MQTT: How do I change the temperature unit from F to C in MOES ZSS-KB-TH-LY-C-MS?
NicoDB 591 2
  • #1 21182317
    NicoDB
    I have a request for information on how to change the displayed temperature from F to C on the MOES ZSS-KB-TH-LY-C-MS temperature sensor using MQTT.
    Greetings
    Darek
  • Suggesting Zigbee2MQTT temperature display mode setting
    #2 21185932
    Rate: 12885
    But in which ecosystem, are we talking about Zigbee2MQTT + HA?
    Maybe similar to this one?
    https://www.zigbee2mqtt.io/devices/LYWSD03MMC.html
    Temperature display mode (enum)
    The units of the temperature displayed on the device screen. Value can be found in the published state on the temperature_display_mode property. To read (/get) the value publish a message to topic zigbee2mqtt/FRIENDLY_NAME/get with payload {"temperature_display_mode: ""}. To write (/set) a value publish a message to topic zigbee2mqtt/FRIENDLY_NAME/set with payload {"temperature_display_mode": NEW_VALUE}. The possible values are: celsius, fahrenheit.
  • #3 21199051
    NicoDB
    I was generally referring to MQTT and set, just something similar to what you have specified, unfortunately this particular one does not work. Perhaps this model doesn't have this possibility (there was nothing in the instructions), I was asking out of curiosity, because of course there is the possibility to change with a button.
