POLUX TUYA LED strip - blinking and loss of connection after switching off the switch
MatroX13 681 4
  • Possible driver fault causing blinking after power cycle
    #1 21436952
    MatroX13
    Hi.
    I have a problem with a POLUX TUYA LED tape (https://www.interblue.pl/tasmy-led/tasma-led-z-funkcja-muzyczna-sterowana-smartfonem-16w-3000k4000k6000krgb-wifi-smart-tuyasmart-polux.html).
    After pairing the tape with the Tuya app, when I turn it off with the wall switch and turn it back on, the tape starts flashing and loses connection with the app.
    What could be causing this problem? Is it possible that the tape driver is faulty?
  • #2 21436973
    sosarek
    Help: 9320
    Rate: 15540
    It should not be switched off but constantly connected to the power supply.
    Z
    Pka, Poznań, 60-850
  • #3 21436978
    MatroX13
    In that case, how do you switch off the strip? Via the app?
  • #5 21457602
    MatroX13
    My question is, would adding a Zigbee gateway solve the problem?
