WB3S ltchiptool v4.13.0 Flash Read Fails at 0x0 via FTDI on Windows 10 Pro
qscented 483 1
  • FTDI wiring and ltchiptool version confirmed
    #1 21842239
    qscented
    @ElektrodaBot
    WB3S ltchiptool read flash error: Reading failure @ 0x0 (No response received) @ElektrodaBot
    AI: How do you have the WB3S module connected to your computer (e.g., which interface, wiring details, power supply)?
    Programmer FTDI to USB computer with Windows 10. Wiring Rx1 module WB3S to TX programmer, TX1 to RX programmer. Power supply with USB and AMS1117 3.3 V. No problems and works well with CBU module.
    AI: Which version of ltchiptool and operating system are you using?
    Version of ltchiptool - v4.13.0. Operating system Microsoft Windows 10 Pro.
  • CEN timing and UART contention likely blocking download mode
    #2 21842258
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    qscented wrote:
    @ElektrodaBot
    WB3S ltchiptool read flash error Reading failure @ 0x0 (No response received) @ElektrodaBot
    AI: How do you have the WB3S module connected to your computer (e.g., which interface, wir...
    Initial assessment of available information
    - Host: Windows 10 Pro, ltchiptool v4.13.0.
    - Interface: FTDI USB–UART, wiring RX1↔TX, TX1↔RX, external 3.3 V from AMS1117.
    - Symptom: ltchiptool “Reading failure @ 0x0 (No response received)” on WB3S, while the same setup works with a CBU module.
    Interpretation: The failure at 0x0 means the tool never established a valid download-mode session with the Beken chip on WB3S. Because your CBU works, the PC/driver/cable are probably fine; this points to reset/boot timing, line contention on UART, I/O level mismatch, or power integrity specific to the WB3S target.
    Note on silicon: Tuya WB3S modules typically carry BK7231T or BK7231N. Some third‑party dev boards marketed as “WB3S” exist with BK7238, but Tuya’s WB3S used in appliances is BK7231T/N. Keep that in mind when you select the chip in ltchiptool.
    Direct answer to the question
    Most often this error is fixed by:
    1) Ensuring the module truly enters download mode (reset timing on CEN).
    2) Eliminating any in‑circuit device that is driving RX1/TX1 (TuyaMCU/MCU/level shifters).
    3) Verifying 3.3 V I/O levels on the FTDI side and stable 3.3 V power at the module.
    4) Issuing the connect/read immediately around a CEN low–high pulse, with a conservative baud (115200) and verbose logging.
    Detailed problem analysis
    1) Entering download mode reliably (CEN handling and timing)
    - CEN is “chip enable” (active low reset). The downloader is most responsive if you:
    - Hold CEN low.
    - Click Start (or run the CLI command).
    - Release CEN to high within ~0.5 s so the ROM/bootloader sees the handshake.
    - Alternative: Click Start first, then briefly pull CEN low for ~100–300 ms and release while ltchiptool shows “Connecting…”.
    - If your FTDI exposes DTR/RTS, you can add a simple auto‑reset:
    - DTR → 100 nF capacitor → CEN, with a 10 kΩ pull‑up from CEN to 3.3 V. This lets the tool’s DTR toggle generate a clean reset pulse.
    2) UART line contention (very common in‑circuit)
    - If WB3S is still soldered on its original PCB, RX1/TX1 are frequently connected to a secondary MCU (often called “TuyaMCU” on smart devices) or other circuitry (e.g., button matrices, transistor drivers).
    - Any device pulling RX1 low or actively transmitting will prevent the downloader from autobauding.
    - Remedies, in order of intrusiveness:
    - Power only the WB3S at 3.3 V and keep the rest of the board unpowered.
    - Hold the external MCU in reset (if its reset pin is accessible).
    - Temporarily lift the RX1/TX1 pins from the module pad side, or cut/rebridge the RX trace later.
    - Best: Desolder the module and program it off‑board.
    3) Voltage and I/O level integrity
    - Power rail:
    - AMS1117 requires proper input/output capacitors (typ. ≥10 µF on OUT and IN). Add 100 nF close to the WB3S VCC–GND pins and a 47–220 µF bulk cap on the 3.3 V rail.
    - Keep programming wires short (<15–20 cm). Ground must be common and low impedance.
    - Watch for “double powering”: do not tie the FTDI’s 3.3 V output to your AMS1117 3.3 V at the same time. Power from one source only.
    - I/O levels:
    - Many FTDI breakouts default to 5 V I/O even if you don’t use their 5 V pin. Ensure VCCIO (or logic level jumper) is set to 3.3 V. A 5 V TX from FTDI can hold the BK’s RX in an invalid state or damage it.
    - Idle level check: with a multimeter or scope, WB3S RX1 should sit at ~3.3 V idle; if it’s near 0 V or being periodically driven, you have contention.
    4) Baud rate and tool options
    - Start conservative at 115200 baud; increase only after a successful link.
    - Use verbose logging to see at which phase it fails:
    - ltchiptool -vv link-info -d COMx
    - If link-info works, try a small read first:
    - ltchiptool -vv flash read -d COMx -b 115200 -l 4096 boot.bin
    - Then a full dump:
    - ltchiptool -vv flash read -d COMx -b 115200 full.bin
    - If detection is flaky, explicitly try both chip IDs:
    - --chip bk7231n
    - --chip bk7231t
    This only affects protocol nuances and prints; it won’t brick anything during read.
    5) Windows/driver specifics
    - Ensure the genuine FTDI VCP driver is installed. In Device Manager:
    - Advanced port settings: set Latency Timer = 1 ms; disable “Serial Enumerator” if present.
    - Close all serial terminals (Arduino IDE/Putty) before using ltchiptool.
    - Try another USB port (preferably direct to the motherboard) and a short, good‑quality USB cable.
    6) Adapter and cabling
    - FTDI clones can be marginal with the Beken autobaud sequence. If available, try a second adapter (CP2102/CP2104 or CH340 at 3.3 V I/O) and keep wires short and twisted GND with RX/TX if possible.
    7) Edge cases
    - BK7231T with a corrupted/erased bootloader (rare unless previously misflashed) may not enter download mode at all. In that case only a SWD/JTAG‑style recovery (not exposed on WB3S) or chip replacement helps. If you’ve never flashed this module before, this is unlikely.
    - Read protection: if you do connect but reads fail mid‑way with permission errors, some firmwares enable protection. Do not issue a chip erase unless you’re prepared to lose the original image.
    Current information and trends
    - Recent ltchiptool builds are much better at autobaud and reset handling but still sensitive to timing on some boards. A quick A/B with one earlier v4.x build (or the portable CLI) is a useful sanity check if everything else looks good.
    - Community experience shows in‑circuit contention and 5 V I/O are the top two causes when “works with module A, fails with WB3S”.
    Supporting explanations and details
    - Why timing matters: the downloader waits for a specific sync pattern right after reset. If your CEN pulse doesn’t align with the tool’s sync bytes, the chip boots the application instead and ignores the flasher.
    - Why contention matters: even a weak pull‑down or a chatty TuyaMCU on RX1 alters the autobaud measurement and the first command frame checksum, yielding “no response”.
    Practical guidelines (do this now)
    - Minimal reproducible test off‑board:
    - Connections: 3.3 V, GND, RX1↔TX, TX1↔RX, CEN accessible.
    - Caps: 100 nF + 47–220 µF across VCC–GND near the module.
    - Command sequence (example COM5):
    - ltchiptool -vv link-info -d COM5 -b 115200
    - While it says “Connecting…”, pull CEN to GND for ~200 ms and release.
    - If link-info succeeds, run the 4 kB read, then full read.
    - If still “no response”, swap the USB–UART adapter and repeat.
    Possible disclaimers or additional notes
    - Do not connect any 5 V signals to the WB3S. If your FTDI board has a 5 V/3.3 V jumper, set it to 3.3 V so VCCIO is correct.
    - Avoid issuing “Erase” until you have a confirmed link and a dumped backup.
    Suggestions for further research
    - Search for “LibreTiny BK7231 download mode CEN timing” and “WB3S UART1 pinout Tuya” for schematics/pin notes if you need board‑level confirmation.
    - If you discover the module is BK7231T and its bootloader is gone, look up community notes on external programmer/SWD recovery or consider module replacement.
    Brief summary
    Your setup is close; the typical blockers are reset timing (CEN), UART contention from the target board, or I/O/power integrity. Isolate the module or at least isolate RX1/TX1, ensure 3.3 V I/O and solid 3.3 V power with local decoupling, and trigger CEN during the ltchiptool connect at 115200 with verbose logs.
    Questions for the user
    - Is the WB3S still on its original PCB? If yes, what device is it from, and can you hold the other MCU in reset or disconnect its UART lines?
    - Can you confirm your FTDI adapter’s logic level is 3.3 V (VCCIO jumper or measured idle TX ~3.3 V)?
    - What is the exact behavior of CEN during your attempts (measured voltage and pulse timing)?
    - Please share the output of:
    - ltchiptool -vv link-info -d COMx -b 115200
    - Do you have a second USB–UART adapter to try?
