[Solved] EWT-63M (ewelink) with BL602: Boot Loop When Adding startDriver BL0942 to Autoexec / Start Command
cloetej 477 1
  • NTP required before starting BL0942 driver
    #1 21821928
    cloetej
    EDIT - I have in the meantime tried "AddEventHandler WifiState 1 startDriver BL0942" as a startup command - thereby trying to load the driver only after a successful wifi connection (i.e. a successful boot). This works to some extent, but the device becomes very unstable and unusable - struggles to connect to Wi-Fi and once connected, reboots as soon as I, for example, refresh the webserver in my browser.
    EDIT 2 - It seems like one have to activate NTP for the BL0942 driver to work. I must have missed it somewhere in the documentation. I found a BTW reference to it in the web app in the tools tab. I then pieced together an autoexec.bat file looking at examples in the forum. This seems to work:
    startDriver NTP
    ntp_timeZoneOfs 2
    ntp_setServer 216.239.35.4
    waitFor NTPState 1
    startDriver BL0942
    SetupEnergyStats 1 60 60
    I will leave this post here and mark it as solved for anyone who struggle with the same in future.
    Hi everyone,
    I did extensive searches and cannot find a forum thread that addresses my problem. Apologies if I missed anything.
    I have an EWT-63M smart breaker (eWeLink) that uses a BL602 IC that links to a BL0942 for power monitoring. I successfully flashed OpenBL602_1.18.249.bin on it and subsequently also OpenBL602_1.18.250_OTA.bin.xz.ota, which is the current firmware.
    I managed to set up the button and LEDs; the relay I will get to. I also defined the RX and TX pins for power monitoring and when I run the command "startDriver BL0942" from the web UI, power monitoring is activated and I get valid readings.
    Whenever I add this command to startup commands or into an autoexec.bat file, the device goes into a boot loop. I have tried adding a 3 s delay and defined the pin roles via the autoexec.bat for in case there is a timing issue, but with no success. (when I run my autoexec.bat via the web app as a script thread, it executes as expected).
    What am I missing?
    Thank you in advance!
    AI: Could you please share the exact contents of your autoexec.bat or the startup commands you’re using, so we can check for any potential issues in the script or command order?
    delay_s 3
    SetPinRole 16 BL0937CF1
    SetPinRole 7 BL0937CF
    delay_ms 500
    startDriver BL0942
    AI: Are there any error messages, logs, or serial output available when the device enters the boot loop? If so, could you provide those details?
    No details available
    #2 21822128
    cloetej
    It seems like one has to activate NTP for the BL0942 driver to work. I must have missed it somewhere in the documentation. I found a BTW reference to it in the web app's Tools tab. I then pieced together an autoexec.bat file by looking at examples in the forum. This seems to work:
    startDriver NTP
    ntp_timeZoneOfs 2
    waitFor NTPState 1
    startDriver BL0942
