(T34) (BK7231N) try to change the SwitchMode of Tuya DIY Mini Switch
flamel7ramond 1137 2
  • P14 dInput_n enables follow-invert switch mode
    #1 21420853
    flamel7ramond
    Hi everyone, I'm such a newbie on this OpenBeken things.
    btw I just flashed my Tuya DIY mini switch (T34) with OpenBK7231N and it's working now.
    One thing that I want to change is something like "SwitchMode" of Tasmota console command ( I want to make the physical switch that connects to S1-S2 act as a Master switch. Equal to 'SwitchMode1' console command of Tasmota).
    May anyone suggest me how to do it?
    thanks for helping me.
    Added after 44 [minutes]:
    Ok I found it
    because I set the P14 to momentary switch ( which is 'ToggleChannelOnToggle' ). that's why the switch mode of this equal to 'edge mode' of tuya setting.
    Now changing it to 'dInput_n', the switch mode equal to 'follow-invert' of the tuya setting.
  • #2 21422207
    Rate: 12914
    That's right, maybe we need to add it to our FAQ... anyway, is now everything working good for you, or can we still help you somehow?
  • #3 21520237
    flamel7ramond
    >>21422207
    Everything works. But sometimes when the electricity is down, the switch gonna be forgotten from the MQTT and I need to click update HomeAssistant Discovery. And this problem is solved by the startup command (as I recall, I insert the command to wait around 3 sec after booting and update the HA discovery command).
