[Solved] Will the TUYA controller handle 15m of LED tape instead of 10m?
gigol123 609 2
  • #1 21228163
    gigol123
    Respected,
    Hint, I have LED strips managed with a controller under TUYA. The controller gives a maximum adjustment of 10m and shows a strip of 10m tape. If I connect another 5m to this 10m section via a connector, should everything work?
    Pawel13741
    Help: 40
    Rate: 54
    It may work, but the power supply in this controller may not work out and either it will be overloaded or the tapes will light up less brightly.
  • #3 21247131
    gigol123
    subject solved, the controller supports approx. 17 m of LED strip without additional measures
