How to View Current Latitude and Longitude Values Set by ntp_setLatLong
150219v8 582 1
  • #1 21784893
    150219v8
    Hi all,
    About ntp_setLatLong in OpenBeken:
    How can I read/view which actual values are set before writing new values?
    Thanks
  • #2 21785932
    Rate: 12945
    I've checked the source code (TIME_SetLatlong) and there is no way currently to check the existing value. Why would you do that? I don't think of any possible use case for that. If you're worried if your command worked, then you can check return result - it will either say OK or "not enough arguments".
