S18 IR Blaster PulseDistance Protocol: Troubleshooting Transmission Issues
c0rkster 738 0
  • PulseDistance decode works, but transmit sends no IR pulses
    #1 21468159
    c0rkster
    Hi, im trying to control a floorfan using IR, i can control other devices using the NEC protocol, but setting PulseDistance as protocol does not transmitting anything (IR LEDs dont blink)
    Setting any of the other protocols and using the values randomly(no idea what im doing;) as the ADDR and CMD arguments and the results will vary from shortened values or turn into 0xFFF but the IR LEDs do blink.
    This is what i get in the WebApp Logs when i press the buttons on the fan remote..
    Debug:IR:IR decode returned true, protocol 1
    Debug:IR: Raw-Data=0xFC03
    Debug:IR: 48 bits
    Debug:IR: LSB first
    Debug:IR:IR decode returned true, protocol PulseDistance (1)
    Info:IR:IR IR_PulseDistance 0xB22 0xB0B 0 (48 bits)
    Info:MQTT:Publishing val {"IrReceived":{"Protocol":"PulseDistance","Bits":48,"Data":"0xFC03"}} to irblaster/RESULT retain=0
    Debug:IR:IR fire event took 0ms
    #Debug info remains the same so i cut it out to make this less messy:
    Info:IR:IR IR_PulseDistance 0xC21 0xC0A 0 (48 bits)
    Info:IR:IR IR_PulseDistance 0xC20 0xC0A 0 (48 bits)
    Info:MQTT:Publishing val {"IrReceived":{"Protocol":"PulseDistance","Bits":48,"Data":"0xF00F"}} to irblaster/RESULT retain=0
    Info:MQTT:Publishing val {"IrReceived":{"Protocol":"PulseDistance","Bits":48,"Data":"0xF40B"}} to irblaster/RESULT retain=0
    Info:MQTT:Publishing val {"IrReceived":{"Protocol":"PulseDistance","Bits":48,"Data":"0xF20D"}} to irblaster/RESULT retain=0
    Info:IR:IR IR_PulseDistance 0xD20 0xD0A 0 (48 bits)
    Info:MQTT:Publishing val {"IrReceived":{"Protocol":"PulseDistance","Bits":48,"Data":"0xEE11"}} to irblaster/RESULT retain=0
    Info:MQTT:Publishing val {"IrReceived":{"Protocol":"PulseDistance","Bits":48,"Data":"0xD22D"}} to irblaster/RESULT retain=0
    This is what i get back when i send the command using WebApp
    Info:IR:Delay 100ms
    Info:IR:IR send PulseDistance 0xC21 0xC0A 0 protocol 1 addr 0xC21 cmd 0xC0A repeats 0 bits override 0
    Info:CMD:[WebApp Cmd 'IRsend PulseDistance 0xC21 0xC0A 0' Result] OK
    With the ReceiveAndSendDistanceWidth.ino example from IRremote i can record and send the signal and the fan does its thing
    Arduino serial monitor ouput:
    Spoiler:
    Using library version 4.4.1
    Ready to receive pulse distance/width coded IR signals at pin 15
    Ready to send IR signals at pin 4 on press of button at pin 10
    Mark:
     0: 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
    10: 0 | 0 | 48x600 |
    Space:
    10: 24x500 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
    20: 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
    30: 0 | 0 | 0 | 23x1650 | 0 |
    DistanceWidthTimingInfoStruct: 8950, 4450, 0, 1650, 600, 500
    PULSE_WIDTH: decodedRawData=0xFC03FC03FE01
    DistanceWidthTimingInfo=8950, 4450, 600, 1650, 600, 500
    Protocol=PulseDistance Raw-Data=0xFC03FC03FE01 48 bits LSB first
    Send on a 32 bit platform with: IrSender.sendPulseDistanceWidth(38, 8950, 4450, 600, 1650, 600, 500, 0xFC03FC03FE01, 48, PROTOCOL_IS_LSB_FIRST, <RepeatPeriodMillis>, <numberOfRepeats>);
    Store new timing info data=8950, 4450, 600, 1650, 600, 500
    Store new numberOfBits=48
    Store new sDecodedRawDataArray[0]=0xFC03FC03FE01
    Stop receiving
    Button pressed, now sending 48 bits 0xFC03FC03FE01 with sendPulseDistanceWidthFromArray timing=8950, 4450, 600, 1650, 600, 500
    Data[0]=0xFC03FC03FE01 #=48
    FC03FC03FE01|48
    Button released -> start receiving
    Almost out of scalp hair to pull so any help is much appreciated (while iam at it very much thanks for this firmware, all your hard work resulted in me having many hours of fun!)
    AI: Could you provide the specific model of the IR blaster and the floor fan you're using?
    TUYA Home Smart Life Mini Universal IR Remote S18 (BK7231N) [CB3S]
    Anslut Floor Fan
    Item No.: 01470
    AI: Can you describe your setup and configuration for the IR blaster, including any specific settings or connections?
    "pins": {
    "6": "Btn;1",
    "7": "IRRecv;0",
    "8": "LED;0",
    "26": "IRSend;0"
