BK7231GUIFlashTool-v50 Flashing Error with OpenBK7231N_QIO_1.18.187.bin on DS12D-WF CB2S
clasik 753 11
How can I fix the flashing error when writing OpenBK7231N_QIO_1.18.187.bin to a DS12D-WF CB2S module with BK7231GUIFlashTool?
Update BK7231GUIFlashTool first, because a recent v50 release had a bug and the fix was to retry with v95 [#21710360] If it still fails, the flashing setup is likely unreliable: shorten all the UART wires and make sure the module has a solid power supply, since powering only from the CP2102 may not be enough [#21710508][#21710618] In the thread, the module finally flashed after the wires were shortened [#21710618]
  • Flash tool detects TH25Q16HB flash and reads encryption key
    #1 21710016
    clasik
    Level 4  
    I am getting this error when I am trying to flash OpenBK7231N_QIO_1.18.187.bin with BK7231GUIFlashTool-v50 in my DS12D-WF CB2S WiFi Curtain Module
    Can anyone help me with this error?
    Starting flash new (no backup)!
    Now is: sábado, 4 de octubre de 2025 18:17:08.
    Flasher mode: BK7231N
    Going to open port: COM3.
    Serial port open!
    Getting bus success!
    Going to set baud rate setting (115200)!
    Flash MID loaded: 1560EB
    Flash def found! For: 1560EB
    Flash information: mid: 1560EB, icName: TH25Q16HB, manufacturer: TH, szMem: 1000000, szSR: 2, cwUnp: 0, cwEnp: 7, cwMsk: 407C, sb: 2, lb: 5, cwdRd: 05-35-FF-FF, cwdWr: 01-FF-FF-FF
    sr: 0
    sr: 0
    final sr: 0
    msk: 407c
    cw: 0, sb: 2, lb: 5
    bfd: 0
    Going to read encryption key...
    Encryption key read done!
    Encryption key: 510fb093 a3cbeadc 5993a17e c7adeb03
    Reading file firmwares/OpenBK7231N_QIO_1.18.187.bin...
    Loaded 1220464 bytes from firmwares/OpenBK7231N_QIO_1.18.187.bin...
    Using hack to write QIO - just skip bootloader...
    ... so bootloader will not be overwritten!
    Preparing to write data file to chip - resetting bus and baud...
    sr: 0
    sr: 0
    final sr: 0
    msk: 407c
    cw: 0, sb: 2, lb: 5
    bfd: 0
    Going to do erase, start 69632, sec count 281!
    Erasing sector 69632... ok! Erasing sector 73728... ok! Erasing sector 77824... ok! Erasing sector 81920... ok! Erasing sector 86016... ok! Erasing sector 90112... ok! Erasing sector 94208... ok! Erasing sector 98304... ok! Erasing sector 102400... ok! Erasing sector 106496... ok! Erasing sector 110592... ok! Erasing sector 114688... ok! Erasing sector 118784... ok! Erasing sector 122880... ok! Erasing sector 126976... ok! Erasing sector 131072... ok! Erasing sector 135168... ok! Erasing sector 139264... ok! Erasing sector 143360... ok! Erasing sector 147456... ok! Erasing sector 151552... ok! Erasing sector 155648... ok! Erasing sector 159744... ok! Erasing sector 163840... ok! Erasing sector 167936... ok! Erasing sector 172032... ok! Erasing sector 176128... ok! Erasing sector 180224... ok! Erasing sector 184320... ok! Erasing sector 188416... ok! Erasing sector 192512... ok! Erasing sector 196608... ok! Erasing sector 200704... ok! Erasing sector 204800... ok! Erasing sector 208896... ok! Erasing sector 212992... ok! Erasing sector 217088... ok! Erasing sector 221184... ok! Erasing sector 225280... ok! Erasing sector 229376... ok! Erasing sector 233472... ok! Erasing sector 237568... ok! Erasing sector 241664... ok! Erasing sector 245760... ok! Erasing sector 249856... ok! Erasing sector 253952... ok! Erasing sector 258048... ok! Erasing sector 262144... ok! Erasing sector 266240... ok! Erasing sector 270336... ok! Erasing sector 274432... ok! Erasing sector 278528... ok! Erasing sector 282624... ok! Erasing sector 286720... ok! Erasing sector 290816... ok! Erasing sector 294912... ok! Erasing sector 299008... ok! Erasing sector 303104... ok! Erasing sector 307200... ok! Erasing sector 311296... ok! Erasing sector 315392... ok! Erasing sector 319488... ok! Erasing sector 323584... ok! Erasing sector 327680... ok! Erasing sector 331776... ok! Erasing sector 335872... ok! Erasing sector 339968... ok! Erasing sector 344064... ok! Erasing sector 348160... ok! Erasing sector 352256... ok! Erasing sector 356352... ok! Erasing sector 360448... ok! Erasing sector 364544... ok! Erasing sector 368640... ok! Erasing sector 372736... ok! Erasing sector 376832... ok! Erasing sector 380928... ok! Erasing sector 385024... ok! Erasing sector 389120... ok! Erasing sector 393216... ok! Erasing sector 397312... ok! Erasing sector 401408... ok! Erasing sector 405504... ok! Erasing sector 409600... ok! Erasing sector 413696... ok! Erasing sector 417792... ok! Erasing sector 421888... ok! Erasing sector 425984... ok! Erasing sector 430080... ok! Erasing sector 434176... ok! Erasing sector 438272... ok! Erasing sector 442368... ok! Erasing sector 446464... ok! Erasing sector 450560... ok! Erasing sector 454656... ok! Erasing sector 458752... ok! Erasing sector 462848... ok! Erasing sector 466944... ok! Erasing sector 471040... ok! Erasing sector 475136... ok! Erasing sector 479232... ok! Erasing sector 483328... ok! Erasing sector 487424... ok! Erasing sector 491520... ok! Erasing sector 495616... ok! Erasing sector 499712... ok! Erasing sector 503808... ok! Erasing sector 507904... ok! Erasing sector 512000... ok! Erasing sector 516096... ok! Erasing sector 520192... ok! Erasing sector 524288... ok! Erasing sector 528384... ok! Erasing sector 532480... ok! Erasing sector 536576... ok! Erasing sector 540672... ok! Erasing sector 544768... ok! Erasing sector 548864... ok! Erasing sector 552960... ok! Erasing sector 557056... ok! Erasing sector 561152... ok! Erasing sector 565248... ok! Erasing sector 569344... ok! Erasing sector 573440... ok! Erasing sector 577536... ok! Erasing sector 581632... ok! Erasing sector 585728... ok! Erasing sector 589824... ok! Erasing sector 593920... ok! Erasing sector 598016... ok! Erasing sector 602112... ok! Erasing sector 606208... ok! Erasing sector 610304... ok! Erasing sector 614400... ok! Erasing sector 618496... ok! Erasing sector 622592... ok! Erasing sector 626688... ok! Erasing sector 630784... ok! Erasing sector 634880... ok! Erasing sector 638976... ok! Erasing sector 643072... ok! Erasing sector 647168... ok! Erasing sector 651264... ok! Erasing sector 655360... ok! Erasing sector 659456... ok! Erasing sector 663552... ok! Erasing sector 667648... ok! Erasing sector 671744... ok! Erasing sector 675840... ok! Erasing sector 679936... ok! Erasing sector 684032... ok! Erasing sector 688128... ok! Erasing sector 692224... ok! Erasing sector 696320... ok! Erasing sector 700416... ok! Erasing sector 704512... ok! Erasing sector 708608... ok! Erasing sector 712704... ok! Erasing sector 716800... ok! Erasing sector 720896... ok! Erasing sector 724992... ok! Erasing sector 729088... ok! Erasing sector 733184... ok! Erasing sector 737280... ok! Erasing sector 741376... ok! Erasing sector 745472... ok! Erasing sector 749568... ok! Erasing sector 753664... ok! Erasing sector 757760... ok! Erasing sector 761856... ok! Erasing sector 765952... ok! Erasing sector 770048... ok! Erasing sector 774144... ok! Erasing sector 778240... ok! Erasing sector 782336... ok! Erasing sector 786432... ok! Erasing sector 790528... ok! Erasing sector 794624... ok! Erasing sector 798720... ok! Erasing sector 802816... ok! Erasing sector 806912... ok! Erasing sector 811008... ok! Erasing sector 815104... ok! Erasing sector 819200... ok! Erasing sector 823296... ok! Erasing sector 827392... ok! Erasing sector 831488... ok! Erasing sector 835584... ok! Erasing sector 839680... ok! Erasing sector 843776... ok! Erasing sector 847872... ok! Erasing sector 851968... ok! Erasing sector 856064... ok! Erasing sector 860160... ok! Erasing sector 864256... ok! Erasing sector 868352... ok! Erasing sector 872448... ok! Erasing sector 876544... ok! Erasing sector 880640... ok! Erasing sector 884736... ok! Erasing sector 888832... ok! Erasing sector 892928... ok! Erasing sector 897024... ok! Erasing sector 901120... ok! Erasing sector 905216... ok! Erasing sector 909312... ok! Erasing sector 913408... ok! Erasing sector 917504... ok! Erasing sector 921600... ok! Erasing sector 925696... ok! Erasing sector 929792... ok! Erasing sector 933888... ok! Erasing sector 937984... ok! Erasing sector 942080... ok! Erasing sector 946176... ok! Erasing sector 950272... ok! Erasing sector 954368... ok! Erasing sector 958464... ok! Erasing sector 962560... ok! Erasing sector 966656... ok! Erasing sector 970752... ok! Erasing sector 974848... ok! Erasing sector 978944... ok! Erasing sector 983040... ok! Erasing sector 987136... ok! Erasing sector 991232... ok! Erasing sector 995328... ok! Erasing sector 999424... ok! Erasing sector 1003520... ok! Erasing sector 1007616... ok! Erasing sector 1011712... ok! Erasing sector 1015808... ok! Erasing sector 1019904... ok! Erasing sector 1024000... ok! Erasing sector 1028096... ok! Erasing sector 1032192... ok! Erasing sector 1036288... ok! Erasing sector 1040384... ok! Erasing sector 1044480... ok! Erasing sector 1048576... ok! Erasing sector 1052672... ok! Erasing sector 1056768... ok! Erasing sector 1060864... ok! Erasing sector 1064960... ok! Erasing sector 1069056... ok! Erasing sector 1073152... ok! Erasing sector 1077248... ok! Erasing sector 1081344... ok! Erasing sector 1085440... ok! Erasing sector 1089536... ok! Erasing sector 1093632... ok! Erasing sector 1097728... ok! Erasing sector 1101824... ok! Erasing sector 1105920... ok! Erasing sector 1110016... ok! Erasing sector 1114112... ok! Erasing sector 1118208... ok! Erasing sector 1122304... ok! Erasing sector 1126400... ok! Erasing sector 1130496... ok! Erasing sector 1134592... ok! Erasing sector 1138688... ok! Erasing sector 1142784... ok! Erasing sector 1146880... ok! Erasing sector 1150976... ok! Erasing sector 1155072... ok! Erasing sector 1159168... ok! Erasing sector 1163264... ok! Erasing sector 1167360... ok! Erasing sector 1171456... ok! Erasing sector 1175552... ok! Erasing sector 1179648... ok! Erasing sector 1183744... ok! Erasing sector 1187840... ok! Erasing sector 1191936... ok! Erasing sector 1196032... ok! Erasing sector 1200128... ok! Erasing sector 1204224... ok! Erasing sector 1208320... ok! Erasing sector 1212416... ok! Erasing sector 1216512... ok!
    All selected sectors erased!
    Writing sector 0x11000... ok! CheckRespond_FlashWrite4K: bad value returned?
    Writing sector 0x12000... Writing sector 73728 failed!
    Writing file data to chip failed.
    AI: Can you describe how you have connected the DS12D-WF CB2S module to your computer for flashing (e.g., which USB-to-serial adapter you are using, wiring details, and whether you are powering the module externally or through the adapter)?
    I am using an usb-to-serial CP2102
    AI: Have you successfully flashed this device or similar BK7231N-based devices before using this tool and firmware, or is this your first attempt?
    This is first time, however I have flashed other equals devices without any problem.
  • #2 21710360
    Rate: 12968
    Recent Flasher release had a bug that was accidentally pushed to production. Can you retry with BK7231GUIFlashTool v95? https://github.com/openshwprojects/BK7231GUIFlashTool
  • Flash fails in finish sector on TH25Q16HB CB2S
    #3 21710493
    clasik
    Level 4  
    >>21710360
    It almost worked... it failed in the finish sector:
    Now is: domingo, 5 de octubre de 2025 10:29:45.
    Serial port open!
    Flash information: mid: 1560EB, icName: TH25Q16HB, manufacturer: TH, szMem: 200000, szSR: 2, cwUnp: 0, cwEnp: 7, cwMsk: 407C, sb: 2, lb: 5, cwdRd: 05-35-FF-FF, cwdWr: 01-FF-FF-FF
    Flash size is 2MB
    sr: 0
    sr: 0
    final sr: 0
    msk: 407c
    cw: 0, sb: 2, lb: 5
    bfd: 0
    Reading file firmwares/OpenBK7231N_QIO_1.18.188.bin...
    Loaded 1220464 bytes from firmwares/OpenBK7231N_QIO_1.18.188.bin...
    Flash size is 2MB
    sr: 0
    sr: 0
    final sr: 0
    msk: 407c
    cw: 0, sb: 2, lb: 5
    bfd: 0
    Writing sector 0x11000... ok! Writing sector 0x12000... ok! Writing sector 0x13000... ok! Writing sector 0x14000... ok! Writing sector 0x15000... ok! Writing sector 0x16000... ok! Writing sector 0x17000... ok! Writing sector 0x18000... ok! Writing sector 0x19000... ok! Writing sector 0x1A000... ok! Writing sector 0x1B000... ok! Writing sector 0x1C000... ok! Writing sector 0x1D000... ok! Writing sector 0x1E000... ok! Writing sector 0x1F000... ok! Writing sector 0x20000... ok! Writing sector 0x21000... ok! Writing sector 0x22000... ok! Writing sector 0x23000... ok! Writing sector 0x24000... ok! Writing sector 0x25000... ok! Writing sector 0x26000... ok! Writing sector 0x27000... ok! Writing sector 0x28000... ok! Writing sector 0x29000... ok! Writing sector 0x2A000... ok! Writing sector 0x2B000... ok! Writing sector 0x2C000... ok! Writing sector 0x2D000... ok! Writing sector 0x2E000... ok! Writing sector 0x2F000... ok! Writing sector 0x30000... ok! Writing sector 0x31000... ok! Writing sector 0x32000... ok! Writing sector 0x33000... ok! Writing sector 0x34000... ok! Writing sector 0x35000... ok! Writing sector 0x36000... ok! Writing sector 0x37000... ok! Writing sector 0x38000... ok! Writing sector 0x39000... ok! Writing sector 0x3A000... ok! Writing sector 0x3B000... ok! Writing sector 0x3C000... ok! Writing sector 0x3D000... ok! Writing sector 0x3E000... ok! Writing sector 0x3F000... ok! Writing sector 0x40000... ok! Writing sector 0x41000... ok! Writing sector 0x42000... ok! Writing sector 0x43000... ok! Writing sector 0x44000... ok! Writing sector 0x45000... ok! Writing sector 0x46000... ok! Writing sector 0x47000... ok! Writing sector 0x48000... ok! Writing sector 0x49000... ok! Writing sector 0x4A000... ok! Writing sector 0x4B000... ok! Writing sector 0x4C000... ok! Writing sector 0x4D000... ok! Writing sector 0x4E000... ok! Writing sector 0x4F000... ok! Writing sector 0x50000... ok! Writing sector 0x51000... ok! Writing sector 0x52000... ok! Writing sector 0x53000... ok! Writing sector 0x54000... ok! Writing sector 0x55000... ok! Writing sector 0x56000... ok! Writing sector 0x57000... ok! Writing sector 0x58000... ok! Writing sector 0x59000... ok! Writing sector 0x5A000... ok! Writing sector 0x5B000... ok! Writing sector 0x5C000... ok! Writing sector 0x5D000... ok! Writing sector 0x5E000... ok! Writing sector 0x5F000... ok! Writing sector 0x60000... ok! Writing sector 0x61000... ok! Writing sector 0x62000... ok! Writing sector 0x63000... ok! Writing sector 0x64000... ok! Writing sector 0x65000... ok! Writing sector 0x66000... ok! Writing sector 0x67000... ok! Writing sector 0x68000... ok! Writing sector 0x69000... ok! Writing sector 0x6A000... ok! Writing sector 0x6B000... ok! Writing sector 0x6C000... ok! Writing sector 0x6D000... ok! Writing sector 0x6E000... ok! Writing sector 0x6F000... ok! Writing sector 0x70000... ok! Writing sector 0x71000... ok! Writing sector 0x72000... ok! Writing sector 0x73000... ok! Writing sector 0x74000... ok! Writing sector 0x75000... ok! Writing sector 0x76000... ok! Writing sector 0x77000... ok! Writing sector 0x78000... ok! Writing sector 0x79000... ok! Writing sector 0x7A000... ok! Writing sector 0x7B000... ok! Writing sector 0x7C000... ok! Writing sector 0x7D000... ok! Writing sector 0x7E000... ok! Writing sector 0x7F000... ok! Writing sector 0x80000... ok! Writing sector 0x81000... ok! Writing sector 0x82000... ok! Writing sector 0x83000... ok! Writing sector 0x84000... ok! Writing sector 0x85000... ok! Writing sector 0x86000... ok! Writing sector 0x87000... ok! Writing sector 0x88000... ok! Writing sector 0x89000... ok! Writing sector 0x8A000... ok! Writing sector 0x8B000... ok! Writing sector 0x8C000... ok! Writing sector 0x8D000... ok! Writing sector 0x8E000... ok! Writing sector 0x8F000... ok! Writing sector 0x90000... ok! Writing sector 0x91000... ok! Writing sector 0x92000... ok! Writing sector 0x93000... ok! Writing sector 0x94000... ok! Writing sector 0x95000... ok! Writing sector 0x96000... ok! Writing sector 0x97000... ok! Writing sector 0x98000... ok! Writing sector 0x99000... ok! Writing sector 0x9A000... ok! Writing sector 0x9B000... ok! Writing sector 0x9C000... ok! Writing sector 0x9D000... ok! Writing sector 0x9E000... ok! Writing sector 0x9F000... ok! Writing sector 0xA0000... ok! Writing sector 0xA1000... ok! Writing sector 0xA2000... ok! Writing sector 0xA3000... ok! Writing sector 0xA4000... ok! Writing sector 0xA5000... ok! Writing sector 0xA6000... ok! Writing sector 0xA7000... ok! Writing sector 0xA8000... ok! Writing sector 0xA9000... ok! Writing sector 0xAA000... ok! Writing sector 0xAB000... ok! Writing sector 0xAC000... ok! Writing sector 0xAD000... ok! Writing sector 0xAE000... ok! Writing sector 0xAF000... ok! Writing sector 0xB0000... ok! Writing sector 0xB1000... ok! Writing sector 0xB2000... ok! Writing sector 0xB3000... ok! Writing sector 0xB4000... ok! Writing sector 0xB5000... ok! Writing sector 0xB6000... ok! Writing sector 0xB7000... ok! Writing sector 0xB8000... ok! Writing sector 0xB9000... ok! Writing sector 0xBA000... ok! Writing sector 0xBB000... ok! Writing sector 0xBC000... ok! Writing sector 0xBD000... ok! Writing sector 0xBE000... ok! Writing sector 0xBF000... ok! Writing sector 0xC0000... ok! Writing sector 0xC1000... ok! Writing sector 0xC2000... ok! Writing sector 0xC3000... ok! Writing sector 0xC4000... ok! Writing sector 0xC5000... ok! Writing sector 0xC6000... ok! Writing sector 0xC7000... ok! Writing sector 0xC8000... ok! Writing sector 0xC9000... ok! Writing sector 0xCA000... ok! Writing sector 0xCB000... ok! Writing sector 0xCC000... ok! Writing sector 0xCD000... ok! Writing sector 0xCE000... ok! Writing sector 0xCF000... ok! Writing sector 0xD0000... ok! Writing sector 0xD1000... ok! Writing sector 0xD2000... ok! Writing sector 0xD3000... ok! Writing sector 0xD4000... ok! Writing sector 0xD5000... ok! Writing sector 0xD6000... ok! Writing sector 0xD7000... ok! Writing sector 0xD8000... ok! Writing sector 0xD9000... ok! Writing sector 0xDA000... ok! Writing sector 0xDB000... ok! Writing sector 0xDC000... ok! Writing sector 0xDD000... ok! Writing sector 0xDE000... ok! Writing sector 0xDF000... ok! Writing sector 0xE0000... ok! Writing sector 0xE1000... ok! Writing sector 0xE2000... ok! Writing sector 0xE3000... ok! Writing sector 0xE4000... ok! Writing sector 0xE5000... ok! Writing sector 0xE6000... ok! Writing sector 0xE7000... ok! Writing sector 0xE8000... ok! Writing sector 0xE9000... ok! Writing sector 0xEA000... ok! Writing sector 0xEB000... ok! Writing sector 0xEC000... ok! Writing sector 0xED000... ok! Writing sector 0xEE000... ok! Writing sector 0xEF000... ok! Writing sector 0xF0000... ok! Writing sector 0xF1000... ok! Writing sector 0xF2000... ok! Writing sector 0xF3000... ok! Writing sector 0xF4000... ok! Writing sector 0xF5000... ok! Writing sector 0xF6000... ok! Writing sector 0xF7000... ok! Writing sector 0xF8000... ok! Writing sector 0xF9000... ok! Writing sector 0xFA000... ok! Writing sector 0xFB000... ok! Writing sector 0xFC000... ok! Writing sector 0xFD000... ok! Writing sector 0xFE000... ok! Writing sector 0xFF000... ok! Writing sector 0x100000... ok! Writing sector 0x101000... ok! Writing sector 0x102000... ok! Writing sector 0x103000... ok! Writing sector 0x104000... ok! Writing sector 0x105000... ok! Writing sector 0x106000... ok! Writing sector 0x107000... ok! Writing sector 0x108000... ok! Writing sector 0x109000... ok! Writing sector 0x10A000... ok! Writing sector 0x10B000... ok! Writing sector 0x10C000... ok! Writing sector 0x10D000... ok! Writing sector 0x10E000... ok! Writing sector 0x10F000... ok! Writing sector 0x110000... ok! Writing sector 0x111000... ok! Writing sector 0x112000... ok! Writing sector 0x113000... ok! Writing sector 0x114000... ok! Writing sector 0x115000... ok! Writing sector 0x116000... ok! Writing sector 0x117000... ok! Writing sector 0x118000... ok! Writing sector 0x119000... ok! Writing sector 0x11A000... ok! Writing sector 0x11B000... ok! Writing sector 0x11C000... ok! Writing sector 0x11D000... ok! Writing sector 0x11E000... ok! Writing sector 0x11F000... ok! Writing sector 0x120000... ok! Writing sector 0x121000... ok! Writing sector 0x122000... ok! Writing sector 0x123000... ok! Writing sector 0x124000... ok! Writing sector 0x125000... ok! Writing sector 0x126000... ok! Writing sector 0x127000... ok! Writing sector 0x128000... ok! CheckRespond_FlashWrite4K: bad value returned?
    Writing sector 0x129000... Writing sector 1216512 failed!
  • #4 21710508
    Rate: 12968
    How do you power your device? Powering from CP2102 may not be sufficient. Can you make a photo?
  • #5 21710521
    clasik
    Level 4  
    I don’t power it, I connect rx, tx, and gnd, CEN momentary to gnd. I have flashed 10 equal devices with the same way.
    However, I have tried to connect it to 220v but I get the same error. I asked to ChatGPT…
  • #6 21710551
    insmod
    Help: 168
    Rate: 455
    Try higher baud rate
  • #7 21710567
    clasik
    Level 4  
    >>21710551
    Thanks, now I am getting other stranger error:
  • #8 21710589
    Rate: 12968
    Strange.... I was actually thinking that maybe you have a broken version, but no, it works on my CB3S:
    Can you show a photo of how you connect it?
  • QIO flash write fails after bus reset
    #9 21710616
    clasik
    Level 4  
    >>21710589
    I got it! I flashed it with itchiptool.
    Now, I have to flash the last of 12 devices, but I am getting other strange error with BK7231GUIFlashTool-v95 and OpenBK7231N_QIO_1.18.187.bin
    I can't flash it with BK7231GUIFlashTool neither itchiptool. Do you know why am getting this error?
    Now is: domingo, 5 de octubre de 2025 11:53:51.
    Serial port open!
    Getting bus failed, will try again - 0/100!
    Going to set baud rate setting (230400)!
    Flash size is 2MB
    sr: 0
    sr: 0
    final sr: 0
    msk: 407c
    cw: 0, sb: 2, lb: 5
    bfd: 0
    Flash size is 2MB
    sr: 0
    sr: 0
    final sr: 0
    msk: 407c
    cw: 0, sb: 2, lb: 5
    bfd: 0
    Writing sector 0x11000... ok! Writing sector 0x12000... ok! Writing sector 0x13000... ok! Writing sector 0x14000... ok! Writing sector 0x15000... ok! Writing sector 0x16000... ok! Writing sector 0x17000... ok! Writing sector 0x18000... ok! Writing sector 0x19000... ok! Writing sector 0x1A000... ok! Writing sector 0x1B000... ok! Writing sector 0x1C000... ok! Writing sector 0x1D000... ok! Writing sector 0x1E000... ok! failed with serial.BytesToRead 0 (expected 15)
    The beginning of buffer in UART contains  data.
    Writing sector 0x1F000... Writing sector 126976 failed!
    Rate: 12968
    That's a very unreliable method of flashing. First of all, I would shorten all the wires.
  • #11 21710689
    clasik
    Level 4  
    >>21710618
    Well, I shortened the wires, and I got it to flash, thanks!
    Now, I have connected to AC 220V, but the blue LED light is off, and I can't find any new WiFi :(
    I am starting to think this device is damaged...
  • #12 21712795
    Rate: 12968
    Maybe disconnect 230V, power device from 3.3V again, and check TX2 output of CB2S (115200 baud)
An error occurs when flashing the OpenBK7231N_QIO_1.18.187.bin firmware onto the DS12D-WF CB2S WiFi Curtain Module using BK7231GUIFlashTool-v50. The flashing process initiates correctly, detecting the flash memory chip TH25Q16HB (MID 1560EB) and entering protection states, but fails to complete successfully. The issue is identified as a bug in the BK7231GUIFlashTool version 50. The recommended solution is to upgrade to BK7231GUIFlashTool version 95, which resolves the flashing error.
TL;DR: Flash failures on CB2S with BK7231N were linked to a buggy flasher (v50); updating to v95 and "retry with BK7231GUIFlashTool v95?" resolved writes. Use proper power, short wires, and correct baud. [Elektroda, p.kaczmarek2, post #21710360]
Why it matters: This FAQ helps first‑time BK7231N flashers fix write/verify errors fast on Tuya CB2S curtain modules.
How do I fix BK7231GUIFlashTool v50 write failures on CB2S?
Update the flasher to BK7231GUIFlashTool v95, then retry the same firmware. The maintainer reported a production bug in a recent release and asked users to switch to v95. This change alone cleared write failures for the affected thread. Re‑run the process after power‑cycling via CEN or a brief power off/on. Use a short USB cable and stable COM port settings before attempting again. [Elektroda, p.kaczmarek2, post #21710360]
What baud rate should I use for BK7231N (CB2S) flashing?
Start at 115200 for bus acquisition and writes. If transfers stall, try 230400 only after confirming wiring and power. An example session in the thread shows both 115200 and 230400 during erase/write, and switching speed revealed different errors caused by signal integrity. Keep wires short and ground solid before increasing speed. [Elektroda, clasik, post #21710616]
Why does flashing fail at the last sector with CheckRespond_FlashWrite4K?
This often indicates marginal signal or power integrity near the end of the write window. In the log, the device erased 281 sectors and wrote until 0x128000, then returned a bad 4K write response. Shortening the wires restored reliable writes for the user. Quote: "shorten all the wires." [Elektroda, p.kaczmarek2, post #21710618]
My USB‑to‑UART (CP2102) powers the board—do I still need external 3.3 V?
Yes, provide a known‑good 3.3 V source. The maintainer flagged under‑powering as a common cause of unreliable flashes and requested photos to verify power. Many CP2102 breakout boards cannot supply stable current under SPI writes. Power the module externally and share ground with the adapter. [Elektroda, p.kaczmarek2, post #21710508]
Is it safe to flash while the DS12D‑WF is on 220–230 V AC?
Do not rely on mains during UART flashing. Use isolated 3.3 V, then test. After flashing, one user powered at 220 V but saw no LED or Wi‑Fi, suggesting either configuration or hardware issues unrelated to the flash step. For diagnostics, return to 3.3 V and use UART logs. [Elektroda, clasik, post #21710689]
What does “Getting bus… please reboot by CEN or power off/on” mean?
The flasher waits for the boot ROM to enter UART mode. Briefly pull CEN low (reset) or power‑cycle to grant bus control. The logs show successful bus acquisition after such a reset, followed by MID read and protection handling. Keep the module still during this step to avoid intermittent contacts. [Elektroda, clasik, post #21710016]
How do I handle flash protection and identification on CB2S?
Let the tool read MID 1560EB and set protection to a writable state. The log identifies TH25Q16HB with 2 MB size and shows SetProtectState(True) success before erase. If MID differs, verify wiring and repeat reset. A correct MID ensures the proper command set is used. [Elektroda, clasik, post #21710493]
I see “serial.BytesToRead 0 (expected 15)”—what should I check?
This indicates the PC expected a 15‑byte response but received nothing, usually due to poor wiring or noise. In the thread, the error occurred early (0x1F000) at 230400 baud. Reduce baud, shorten leads, secure ground, and stabilize power before retrying. It’s a transport failure, not a firmware bug. [Elektroda, clasik, post #21710616]
What is OpenBK7231N / OpenBeken in this context?
OpenBK7231N is the OpenBeken build for BK7231N SoCs, distributed as images like OpenBK7231N_QIO_1.18.188.bin. The flasher uses a QIO write path that skips the bootloader region to reduce risk during updates. Select the correct N variant for CB2S modules. [Elektroda, clasik, post #21710493]
How can I verify the device booted after flashing if Wi‑Fi is missing?
Disconnect mains, power from 3.3 V, and capture TX2 at 115200 to read boot logs. The maintainer advised checking TX2 to confirm boot progress when the LED and AP are absent. Serial output quickly reveals configuration or boot failures. Reflash if boot messages are corrupt. [Elektroda, p.kaczmarek2, post #21712795]
Does increasing baud rate always help slow flashes?
No. Higher baud can expose marginal wiring and worsen reliability. In the case discussed, moving to 230400 produced a new error image, and only fixing wiring length restored stability. Quote: "Strange...." but wiring photos were requested to diagnose. Prioritize wiring over speed. [Elektroda, p.kaczmarek2, post #21710589]
What’s the minimal wiring for flashing CB2S via UART?
Connect TX–RX crossed, GND–GND, and provide stable 3.3 V. Momentarily pull CEN to GND to reset into the bootloader. One user initially connected only RX, TX, GND and relied on board power, which led to intermittent failures until wiring and power were corrected. [Elektroda, clasik, post #21710521]
How many sectors get erased during a full image write?
The example logs show an erase starting at 0x11000 with a sector count of 281 on a 2 MB TH25Q16HB. This aligns with a ~1.2 MB payload and reserved regions such as the bootloader. Use the same offsets when verifying region writes. [Elektroda, clasik, post #21710493]
Quick 3‑step: how do I recover a failing flash session?
  1. Update to BK7231GUIFlashTool v95 and power from a stable 3.3 V.
  2. Shorten UART wires; set baud to 115200; reset via CEN.
  3. Reflash; if Wi‑Fi/LED absent, read TX2 logs at 115200. [Elektroda, p.kaczmarek2, post #21710360]
Edge case: Itchiptool works but GUIFlashtool fails—what’s different?
Transport timing and command sequencing differ between tools. A device in the thread flashed successfully with itchiptool when GUIFlashtool faltered, until wiring was improved. If a tool fails late in the write, suspect signal integrity first, not firmware corruption. [Elektroda, clasik, post #21710616]
Should I overwrite the bootloader on BK7231N?
No. The QIO flow shown in the logs explicitly skips the bootloader region. This reduces bricking risk and speeds updates. Use the correct image variant and let the tool manage protected areas and offsets automatically during flashing. [Elektroda, clasik, post #21710493]
