[OpenBeken] How to get device full name or short name in a script?
Tilator 111 1
  • #1 21933381
    Tilator
    Rate: 13
    @ElektrodaBot How do I get OpenBeken device full name or short name in a script?
  • No built-in script variable for device names
    #2 21933384
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 362
    Rate: 950
    Direct answer
    In the normal OpenBeken command script / autoexec.bat script, there is currently no documented built-in script variable such as:
    Code: text
    So you cannot reliably do:
    Code: text
    and expect OpenBeken to expand it.
    OpenBeken internally does have both names:
    - Full / long device name: returned in C by
    CFG_GetDeviceName()
    - Short device name: returned in C by
    CFG_GetShortDeviceName()
    The source shows these functions returning
    g_cfg.longDeviceName
    and
    g_cfg.shortDeviceName
    respectively. (github.com)
    What you can do
    1. To set the names
    Use the normal OBK commands:
    Code: text
    The command list documents
    FriendlyName
    as setting the full name, and
    ShortName
    as setting the short name; the short name is used for MQTT topics. (github.com)
    2. To use the device short name in MQTT publishing
    Usually you do not need to manually read the short name when publishing from the same device. OBK automatically prefixes non-raw MQTT publishes with the device topic/name. The documented
    publish
    command example shows that the final topic is built as:
    Code: text
    unless you pass raw mode as the third argument. (github.com)
    Example:
    Code: text
    will publish under this device’s own OBK MQTT prefix.
    If you want to publish to an absolute/raw topic, use:
    Code: text
    3. In Berry scripting
    Berry can read OBK legacy variables with:
    but the current generated constants list does not include a short-name or full-name variable; it lists variables such as
    $CHn
    $voltage
    $current
    $hour
    $uptime
    , etc. (github.com) The Berry tutorial also shows
    getVar("$voltage")
    getVar("$current")
    , and
    getVar("$power")
    , but not a device-name variable. (elektroda.com)
    So this will probably not work unless your firmware build has been modified:
    Practical workaround
    For now, if you need the name inside a script, define it yourself:
    Legacy OBK script
    Code: text
    Berry
    If you are modifying firmware
    The clean firmware-side solution would be to expose two new script constants, for example:
    Code: text
    mapped internally to:
    Code: text
    The relevant C getters already exist in
    new_cfg.c
    , so this is mainly a tokenizer/constants exposure issue, not a missing configuration feature. (github.com)
    Summary
    ShortName ...
    and
    FriendlyName ...
    set the names.
    - OBK internally has
    and
    CFG_GetDeviceName()
    - The current documented script constants do not expose those names.
    - In normal scripts, use a hardcoded label or rely on
    publish
    auto-prefixing.
    - For a proper dynamic script variable, firmware support would need to be added.
