TH01 Sensor with OpenBeken: Forcing TuyaMCU to update Every 30 Seconds
patentjyp 657 3
  • Forcing TuyaMCU state updates every 30 seconds
    #1 21834649
    patentjyp
    I have temp & humidity sensor TH01 flashed with Openbeken.
    TH01 is the same as in the link below.
    https://www.elektroda.com/rtvforum/topic3968377.html
    It reports temperature, humidity and battery without any problem.
    I connected TH01 to DC 3.3V source without battery so it is constantly on. I remove the transistor that turns on and off CB3S module and connected GND of CB3S module to GND of 3.3V DC source.
    I want force TuyaMCU to update temperature and humidity every 30 seconds. How do i do this?
    I tried
    addRepeatingEvent 30 -1 tuyaMcu_sendQueryState
    but it does not work.
    Before flashing TH01, I sniffed UART (with original Tuya firmware) and I obtained the log below.
    I am not sure the log below will help but just in case...
    Sent by WiFi module:
    55 AA 00 01 00 00 00
    HEADER VER=00 Product LEN CHK
    Received by WiFi module:
    55 AA 00 01 00 24 7B2270223A226C66333679356E7762386A6B78776767222C2276223A22312E302E30227D 99
    HEADER VER=00 Product LEN {"p":"lf36y5nwb8jkxwgg","v":"1.0.0"} CHK
    55 AA 00 02 00 01 03 05
    HEADER VER=00 McuConf LEN 03 CHK
    55 AA 00 02 00 00 01
    HEADER VER=00 McuConf LEN CHK
    55 AA 00 02 00 01 04 06
    HEADER VER=00 McuConf LEN 04 CHK
    55 AA 00 08 00 0F 00010101010101010200040000010D 31
    HEADER VER=00 QueryInitStatus LEN INVALID date dpId=1 Val V=269 CHK
    55 AA 00 08 00 0F 000101010101010202000400000017 3B
    HEADER VER=00 QueryInitStatus LEN INVALID date dpId=2 Val V=23 CHK
    55 AA 00 08 00 01 00 08
    HEADER VER=00 QueryInitStatus LEN INVALID date CHK
    55 AA 00 08 00 0C 000303030303030304000102 2F
    HEADER VER=00 QueryInitStatus LEN INVALID date dpId=3 Enum V=2 CHK
    55 AA 00 10 00 02 0109 1B
    HEADER VER=00 ObtainDPcache LEN CHK
    55 AA 00 10 00 02 0100 12
    55 AA 00 08 00 0F 000101010101010102000400000139 5D
    HEADER VER=00 QueryInitStatus LEN INVALID date dpId=1 Val V=313 CHK
    55 AA 00 08 00 0F 000101010101010202000400000032 56
    HEADER VER=00 QueryInitStatus LEN INVALID date dpId=2 Val V=50 CHK
  • Direct sensor wiring needed for constant WiFi power
    #2 21835733
    Rate: 12855
    My first question would be do you get any readings at all now?
    From what I remember, the TuyaMCU battery powered driver works in such a way that MCU turns on the WiFi module, and WiFI module sends request to the MCU. If you power WIFI module constantly, then it won't know when to send packet to the MCU, so it wont have a transaction, so it won't get temperature at all.
    Please confirm, are you getting any readings when powering WiFI module constantly?
    I think the correct solution here is to remove the MCU from the board and connect the sensor directly to WiFi chip.
  • #3 21840885
    patentjyp
    >>21835733
    You are correct. No reading at all.
    I removed Tuya MCU and directly connected CHT8310 to CB3S via I2C.
  • #4 21840974
    Rate: 12855
    Is it working now? How many bridges did you had to make, can you show a photo to help other users?
