NSPanel with Tasmota does not display content - how to configure with HomeAssistant?
Filip8X8 2433 2
  • Appdaemon files created in xxx_appdaemon path
    #1 21023384
    Filip8X8
    Hi, I have an NSPanel with tasmota pre-installed (tasmota is already connected to WIFI and works) connected via MQTT to homeassistant (in the logs I saw that nspanel connects) no new device has been added as if in the broker. In the offices and integrations I have detected the tasmota and I have added this panel I can control etc.. But I have a huge problem with the appearance of the panel.... It keeps writing me waiting for content.
    To make some widget on nspanel it is necessary in homeassistant to download appdaemon as far as I know, I tested it and nothing. The first time it didn't create the configuration files and the second time I don't even want to create an appdaemon folder.
    Is anyone able to help?
    Added after 41 [minutes]:
    Mini update, the files were created in the xxx_appdaemon path, they were not created in config/appdaemon. But despite the configuration change it doesn't work
  • #2 21024595
    Rate: 12954
    I think I had this problem while writing this topic:
    https://www.elektroda.pl/rtvforum/topic4005509.html
    From what I remember, a name mismatch was to blame, as I wrote in the linked topic:
    Screenshot of the MQTT configuration interface in an application with example client, user, password, and topic fields.
  • #3 21031208
    Filip8X8
    The names match. MQTT is connected but seems to disconnect from the logs. Although the data is correct. But my biggest fear is that appdaemon has had an update and the file path has been changed, while the nspanel lovelace ui add-on has not and continues to do so in the old path. Has anyone played around with this yet?
