1265
    Rate: 1884
    The charger has a circuit to control the charging process/stabilise the charging/disconnecting current of the batteries after charging and the power supply unit gives 5V with a maximum current of 3A.
    You have the power supply unit
  • #7 21023970
    Rfck
    What does this mean in practice?
  • #8 21024527
    elktrod
    Help: 781
    Rate: 1384
    Connect an ammeter and voltmeter and you may find that after a while the charger recognises that it has charged your "LEDs" and limits the charging current given? And the power supply won't limit the injected current as long as it's working? That's what I think, but I don't know if I'm thinking correctly.
The discussion revolves around an issue with an ESP8266 controller purchased from Aliexpress, which resets randomly after installing WLED version 0.14.1. The user connects a WS281B addressable LED strip powered by a 5V3A USB charger. Responses suggest that the problem may stem from the power supply, as the LED strip requires significant current (60 mA per diode for 60 diodes), exceeding the charger's capacity when all LEDs are lit. Participants clarify the differences between a charger and a power supply, emphasizing that a charger may limit current after detecting a full charge, potentially causing the resets. Recommendations include using a proper power supply instead of a charger to ensure stable operation.
