OpenBeken BK7231N + BL0942 MQTT Sensor Availability in Home Assistant, Missing avty_t
avgapon 1014 10
Why do my OpenBeken MQTT Home Assistant energy sensors not include `avty_t` in discovery, while the switch entity does, and how can I fix sensor availability?
This is a regression: after commit `d491a71`, `avty_t` became effectively disabled for sensors, so Home Assistant discovery no longer publishes availability for energy-related sensors even though the switch still has it [#21822138] The proposed fix is to check only `!flagavty` instead of `!isSensor && !flagavty`, because the current logic suppresses availability for all sensors regardless of the flag [#21822147] A PR with that change was later tested, and after running “Start Home Assistant Discovery” the sensors again had `"avty_t": "~/connected"` [#21834493] If you need to disable availability for special cases like deep-sleep devices, that can still be controlled with the flag instead of being forced off for every sensor [#21880779]
  • Energy sensors missing avty_t in discovery payloads
    #1 21821590
    avgapon
    Hi. I am totally new here, so maybe I am asking something obvious or silly. My apologies if that's the case.
    I've just reflashed a pretty generic Tuya smart plug based on BK7231N (T34, actually) + BL0942 to the latest OpenBeken firmware that has been downloaded by the GUI flasher (1.18.249).
    Everything went very well, everything works.
    Home Asssistant has auto-discovered the device and it was also perfect.
    Then, I pulled the plug from the wall socket and that's when I got a bit puzzled.
    Home Assistant shows the switch entity of the device as unavailable, but for all power sensors it keeps showing the last reported value.
    I checked with MQTT explorer and I think that the issue may be related to availability topic ("avty_t") in the discovery messages.
    I see relevant topics under homeassistant/switch (there's just one, homeassistant/switch/XXX_relay_1/config) and under homeassistant/sensor (there are several of them).
    The topic under "switch/" has a message with JSON payload that has
    field in it.
    But messages in the topics under "sensor/" do not have that field in their payloads.
    I guess that's why Home Assistant does not know / care about availability of those sensors.
    I wonder if I configured something wrong or if I haven't configured something that I should have.
    AI: Could you please share whether you customized any MQTT or discovery settings in OpenBeken, or are you using the default configuration?
    Almost default configuration.
    In Flags I have only flag 2 set.
    I also have a startup command:
    backlog startDriver NTP; ntp_setServer 192.168.0.1; ntp_timeZoneOfs +3; SetupEnergyStats 1 60 5;
    AI: Which versions of Home Assistant and your MQTT broker are you currently using?
    mosquitto-2.0.22
    HASS 2026.1.2
    Added after 31 [minutes]:
    Another observation is that discovery messages for "internal sensors" (like chip temperature, RSSI, etc) do have avty_t in them.
    Only energy related sensors don't have it.
    Makes me wonder if maybe SetupEnergyStats could be responsible for that.
  • Regression disables avty_t for all sensors
    #2 21822138
    avgapon
    I think that the effect could be a regression from https://github.com/openshwprojects/OpenBK7231...mmit/d491a71a938135f92a7dc3f838e8f983e7101de7
    commit d491a71a938135f92a7dc3f838e8f983e7101de7 (tag: 1.17.673)
    Author: Tester23 <openshwprojects@gmail.com>
    Date:   Thu Sep 5 18:19:26 2024 +0200
        made avty disable global
    If I read the intent correctly, it was to make flag 35 apply to all kinds of "entities", not only those considered as sensors (isSensor variable in hass_init_device_info).
    But after the change, "avty_t" is always disabled for sensors, regardless of the flag.
    I do not think that it was the intent?
  • #3 21822144
    Rate: 12913
    Interesting, if so, it's a bug. If you have a fix, please submit, if not, I'll check it with self test soon. I am not yet certain it's the case.
  • #4 21822147
    avgapon
    >>21822144
    I don't have a formal fix, but I think that it should be to check only `!flagavty` instead of `!isSensor && !flagavty` as the code does now.
    I can open an issue or a PR if that would be better.
  • #5 21834377
    Rate: 12913
  • #6 21834493
    avgapon
    >>21834377 >>21834377
    Yes, I did it to get a free firmware build :-) and to expose the proposed change properly.
    I've just tested the new firmware, and after doing "Start Home Assistant Discovery", I now see "avty_t": "~/connected" for all sensors where I expected it to be.
  • Fixing isSensor handling for frequency and timestamp sensors
    #7 21880556
    Help: 449
    Rate: 918
    this PR is good to merge?
    Added after 1 [hours] 40 [minutes]:
    additionally, is it true that these are not treated as
    isSensor
    FREQUENCY_SENSOR
    ILLUMINANCE_SENSOR
    TIMESTAMP_SENSOR
    this
    Code: C / C++
    should be this?
    Code: C / C++
  • #8 21880685
    Rate: 12913
    This pr is awaiting external confirmation whether it's correct or not. I was not sure myself. Can you vouch we can merge it?
  • Global availability flag regression in sensor publishing
    #9 21880710
    Help: 449
    Rate: 918
    Not from experience but only through AI analysis, which said:
  • #10 21880779
    Rate: 12913
    My concern is that we might have wanted to disable avty for sensors like device which report once and then go to deep sleep, but okay, in worst case, you can u this flag to disable it there...
  • #11 21880780
    Help: 449
    Rate: 918
    ah OK sure. interesting. well, I dunno.
    there is this in code to suppress availability for those kinds of devices
    Code: C / C++
    The regression from d491a71 looks to have made all sensors lose avty_t regardless of the global flag
A Tuya smart plug based on BK7231N/T34 and BL0942 was reflashed with OpenBeken and auto-discovered in Home Assistant, but after unplugging it the switch entity became unavailable while power sensors kept their last values. The issue was traced to MQTT discovery availability topic handling (`avty_t`), likely caused by a regression in commit d491a71 that changed availability logic to be global. A PR was proposed and tested, restoring `avty_t: ~/connected` for sensors after rediscovering the device. The discussion also examined whether frequency, illuminance, timestamp, and voltage sensor types should be treated as sensors for availability handling, and noted special suppression logic for deep-sleep style devices such as DoorSensor and tmSensor.
