Setting Up Power Monitoring on POWSAV AHR-083 Power Strip in OpenBeken
Beken_Call 780 2
  • Need the correct OpenBeken energy monitoring driver
    #1 21156170
    Beken_Call
    I am trying to get the POWSAV - AHR-083 power strip up and working in OpenBeken. I got OpenBeken running on it and can control the relays to turn the outlets on and off, but I can't figure out how to get the power monitoring working on it.
    Trying to "Enable and setup some basic energy monitoring" in the UI just throws the error "ERROR: Unknown command (undefined)". I'm guessing maybe that will not work if I haven't given it a driver to run in the autoexec.bat, but I don't know which driver is appropriate for this device.
    Here are some more details on it that might be helpful:
    https://www.jwowlearn2code.com/posts/powsavAHR083/
    https://github.com/tuya-cloudcutter/tuya-clou...hr-083-smart-surge-protector-power-strip.json
    Sorry for asking what is probably something very simple. Thank you!
  • #2 21156174
    Help: 443
    Rate: 908
    I don't see any evidence in the pics, links or Googling that the AHR-083 has any power monitoring capabilities. Where are you seeing that it does?
  • #3 21157026
    Beken_Call
    >>21156174
    Ha, I just had this thought myself before I saw your post -- somehow I assumed that it would being a "smart" device, but I guess the intelligence ends at being able to turn outlets on and off from an app, which I don't really care about. Oh well.
    Anyone aware of something that does this? I wanted some way of differentiating the power draw of multiple devices on one power strip.
