[Solved] BL602 SDV-002_V1.2 Flashing Fails: UART Shows Boot, Bouffalo Lab Cant Read Flash ID
lamero345 621 4
  • BL602 boots but Bouffalo Lab cannot read flash ID
    #1 21757443
    lamero345
    BL602 Module SDV-002_V1.2 unable to flash
    I have this product https://it.aliexpress.com/item/1005010017712057.html
    With Bouffalo Lab I can't read flash id as described here: https://www.elektroda.com/news/news4051649.html but i have this logs on UART
    cfg->wifi
    [19:45:06.807] - Starting bl602 now....
    Booting BL602
    [19:45:06.807] - Chip...
    RISC-V Core Feature:RV32-ACFIMX
    Build Version: release_bl_iot_sdk_1.6.34-82-g2d2a86d6b
    Build Date: May 23 2024
    Build Time: 11:27:55
    blog init set power on level 2, 2, 2.
    [IRQ] Clearing and Disable all the pending IRQ...
    [         0][INFO: hal_boot2.c: 303] [HAL] [BOOT2] Active Partition[0] consumed 596 Bytes
    [         0][INFO: hal_boot2.c:  82] ======= PtTable_Config @0x4200e83c=======
    [         0][INFO: hal_boot2.c:  83] magicCode 0x54504642; version 0x0000; entryCnt 6; age 0; crc32 0xD9834983
    [         0][INFO: hal_boot2.c:  89] idx  type device activeIndex     name   Address[0]  Address[1]  Length[0]   Length[1]   age
    [         0][INFO: hal_boot2.c:  91] [00]  00     0         0            FW  0x00010000  0x0013c000  0x0012c000  0x000b4000  0
    [         0][INFO: hal_boot2.c:  91] [01]  02     0         0           mfg  0x0013c000  0x00000000  0x00032000  0x00000000  0
    [         0][INFO: hal_boot2.c:  91] [02]  03     0         0       reserve  0x001f0000  0x00000000  0x00006000  0x00000000  0
    [         0][INFO: hal_boot2.c:  91] [03]  04     0         0           PSM  0x001f6000  0x00000000  0x00004000  0x00000000  0
    [         0][INFO: hal_boot2.c:  91] [04]  05     0         0          DATA  0x001fa000  0x00000000  0x00002000  0x00000000  0
    [         0][INFO: hal_boot2.c:  91] [05]  06     0         0       factory  0x001fc000  0x00000000  0x00004000  0x00000000  0
    [         0][INFO: bl_flash.c: 391] ======= FlashCfg magiccode @0x42049c18=======
    [         0][INFO: bl_flash.c: 392] mid         0xC8
    [         0][INFO: bl_flash.c: 393] clkDelay     0x1
    [         0][INFO: bl_flash.c: 394] clkInvert     0x1
    [         0][INFO: bl_flash.c: 395] sector size    4KBytes
    [         0][INFO: bl_flash.c: 396] page size    256Bytes
    [         0][INFO: bl_flash.c: 397] ---------------------------------------------------------------
    [         0][INFO: hal_board.c:1249] [MAIN] [BOARD] [FLASH] addr from partition is 001fc000, ret is 0
    [         0][INFO: hal_board.c:1261] [MAIN] [BOARD] [XIP] addr from partition is 231eb000, ret is 0
    [         0][INFO: hal_board.c: 208] MAC address mode length 3
    [         0][INFO: hal_board.c: 212] MAC address mode is MBF
    Read slot:0
    [         0][INFO: hal_board.c: 187] Set MAC addrress 7C:3E:82:82:C0:AD
    [         0][INFO: hal_board.c: 955] country_code : 86
    [         0][INFO: hal_board.c: 342] xtal_mode is MF
    Read slot:0
    [         0][INFO: hal_board.c: 374] get xtal from M ready 31 31 1 60 60
    [         0][INFO: hal_board.c: 846] pwr_table_11b :20 20 20 18
    [         0][INFO: hal_board.c: 860] pwr_table_11g :18 18 18 18 18 18 14 14
    [         0][INFO: hal_board.c: 878] pwr_table_11n :18 18 18 18 18 16 14 14
    No written slot found
    [19:45:06.823] - [         0][BUF: hal_board.c: 606]   0   0   0   0   0   0   0   0   0   0   0   0   0   0
    [         0][INFO: hal_board.c: 902] set pwr_table_ble = 13 in dts
    [         0][INFO: hal_board.c: 687] ap_ssid string[0] = bl_test_005, ap_ssid_len = 11
    [         0][INFO: hal_board.c: 698] ap_psk string[0] = 12345678, ap_psk_len = 8
    [         0][INFO: hal_board.c: 707] ap_channel = 11
    [19:45:06.823] -
    [         0][INFO: hal_board.c: 635] [STA] ap_ssid string[0] = yourssid, ap_ssid_len = 8
    [         0][INFO: hal_board.c: 646] [STA] ap_psk string[0] = yourapssword, ap_psk_len = 12
    [         0][INFO: hal_board.c: 654] auto_connect_enable = 1
    [         0][INFO: hal_board.c: 749] Troom_os = -1, lentmp = 4
    [         0][INFO: hal_board.c: 758] linear_or_follow = 1, lentmp = 4
    [         0][INFO: hal_board.c: 767] Tchannels:2412,2427,2442,2457,2472,
    [         0][INFO: hal_board.c: 781] Tchannel_os:180,170,160,140,120,
    [         0][INFO: hal_board.c: 795] Tchannel_os_low:200,190,180,160,130,
    [         0][INFO: hal_board.c: 808] en_tcal = 0, lentmp = 4
    [OS] Starting aos_loop_proc task...
    [OS] Starting OS Scheduler...
    [MTD] >>>>>> Hanlde info Dump >>>>>>
    name PSM
    id 0
    offset 0x001f6000(2056192)
    size 0x00004000(16Kbytes)
    xip_addr 0x231e5000
    [MTD] <<<<<< Hanlde info End <<<<<<
    [EF] Found Valid PSM partition, XIP Addr 231e5000, flash addr 001f6000, size 16384
    ENV AREA SIZE 16384, SECTOR NUM 4
    *default_env_size = 0x00000001
    ENV start address is 0x00000000, size is 16384 bytes.
    [19:45:06.888] - EasyFlash V4.0.99 is initialize success.
    You can get the latest versio
    [19:45:06.888] - n on https://github.com/armink/EasyFlash .
    [        64][INFO: vfs_uart.c: 584] uart[0] rx_buf_size 512, tx_buf_size 512
    [        65][INFO: vfs_uart.c: 599] uart[0] cts status = disable lentmp = 7
    [        66][INFO: vfs_uart.c: 599] uart[0] rts status = disable lentmp = 7
    [        66][INFO: vfs_uart.c: 616] id = 0, tx = 16, rx = 7, cts = 255, rts = 255 baudrate = 2000000.
    [        67][INFO: vfs_uart.c: 531] uart[1] status = disable
    Booting BL602 Chip...
    ############################## system init     ##################################
    Device Info:[Firmware Name:<FWSW-CKBL602-SWITCH-BL602L_v1.2.0>,Build Time:<20240523.112754.589>,Boot Reason:<BL_RST_POWER_OFF>]
    [19:45:07.083] - Reading the dts file...
    And the GPIO config is :
    cfg->wifi_led = 200
    cfg->l
    [19:45:08.309] -  ======= PtTable_Config @0x4200e83c=======
    [19:45:08.312] -  0         0           PSM  0x001f6000  0x00000000  0x00004000  0x00000000  0
    Read slot:0
    Read slot:0
    [19:45:08.335] -
    name PSM
    id 0
    xip_addr 0x231e5000
    [19:45:08.398] - EasyFlash V4.0.99 is initialize success.
    You can get the latest version on https://github.
    [19:45:08.398] - com/armink/EasyFlash .
    [        65][INFO: vfs_uart.c: 584] uart[0] rx_buf_size 512, tx_buf_size 512
    [        66][INFO: vfs_uart.c: 599] uart[0] cts status = disable lentmp = 7
    [        67][INFO: vfs_uart.c: 616] id = 0, tx = 16, rx = 7, cts = 255, rts = 255 baudrate = 2000000.
    [        68][INFO: vfs_uart.c: 531] uart[1] status = disable
    [19:45:08.573] - Reading the dts file...
    cfg->wifi_led = 200
    cfg->led_status = 0
    cfg->led_ch_status = 1
    cfg->backlight_en    = 0
    AI: Can you specify which Bouffalo Lab tool (and version) you are using to flash the BL602, and whether you’re using the command line or GUI? Also, what operating system are you running it on?
    1.9.0
    AI: How do you have the BL602 module connected to your computer for flashing (e.g., which USB-to-UART adapter, wiring details, power supply), and are you using any additional hardware like a reset or boot mode button?
    USB-to-UART adapter
  • Flash ID detected but image creation still fails
    #3 21757521
    lamero345
    [22:05:00.655] - ========= Interface is Uart =========
    [22:05:00.666] - eflash loader bin is eflash_loader_40m.bin
    [22:05:00.666] - ========= chip flash id: ef4015 =========
    [22:05:00.676] - create partition.bin, pt_new is True
    [22:05:00.696] - fw_boot_head_gen xtal: 40M
    [22:05:00.706] - Create bootheader using C:\BouffaloLabDevCube-v1.9.0\chips\bl602\img_create_iot\efuse_bootheader_cfg.ini
    [22:05:00.706] - Updating data according to <C:\BouffaloLabDevCube-v1.9.0\chips\bl602\img_create_iot\efuse_bootheader_cfg.ini[BOOTHEADER_CFG]>
    [22:05:00.706] - Created file len:176
    [22:05:00.719] - Create efuse using C:\BouffaloLabDevCube-v1.9.0\chips\bl602\img_create_iot\efuse_bootheader_cfg.ini
    [22:05:00.719] - Updating data according to <C:\BouffaloLabDevCube-v1.9.0\chips\bl602\img_create_iot\efuse_bootheader_cfg.ini[EFUSE_CFG]>
    [22:05:00.726] - Created file len:128
    [22:05:00.735] - ========= sp image create =========
    [22:05:00.735] - Image hash is b'e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855'
    [22:05:00.735] - Hash ignored
    [22:05:00.746] - Header crc ignored
    [22:05:00.746] - Write flash img
    [22:05:00.746] - Encrypt efuse data
    [22:05:00.756] - fw_boot_head_gen xtal: 40M
    [22:05:00.766] - Create bootheader using C:\BouffaloLabDevCube-v1.9.0\chips\bl602\img_create_iot\efuse_bootheader_cfg.ini
    [22:05:00.769] - Updating data according to <C:\BouffaloLabDevCube-v1.9.0\chips\bl602\img_create_iot\efuse_bootheader_cfg.ini[BOOTHEADER_CFG]>
    [22:05:00.769] - Created file len:176
    [22:05:00.776] - Create efuse using C:\BouffaloLabDevCube-v1.9.0\chips\bl602\img_create_iot\efuse_bootheader_cfg.ini
    [22:05:00.786] - Updating data according to <C:\BouffaloLabDevCube-v1.9.0\chips\bl602\img_create_iot\efuse_bootheader_cfg.ini[EFUSE_CFG]>
    [22:05:00.787] - Created file len:128
    [22:05:00.800] - ========= sp image create =========
    [22:05:00.808] - Image hash is b'83891c0734583b9209e28aeaba717f85657b94747f6c4f2cc1c71e7fd874b4e8'
    [22:05:00.808] - Hash ignored
    [22:05:00.810] - Header crc ignored
    [22:05:00.810] - Write flash img
    [22:05:00.816] - Encrypt efuse data
    [22:05:00.826] - fw_boot_head_gen xtal: 40M
    [22:05:00.836] - Create bootheader using C:\BouffaloLabDevCube-v1.9.0\chips\bl602\img_create_iot\efuse_bootheader_cfg.ini
    [22:05:00.836] - Updating data according to <C:\BouffaloLabDevCube-v1.9.0\chips\bl602\img_create_iot\efuse_bootheader_cfg.ini[BOOTHEADER_CFG]>
    [22:05:00.846] - Created file len:176
    [22:05:00.852] - Create efuse using C:\BouffaloLabDevCube-v1.9.0\chips\bl602\img_create_iot\efuse_bootheader_cfg.ini
    [22:05:00.856] - Updating data according to <C:\BouffaloLabDevCube-v1.9.0\chips\bl602\img_create_iot\efuse_bootheader_cfg.ini[EFUSE_CFG]>
    [22:05:00.856] - Created file len:128
    [22:05:00.876] - ========= sp image create =========
    [22:05:00.887] - Image hash is b'4a80738536970199b4f274cb6054584ded95713bfedc08f3c2a583a4da331d0f'
    [22:05:00.887] - Header crc: b'36340c2a'
    [22:05:00.887] - Write flash img
    [22:05:00.900] - Encrypt efuse data
    [22:05:00.910] - FW Header is 176, 3920 still needed
    [22:05:00.910] - FW OTA bin header is Done. Len is 4096
    [22:05:01.046] - BL60X_OTA_Ver1.0
    [22:05:01.161] - FW OTA bin is Done. Len is 773520
    [22:05:01.746] - OTA XZ file len = 425944
    [22:05:01.746] - Partiton len = 557056
    [22:05:01.746] - BL60X_OTA_Ver1.0
    [22:05:01.852] - FW OTA xz is Done
    [22:05:01.856] - ========= eflash loader config =========
    [22:05:01.858] - Image offset = 8192
    [22:05:01.947] - =========C:/Users/NOTEBOOK/Downloads/BouffaloLabDevCube-v1.9.0/chips/bl602/device_tree/bl_factory_params_IoTKitA_40M.dts ——> C:\BouffaloLabDevCube-v1.9.0\chips\bl602/device_tree/ro_params.dtb=========
    [22:05:02.357] - True
    [22:05:02.366] - Version: eflash_loader_v2.5.1
    [22:05:02.366] - Program Start
    [22:05:02.366] - ========= eflash loader cmd arguments =========
    [22:05:02.371] - Config file: C:\BouffaloLabDevCube-v1.9.0\chips\bl602\eflash_loader/eflash_loader_cfg.ini
    [22:05:02.373] - serial port is COM3
    [22:05:02.373] - cpu_reset=False
    [22:05:02.376] - chiptype: bl602
    [22:05:02.376] - ========= Interface is uart =========
    [22:05:02.376] - com speed: 2000000
    [22:05:02.376] - Eflash load helper file: C:\BouffaloLabDevCube-v1.9.0\chips\bl602\eflash_loader/eflash_loader_40m.bin
    [22:05:02.376] - ========= load eflash_loader.bin =========
    [22:05:02.376] - Load eflash_loader.bin via uart
    [22:05:02.376] - ========= image load =========
    [22:05:02.657] - Not ack OK
    [22:05:02.657] - FL
    [22:05:02.657] - result: FL
    [22:05:02.960] - tx rx and power off, press the machine!
    [22:05:02.960] - cutoff time is 0.1
    [22:05:03.068] - power on tx and rx
    [22:05:03.895] - reset cnt: 0, reset hold: 0.005, shake hand delay: 0.1
    [22:05:03.896] - clean buf
    [22:05:03.916] - send sync
    [22:05:04.150] - ack is 4f4b
    [22:05:04.198] - shake hand success
    [22:05:04.214] - get_boot_info
    [22:05:04.216] - data read is b'010000000000000003000400adc082823e7c1b00'
    [22:05:04.216] - ========= chipid: 7c3e8282c0ad =========
    [22:05:04.216] - last boot info: None
    [22:05:04.216] - sign is 0 encrypt is 0
    [22:05:04.216] - segcnt is 1
    [22:05:04.246] - segdata_len is 38592
    [22:05:04.342] - 4080/38592
    [22:05:04.440] - 8160/38592
    [22:05:04.536] - 12240/38592
    [22:05:04.627] - 16320/38592
    [22:05:04.726] - 20400/38592
    [22:05:04.817] - 24480/38592
    [22:05:04.916] - 28560/38592
    [22:05:05.012] - 32640/38592
    [22:05:05.111] - 36720/38592
    [22:05:05.159] - 38592/38592
    [22:05:05.168] - Run img
    [22:05:05.294] - Load helper bin time cost(ms): 2918.455322265625
    [22:05:05.406] - Flash load shake hand
    [22:05:05.442] - default set DTR high
    [22:05:05.550] - clean buf
    [22:05:05.566] - send sync
    [22:05:05.788] - ack is 4f4b
    [22:05:05.836] - Read mac addr
    [22:05:05.836] - macaddr: adc082823e7c
    [22:05:05.846] - flash set para
    [22:05:05.846] - ========= flash read jedec ID =========
    [22:05:05.856] - Read flash jedec ID
    [22:05:05.856] - flash jedec id: c8401580
    [22:05:05.856] - Finished
    [22:05:05.873] - get flash size: 0x00200000
    [22:05:05.873] - Program operation
    [22:05:05.876] - Dealing Index 0
    [22:05:05.876] - ========= programming C:\BouffaloLabDevCube-v1.9.0\chips\bl602\img_create_iot\whole_img_boot2.bin to 0x00000000
    [22:05:05.883] - ========= flash load =========
    [22:05:05.886] - ========= flash erase =========
    [22:05:05.886] - Erase flash from 0x0 to 0xbabf
    [22:05:05.908] - erase pending
    [22:05:06.016] - erase pending
    [22:05:06.046] - erase pending
    [22:05:06.081] - erase pending
    [22:05:06.108] - erase pending
    [22:05:06.185] - Erase time cost(ms): 299.403076171875
    [22:05:06.196] - decompress write rx timeout: 24.576
    [22:05:06.233] - decompress flash load 24060
    [22:05:06.256] - Load 2048/24060 {"progress":8}
    [22:05:06.266] - Load 4096/24060 {"progress":17}
    [22:05:06.286] - Load 6144/24060 {"progress":25}
    [22:05:06.307] - Load 8192/24060 {"progress":34}
    [22:05:06.316] - Load 10240/24060 {"progress":42}
    [22:05:06.339] - Load 12288/24060 {"progress":51}
    [22:05:06.346] - Load 14336/24060 {"progress":59}
    [22:05:06.366] - Load 16384/24060 {"progress":68}
    [22:05:06.386] - Load 18432/24060 {"progress":76}
    [22:05:06.396] - Load 20480/24060 {"progress":85}
    [22:05:06.419] - Load 22528/24060 {"progress":93}
    [22:05:06.434] - Load 24060/24060 {"progress":100}
    [22:05:06.436] - Load 24060/24060 {"progress":100}
    [22:05:06.436] - Write check
    [22:05:06.456] - Flash load time cost(ms): 259.666748046875
    [22:05:06.456] - Finished
    [22:05:06.456] - Sha caled by host: 2f44f91873a18ff35cf93ab5a35dcde41ab8f075e21af450e904699bdabb0c01
    [22:05:06.456] - xip mode Verify
    [22:05:06.477] - Read Sha256/47808
    [22:05:06.477] - Flash xip readsha time cost(ms): 11.171630859375
    [22:05:06.477] - Finished
    [22:05:06.497] - Sha caled by dev: 2f44f91873a18ff35cf93ab5a35dcde41ab8f075e21af450e904699bdabb0c01
    [22:05:06.497] - Verify success
    [22:05:06.510] - Dealing Index 1
    [22:05:06.510] - ========= programming chips\bl602\partition\partition.bin to 0x0000E000
    [22:05:06.519] - ========= flash load =========
    [22:05:06.519] - ========= flash erase =========
    [22:05:06.526] - Erase flash from 0xe000 to 0xe10f
    [22:05:06.546] - erase pending
    [22:05:06.614] - Erase time cost(ms): 87.970703125
    [22:05:06.636] - Load 272/272 {"progress":100}
    [22:05:06.636] - Write check
    [22:05:06.666] - Flash load time cost(ms): 50.393798828125
    [22:05:06.666] - Finished
    [22:05:06.666] - Sha caled by host: fd6af18fc4aaf2807277cac767ca19d12af7b55f5ecbb8902ef28bc2430524aa
    [22:05:06.666] - xip mode Verify
    [22:05:06.689] - Read Sha256/272
    [22:05:06.689] - Flash xip readsha time cost(ms): 23.200927734375
    [22:05:06.689] - Finished
    [22:05:06.706] - Sha caled by dev: fd6af18fc4aaf2807277cac767ca19d12af7b55f5ecbb8902ef28bc2430524aa
    [22:05:06.706] - Verify success
    [22:05:06.716] - Dealing Index 2
    [22:05:06.716] - ========= programming chips\bl602\partition\partition.bin to 0x0000F000
    [22:05:06.726] - ========= flash load =========
    [22:05:06.728] - ========= flash erase =========
    [22:05:06.728] - Erase flash from 0xf000 to 0xf10f
    [22:05:06.746] - erase pending
    [22:05:06.819] - Erase time cost(ms): 91.318359375
    [22:05:06.826] - Load 272/272 {"progress":100}
    [22:05:06.835] - Load 272/272 {"progress":100}
    [22:05:06.835] - Write check
    [22:05:06.856] - Flash load time cost(ms): 30.302734375
    [22:05:06.856] - Finished
    [22:05:06.856] - Sha caled by host: fd6af18fc4aaf2807277cac767ca19d12af7b55f5ecbb8902ef28bc2430524aa
    [22:05:06.856] - xip mode Verify
    [22:05:06.876] - Read Sha256/272
    [22:05:06.876] - Flash xip readsha time cost(ms): 10.265625
    [22:05:06.883] - Finished
    [22:05:06.896] - Sha caled by dev: fd6af18fc4aaf2807277cac767ca19d12af7b55f5ecbb8902ef28bc2430524aa
    [22:05:06.899] - Verify success
    [22:05:06.911] - Dealing Index 3
    [22:05:06.911] - ========= programming C:\BouffaloLabDevCube-v1.9.0\chips\bl602\img_create_iot\whole_img.bin to 0x00010000
    [22:05:06.916] - ========= flash load =========
    [22:05:06.926] - ========= flash erase =========
    [22:05:06.926] - Erase flash from 0x10000 to 0xccd8f
    [22:05:06.936] - erase pending
    [22:05:07.101] - erase pending
    [22:05:07.264] - erase pending
    [22:05:07.423] - erase pending
    [22:05:07.582] - erase pending
    [22:05:07.740] - erase pending
    [22:05:07.884] - erase pending
    [22:05:08.028] - erase pending
    [22:05:08.204] - erase pending
    [22:05:08.331] - erase pending
    [22:05:08.490] - erase pending
    [22:05:08.616] - erase pending
    [22:05:08.713] - erase pending
    [22:05:08.728] - erase pending
    [22:05:08.761] - erase pending
    [22:05:08.776] - erase pending
    [22:05:08.808] - erase pending
    [22:05:08.855] - Erase time cost(ms): 1929.2763671875
    [22:05:08.866] - decompress write rx timeout: 24.576
    [22:05:09.256] - decompress flash load 425944
    [22:05:09.270] - Load 2048/425944 {"progress":0}
    [22:05:09.286] - Load 4096/425944 {"progress":0}
    [22:05:09.301] - Load 6144/425944 {"progress":1}
    [22:05:09.316] - Load 8192/425944 {"progress":1}
    [22:05:09.332] - Load 10240/425944 {"progress":2}
    [22:05:09.348] - Load 12288/425944 {"progress":2}
    [22:05:09.366] - Load 14336/425944 {"progress":3}
    [22:05:09.383] - Load 16384/425944 {"progress":3}
    [22:05:09.399] - Load 18432/425944 {"progress":4}
    [22:05:09.415] - Load 20480/425944 {"progress":4}
    [22:05:09.431] - Load 22528/425944 {"progress":5}
    [22:05:09.446] - Load 24576/425944 {"progress":5}
    [22:05:09.463] - Load 26624/425944 {"progress":6}
    [22:05:09.476] - Load 28672/425944 {"progress":6}
    [22:05:09.495] - Load 30720/425944 {"progress":7}
    [22:05:09.506] - Load 32768/425944 {"progress":7}
    [22:05:09.526] - Load 34816/425944 {"progress":8}
    [22:05:09.538] - Load 36864/425944 {"progress":8}
    [22:05:09.556] - Load 38912/425944 {"progress":9}
    [22:05:09.569] - Load 40960/425944 {"progress":9}
    [22:05:09.590] - Load 43008/425944 {"progress":10}
    [22:05:09.606] - Load 45056/425944 {"progress":10}
    [22:05:09.619] - Load 47104/425944 {"progress":11}
    [22:05:09.638] - Load 49152/425944 {"progress":11}
    [22:05:09.648] - Load 51200/425944 {"progress":12}
    [22:05:09.667] - Load 53248/425944 {"progress":12}
    [22:05:09.685] - Load 55296/425944 {"progress":12}
    [22:05:09.696] - Load 57344/425944 {"progress":13}
    [22:05:09.716] - Load 59392/425944 {"progress":13}
    [22:05:09.727] - Load 61440/425944 {"progress":14}
    [22:05:09.746] - Load 63488/425944 {"progress":14}
    [22:05:09.759] - Load 65536/425944 {"progress":15}
    [22:05:09.776] - Load 67584/425944 {"progress":15}
    [22:05:09.796] - Load 69632/425944 {"progress":16}
    [22:05:09.806] - Load 71680/425944 {"progress":16}
    [22:05:09.826] - Load 73728/425944 {"progress":17}
    [22:05:09.838] - Load 75776/425944 {"progress":17}
    [22:05:09.856] - Load 77824/425944 {"progress":18}
    [22:05:09.876] - Load 79872/425944 {"progress":18}
    [22:05:09.886] - Load 81920/425944 {"progress":19}
    [22:05:09.906] - Load 83968/425944 {"progress":19}
    [22:05:09.920] - Load 86016/425944 {"progress":20}
    [22:05:09.936] - Load 88064/425944 {"progress":20}
    [22:05:09.956] - Load 90112/425944 {"progress":21}
    [22:05:09.966] - Load 92160/425944 {"progress":21}
    [22:05:09.986] - Load 94208/425944 {"progress":22}
    [22:05:09.998] - Load 96256/425944 {"progress":22}
    [22:05:10.019] - Load 98304/425944 {"progress":23}
    [22:05:10.036] - Load 100352/425944 {"progress":23}
    [22:05:10.046] - Load 102400/425944 {"progress":24}
    [22:05:10.067] - Load 104448/425944 {"progress":24}
    [22:05:10.084] - Load 106496/425944 {"progress":25}
    [22:05:10.096] - Load 108544/425944 {"progress":25}
    [22:05:10.116] - Load 110592/425944 {"progress":25}
    [22:05:10.126] - Load 112640/425944 {"progress":26}
    [22:05:10.146] - Load 114688/425944 {"progress":26}
    [22:05:10.156] - Load 116736/425944 {"progress":27}
    [22:05:10.176] - Load 118784/425944 {"progress":27}
    [22:05:10.197] - Load 120832/425944 {"progress":28}
    [22:05:10.213] - Load 122880/425944 {"progress":28}
    [22:05:10.229] - Load 124928/425944 {"progress":29}
    [22:05:10.239] - Load 126976/425944 {"progress":29}
    [22:05:10.260] - Load 129024/425944 {"progress":30}
    [22:05:10.277] - Load 131072/425944 {"progress":30}
    [22:05:10.293] - Load 133120/425944 {"progress":31}
    [22:05:10.306] - Load 135168/425944 {"progress":31}
    [22:05:10.325] - Load 137216/425944 {"progress":32}
    [22:05:10.341] - Load 139264/425944 {"progress":32}
    [22:05:10.356] - Load 141312/425944 {"progress":33}
    [22:05:10.371] - Load 143360/425944 {"progress":33}
    [22:05:10.386] - Load 145408/425944 {"progress":34}
    [22:05:10.404] - Load 147456/425944 {"progress":34}
    [22:05:10.420] - Load 149504/425944 {"progress":35}
    [22:05:10.436] - Load 151552/425944 {"progress":35}
    [22:05:10.446] - Load 153600/425944 {"progress":36}
    [22:05:10.466] - Load 155648/425944 {"progress":36}
    [22:05:10.478] - Load 157696/425944 {"progress":37}
    [22:05:10.497] - Load 159744/425944 {"progress":37}
    [22:05:10.516] - Load 161792/425944 {"progress":37}
    [22:05:10.532] - Load 163840/425944 {"progress":38}
    [22:05:10.546] - Load 165888/425944 {"progress":38}
    [22:05:10.556] - Load 167936/425944 {"progress":39}
    [22:05:10.577] - Load 169984/425944 {"progress":39}
    [22:05:10.596] - Load 172032/425944 {"progress":40}
    [22:05:10.606] - Load 174080/425944 {"progress":40}
    [22:05:10.626] - Load 176128/425944 {"progress":41}
    [22:05:10.636] - Load 178176/425944 {"progress":41}
    [22:05:10.660] - Load 180224/425944 {"progress":42}
    [22:05:10.668] - Load 182272/425944 {"progress":42}
    [22:05:10.686] - Load 184320/425944 {"progress":43}
    [22:05:10.707] - Load 186368/425944 {"progress":43}
    [22:05:10.720] - Load 188416/425944 {"progress":44}
    [22:05:10.736] - Load 190464/425944 {"progress":44}
    [22:05:10.750] - Load 192512/425944 {"progress":45}
    [22:05:10.766] - Load 194560/425944 {"progress":45}
    [22:05:10.786] - Load 196608/425944 {"progress":46}
    [22:05:10.796] - Load 198656/425944 {"progress":46}
    [22:05:10.816] - Load 200704/425944 {"progress":47}
    [22:05:10.827] - Load 202752/425944 {"progress":47}
    [22:05:10.846] - Load 204800/425944 {"progress":48}
    [22:05:10.866] - Load 206848/425944 {"progress":48}
    [22:05:10.876] - Load 208896/425944 {"progress":49}
    [22:05:10.899] - Load 210944/425944 {"progress":49}
    [22:05:10.907] - Load 212992/425944 {"progress":50}
    [22:05:10.926] - Load 215040/425944 {"progress":50}
    [22:05:10.946] - Load 217088/425944 {"progress":50}
    [22:05:10.956] - Load 219136/425944 {"progress":51}
    [22:05:10.976] - Load 221184/425944 {"progress":51}
    [22:05:10.986] - Load 223232/425944 {"progress":52}
    [22:05:11.006] - Load 225280/425944 {"progress":52}
    [22:05:11.026] - Load 227328/425944 {"progress":53}
    [22:05:11.036] - Load 229376/425944 {"progress":53}
    [22:05:11.059] - Load 231424/425944 {"progress":54}
    [22:05:11.066] - Load 233472/425944 {"progress":54}
    [22:05:11.091] - Load 235520/425944 {"progress":55}
    [22:05:11.106] - Load 237568/425944 {"progress":55}
    [22:05:11.123] - Load 239616/425944 {"progress":56}
    [22:05:11.136] - Load 241664/425944 {"progress":56}
    [22:05:11.146] - Load 243712/425944 {"progress":57}
    [22:05:11.171] - Load 245760/425944 {"progress":57}
    [22:05:11.186] - Load 247808/425944 {"progress":58}
    [22:05:11.196] - Load 249856/425944 {"progress":58}
    [22:05:11.218] - Load 251904/425944 {"progress":59}
    [22:05:11.226] - Load 253952/425944 {"progress":59}
    [22:05:11.246] - Load 256000/425944 {"progress":60}
    [22:05:11.266] - Load 258048/425944 {"progress":60}
    [22:05:11.276] - Load 260096/425944 {"progress":61}
    [22:05:11.296] - Load 262144/425944 {"progress":61}
    [22:05:11.306] - Load 264192/425944 {"progress":62}
    [22:05:11.326] - Load 266240/425944 {"progress":62}
    [22:05:11.346] - Load 268288/425944 {"progress":62}
    [22:05:11.356] - Load 270336/425944 {"progress":63}
    [22:05:11.376] - Load 272384/425944 {"progress":63}
    [22:05:11.386] - Load 274432/425944 {"progress":64}
    [22:05:11.406] - Load 276480/425944 {"progress":64}
    [22:05:11.423] - Load 278528/425944 {"progress":65}
    [22:05:11.436] - Load 280576/425944 {"progress":65}
    [22:05:11.456] - Load 282624/425944 {"progress":66}
    [22:05:11.466] - Load 284672/425944 {"progress":66}
    [22:05:11.486] - Load 286720/425944 {"progress":67}
    [22:05:11.496] - Load 288768/425944 {"progress":67}
    [22:05:11.516] - Load 290816/425944 {"progress":68}
    [22:05:11.536] - Load 292864/425944 {"progress":68}
    [22:05:11.546] - Load 294912/425944 {"progress":69}
    [22:05:11.566] - Load 296960/425944 {"progress":69}
    [22:05:11.576] - Load 299008/425944 {"progress":70}
    [22:05:11.596] - Load 301056/425944 {"progress":70}
    [22:05:11.616] - Load 303104/425944 {"progress":71}
    [22:05:11.626] - Load 305152/425944 {"progress":71}
    [22:05:11.646] - Load 307200/425944 {"progress":72}
    [22:05:11.656] - Load 309248/425944 {"progress":72}
    [22:05:11.676] - Load 311296/425944 {"progress":73}
    [22:05:11.696] - Load 313344/425944 {"progress":73}
    [22:05:11.706] - Load 315392/425944 {"progress":74}
    [22:05:11.726] - Load 317440/425944 {"progress":74}
    [22:05:11.736] - Load 319488/425944 {"progress":75}
    [22:05:11.756] - Load 321536/425944 {"progress":75}
    [22:05:11.776] - Load 323584/425944 {"progress":75}
    [22:05:11.786] - Load 325632/425944 {"progress":76}
    [22:05:11.806] - Load 327680/425944 {"progress":76}
    [22:05:11.823] - Load 329728/425944 {"progress":77}
    [22:05:11.836] - Load 331776/425944 {"progress":77}
    [22:05:11.856] - Load 333824/425944 {"progress":78}
    [22:05:11.869] - Load 335872/425944 {"progress":78}
    [22:05:11.886] - Load 337920/425944 {"progress":79}
    [22:05:11.916] - Load 339968/425944 {"progress":79}
    [22:05:11.936] - Load 342016/425944 {"progress":80}
    [22:05:11.946] - Load 344064/425944 {"progress":80}
    [22:05:11.969] - Load 346112/425944 {"progress":81}
    [22:05:11.985] - Load 348160/425944 {"progress":81}
    [22:05:12.000] - Load 350208/425944 {"progress":82}
    [22:05:12.016] - Load 352256/425944 {"progress":82}
    [22:05:12.032] - Load 354304/425944 {"progress":83}
    [22:05:12.048] - Load 356352/425944 {"progress":83}
    [22:05:12.064] - Load 358400/425944 {"progress":84}
    [22:05:12.080] - Load 360448/425944 {"progress":84}
    [22:05:12.096] - Load 362496/425944 {"progress":85}
    [22:05:12.111] - Load 364544/425944 {"progress":85}
    [22:05:12.127] - Load 366592/425944 {"progress":86}
    [22:05:12.143] - Load 368640/425944 {"progress":86}
    [22:05:12.159] - Load 370688/425944 {"progress":87}
    [22:05:12.176] - Load 372736/425944 {"progress":87}
    [22:05:12.191] - Load 374784/425944 {"progress":87}
    [22:05:12.207] - Load 376832/425944 {"progress":88}
    [22:05:12.223] - Load 378880/425944 {"progress":88}
    [22:05:12.239] - Load 380928/425944 {"progress":89}
    [22:05:12.271] - Load 382976/425944 {"progress":89}
    [22:05:12.286] - Load 385024/425944 {"progress":90}
    [22:05:12.302] - Load 387072/425944 {"progress":90}
    [22:05:12.318] - Load 389120/425944 {"progress":91}
    [22:05:12.336] - Load 391168/425944 {"progress":91}
    [22:05:12.350] - Load 393216/425944 {"progress":92}
    [22:05:12.366] - Load 395264/425944 {"progress":92}
    [22:05:12.381] - Load 397312/425944 {"progress":93}
    [22:05:12.397] - Load 399360/425944 {"progress":93}
    [22:05:12.413] - Load 401408/425944 {"progress":94}
    [22:05:12.429] - Load 403456/425944 {"progress":94}
    [22:05:12.446] - Load 405504/425944 {"progress":95}
    [22:05:12.461] - Load 407552/425944 {"progress":95}
    [22:05:12.476] - Load 409600/425944 {"progress":96}
    [22:05:12.492] - Load 411648/425944 {"progress":96}
    [22:05:12.508] - Load 413696/425944 {"progress":97}
    [22:05:12.526] - Load 415744/425944 {"progress":97}
    [22:05:12.539] - Load 417792/425944 {"progress":98}
    [22:05:12.556] - Load 419840/425944 {"progress":98}
    [22:05:12.571] - Load 421888/425944 {"progress":99}
    [22:05:12.586] - Load 423936/425944 {"progress":99}
    [22:05:12.607] - Load 425944/425944 {"progress":100}
    [22:05:12.607] - Write check
    [22:05:12.633] - Flash load time cost(ms): 3767.531494140625
    [22:05:12.633] - Finished
    [22:05:12.636] - Sha caled by host: 2b96ae55acc6200433270bf0f1b2ace8e9c0230b19d39bf263070862769f67a5
    [22:05:12.636] - xip mode Verify
    [22:05:12.876] - Read Sha256/773520
    [22:05:12.876] - Flash xip readsha time cost(ms): 226.777099609375
    [22:05:12.876] - Finished
    [22:05:12.886] - Sha caled by dev: 2b96ae55acc6200433270bf0f1b2ace8e9c0230b19d39bf263070862769f67a5
    [22:05:12.886] - Verify success
    [22:05:12.906] - Dealing Index 4
    [22:05:12.906] - ========= programming chips\bl602\device_tree\ro_params.dtb to 0x001F8000
    [22:05:12.915] - ========= flash load =========
    [22:05:12.918] - ========= flash erase =========
    [22:05:12.918] - Erase flash from 0x1f8000 to 0x1f975d
    [22:05:12.936] - erase pending
    [22:05:12.956] - erase pending
    [22:05:13.028] - Erase time cost(ms): 110.229736328125
    [22:05:13.036] - decompress write rx timeout: 24.576
    [22:05:13.058] - decompress flash load 1584
    [22:05:13.066] - Load 1584/1584 {"progress":100}
    [22:05:13.066] - Write check
    [22:05:13.094] - Flash load time cost(ms): 57.684814453125
    [22:05:13.096] - Finished
    [22:05:13.096] - Sha caled by host: 2030ce2a98174d1e1bc02905472a5c55ff0df9d7274c49efd787982af2430e58
    [22:05:13.096] - xip mode Verify
    [22:05:13.116] - Read Sha256/5982
    [22:05:13.116] - Flash xip readsha time cost(ms): 20.121337890625
    [22:05:13.116] - Finished
    [22:05:13.126] - Sha caled by dev: 2030ce2a98174d1e1bc02905472a5c55ff0df9d7274c49efd787982af2430e58
    [22:05:13.126] - Verify success
    [22:05:13.142] - Program Finished
    [22:05:13.146] - All time cost(ms): 10780.134521484375
    [22:05:13.376] - close interface
    [22:05:13.376] - [All Success]
    [22:06:32.086] - serial type is general
    [22:06:32.166] - Open COM3 Success
    [22:06:37.759] - Version: eflash_loader_v2.5.1
    [22:06:37.769] - Program Start
    But when i connect VCC and GND I can't see WIFI AP
  • #4 21757628
    insmod
    Help: 168
    Rate: 455
    Check boot log, it may show if there's a problem.
  • #5 21771868
    lamero345
    Reflashed with BouffaloLabDevCube
