[Solved] How to connect an IPEX antenna to a BL602 / SM028 with ewelink 1CH switch?
mdeveloper 678 2
  • #1 21074704
    mdeveloper
    Hi
    How do I add an external antenna to the BL602/SM028? I have an external IPEX antenna with a female connector - how do I cut the wires and how do I connect? I bought an eWeLink 1CH switch.
    Thanks
  • #2 21076602
    Rate: 12914
    As far as I can see the SM028 does not have a connector for an external antenna, but the Ai-WB2-M1-I, for example, does - below the documentation, you can take a look at the schematic, among other things:
    • Ai-WB2-M1-I_V1.0.0.pdf (951.51 KB) You must be logged in to download this attachment.
  • #3 21818970
    mdeveloper
    I did not need to mount an antenna. Range at a dozen/twenty metres (I did not test longer distances) without an external antenna.
