[BL602] [BL602C20] Flash erase fails with Unknown Response using BK7231 Easy UART Flasher
Arak0n 759 3
  • BLDevCube works when Easy UART flasher fails
    #1 21794698
    Arak0n
    I'm trying to flash a BL602C20 (from a basic RGBW controller) with Openbeken.
    It's connected via an USB-Serial adapter and powered by an additional AMS1117-3,3V to ensure stable power supply.
    I can write the bootloader fine, but erasing to write the firmware fails every time. I tried different baud rates, too. Using the BK7231 Easy UART Flasher tool.
    Here's the output:
    Now is: Wednesday, 31 December 2025 13:31:57.
    Flasher mode: BL602
    Going to open port: COM7.
    Port ready!
    Sync attempt 0/1000 ... OK!
    Command fail!
    Flash ID: 5E401580
    Flash size is 2MB
    Eflash loader is already uploaded!
    Writing boot...
    Erasing from 0x0 to 0x10000
    Erase pending...
    Starting flash write 65536
    .0..4092..8184..12276..16368..20460..24552..28644..32736..36828..40920..45012..49104..53196..57288..61380..65472.
    Hash matches 330D7EBF8709EB425BE083DEC50DA987399B363AA7C1E87132B2A629AB05BCC4!
    Done flash write 65536
    Reading firmwares/OpenBL602_1.18.233.bin...
    Erasing from 0x10000 to 0xCE000
    Erase pending...
    Erase pending...
    Erase pending...
    Erase pending...
    Erase pending...
    Unknown response, PUnknown response, DUnknown response, PUnknown response, DUnknown response, PUnknown response, DUnknown response, PUnknown response, DUnknown response, PUnknown response, DUnknown response, PUnknown response, DUnknown response, PUnknown response, DUnknown response, PUnknown response, DUnknown response, PUnknown response, DUnknown response, PUnknown response, DUnknown response, PUnknown response, DUnknown response, PUnknown response, DUnknown response, PUnknown response, DUnknown response, OUnknown response, K
    Any ideas please?
    Edit: Solved... I tried with the BLDevCube app and it worked first try.
  • #4 21794924
    Rate: 12839
    If you can, let us know if the newer release of our flasher works for you.
