BK3431Q Program Mode Entry: Pinout, UART Boot Commands, and SPI Flash Dump Methods
apubadulake 669 0
  • BK3431Q program mode entry methods needed
    #1 21821576
    apubadulake
    Hi everyone,
    I'm currently working with a Beken BK3431Q chip and I'm having some trouble entering Program Mode to dump the flash memory.
    On the standard BK3431, there is usually a specific pin to trigger the bootloader/program mode, but I cannot find an equivalent hardware trigger for the Q variant.
    Current Status:
    UART: I can successfully connect to the UART console, but it seems to be locked in Debug Mode. I can see logs, but I cannot execute commands to dump flash or interact with the bootloader.
    SPI: I’ve attempted to access the chip via SPI using pins P00 (SCK), P01 (CSN), P02 (MOSI), and P03 (MISO) [Note: Verify if you meant these or the P04-P07 you mentioned], but as a beginner in SPI interfacing, I haven't had any luck getting a response.
    My Questions:
    Does the BK3431Q require a specific high/low voltage on a certain pin during power-on to enter Program Mode (similar to the ESP32's GPIO0)?
    Is there a specific "magic key" or command sent via UART at boot time to interrupt the boot process?
    For SPI access, is there a recommended tool or script (like flashrom or a specific Beken Programmer tool) that works specifically for this revision?
    Any guidance, datasheets, or pinout tips would be greatly appreciated!
    Thanks in advance!
