BK7231N Key Extraction Issue with OpenBeken and BK7231 GUI Flash Tool
jonira 1341 2
  • No JSON config found in extracted Tuya binary
    #1 21223923
    jonira
    I'm trying to flash OpenBeken a CBU board with BK7231 GUI Flash Tool.
    I flashed it and I clicked on "Download Tuya GPIO Config from 0x1EE000". I get a 72KB file but when I drag it in the program (tab: extract config from tuya binary) I get: "failed to extract keys". In the log I see: "Failed to extract Tuya keys - No json start found".
    Is it a problem with the program or the firmware? I used OpenBK7231N_QIO_1.17.606.bin and 692.bin.
  • #2 21223927
    Rate: 12909
    Some of the devices may not have keys configuration. You may need to try GPIODoctor to find out their GPIO roles. What kind of device do you have?
  • #3 21225301
    jonira
    I have found the pins manually and added the device here
