24 bits, how many kHz? I understand that you don't specifically write about it. 900?
jakubprazmowskibox wrote:24bits how many hz? (...) 900?
Pltin74 wrote:you don't understand. 2137hz
tytka wrote:I don't understand what you wrote, because you gave spaces after the " at the beginning of the quoted sentence. This makes the whole text impossible to understand"The Raspberry Pi DAC Pro is based on a Burr Brown PCM5242 32-bit / 384 kHz converter, allows Full HD audio playback 24-bit / 192 kHz"
jakubprazmowskibox wrote:What is the moderator's concern?
