[Solved] Why OTA Update on BL 602 Chip ends with reboot in old version?
150219v8 1248 9
Why does an OTA update on a BL602 device reboot back into the old firmware version, and how can I update it successfully?
On firmware version 1.17.643, OTA is broken, so the device resets and boots the old version instead of completing the update [#21201985] The workaround is to upload the OTA file from a desktop Chrome browser with limited bandwidth/throttled upload speed [#21203069][#21203359][#21203494] This was confirmed to work by the original poster after using Chrome throttling [#21206003]
  • #1 21201889
    150219v8
    A few weeks ago I successfully flashed a smart socket with a BL 602 chip via Uart with version 1.17.643. If I now try to do an OTA update, the device resets and reboots with the old version. Do I have to pay attention to anything special to perform the update?
  • #3 21203024
    150219v8
    So, the only way for the next update is to open it and flash it by UART again? I can't find a description for a workaround at your link.
  • #5 21203356
    150219v8
    The speed throughput is the solution?
    By the way, I have no professional router like a Cisco to limit the throughput on a port.
  • #6 21203359
    miegapele
    Help: 15
    Rate: 29
    You just need to limit speed with chrome on website.
  • #7 21203451
    150219v8
    Ok it sounds simple, but I have no idea how to do it.
    Is it easy to explain?
    Does it also work with Chrome browser on Android?
  • #9 21204531
    150219v8
    I did it.
    Thanks for your Help.
  • #10 21206003
    150219v8
    Solution: Transfer OTA File with Chrome Browser with Limited bandwidth in Upload.
    Description See Link in Text above.
The discussion revolves around issues encountered during an OTA update on a smart socket utilizing a BL 602 chip, specifically when the device reverts to an older firmware version after rebooting. A user successfully flashed the device with version 1.17.643 but faced problems with OTA updates. It was identified that the OTA functionality is broken in this version, and a workaround involves limiting the upload speed during the transfer of the OTA file using the Chrome browser on a desktop. The solution was confirmed to work after the user implemented the suggested method.
