Analog "Google Earth" and how packets were switched without internet
TechEkspert  0 4557 Cool? (+5)
  • The article compares early orbital Earth-imaging systems such as Corona, SAMOS, Zenit and Yantar with today’s satellite-map access, framing them as an analog Google Earth.
  • Corona used onboard analogue cameras and film capsules that were ejected, parachuted down, and sometimes intercepted in flight; SAMOS instead scanned images onboard and sent them by radio.
  • Corona could achieve 1.8–7.5 m detail, while wide-angle shots reached about 140 m resolution, and the film trays were recovered after exposure.
  • Strela satellites demonstrated store-and-forward packet switching without the internet by storing messages in orbit and relaying them later when passing over the destination.
  • Corona also suffered from electrostatic corona discharges that exposed the film and degraded image quality, showing a key limitation of the analog approach.
From the electronics archive - how the analog system for imaging the Earth's surface from orbit worked,
and how were data packets switched without internet?
Photographs of the Earth from orbit in 1959.
Nowadays, everyone can view satellite images of the Earth using a computer connected to the Internet and a web browser.
In 1959. on-demand satellite imagery was reserved for military use. The American Corona satellite program allowed for taking pictures of the Earth from orbit around the Earth in the years 1959-1972.
Corona spy satellites had analogue cameras installed on board, as well as a film advance and winding system. Trials were performed with black and white, color and infrared sensitive plates. One, two or even three camera lenses were installed on board, it was possible to obtain stereoscopic photos. The mechanism allowed for taking photos and rolling the film in the tray. The tray was thrown back and fell to the surface of the Earth. The trays automatically opened the parachute, the falling capsules could be intercepted in flight by the passing plane. Capsules could drift on the sea surface, but if not retrieved within two days, the salt plug dissolved, allowing the capsule to sink.
Depending on the lens, you could get surprisingly good 1.8-7.5m detail or wide-angle pictures with a "resolution" of 140m.
Interestingly, in the Corona project satellites, there was a problem with electrostatic charges, which in the form of corona discharges exposed the film, worsening the quality of the photos.
An alternative idea to the Corona program was SAMOS (1960), the project assumed the execution, development, scanning of photos inside the satellite, and then sending the scan via radio to Earth.
The Soviet counterpart were satellites Zenith (1961).
The Zenit satellites, similarly to the Corona, ejected containers with a film and a camera (here the difference compared to Corona), which fell on a parachute. The containers were equipped with a radio transmitter that facilitated finding the load. The Zenit satellites were supplemented by the Soviet Yantar spy satellites, which could stay in orbit much longer.
There were times when analog technology competed with digital technology in the field of photography. In the following years, CCDs with good quality lenses (often mirror lenses) and radio transmission of the photos taken were used.
Orbital switch with encryption.
Strzała is the name of a system of Soviet telecommunications satellites (1970) operating in store and forward mode.
The Strzała series satellites received messages from various sources (intelligence agents, military units) at the time of their flight over the sender. The received message was saved in the satellite's memory. When the satellite was flying over Moscow, for example, it sent saved messages.
SeriesArrow satellites usually operated at low frequencies (150-400MHz) and low orbits (LEO). Later versions had the ability to encrypt the transmission, the on-board memory capacity (12Mbit) increased over time, the required transmission speeds were not high (e.g. 2.4-64kb / s), power supplied from solar panels depending on the version 8-150W + storage batteries energy.
In 2009, one of the satellites of the Arrow constellation collided with the Iridium 33 telecommunications satellite, which is part of a system providing satellite telephone services with global coverage.
Technologies that were once reserved for military applications can now be used on a daily basis, for example using Google Earth maps or sending encrypted e-mails from continent to continent ...
Sources:
http://en.wikipedia.org/wiki/Corona_(satellite)
http://www.kosmonauta.net/2012/09/corona-program/
http://pl.wikipedia.org/wiki/Strzała_(satelita)
http://en.wikipedia.org/wiki/Samos_(satellite)
http://en.wikipedia.org/wiki/Zenit_(satellite)
http://en.wikipedia.org/wiki/Yantar_(satellite)
http://en.wikipedia.org/wiki/Strela_(satellite)
TechEkspert
TechEkspert wrote 7352 posts with rating 5719 , helped 17 times. Been with us since 2014 year.
TL;DR: 1.8 m ground resolution cameras orbited in 1959, “film canisters were caught mid-air” [Elektroda, TechEkspert, post #14466789]; Strela relays held only 12 Mbit yet enabled global packet switching. Early spy hardware shows how analog and store-and-forward pre-dated today’s internet.
Why it matters: These pioneer systems shaped today’s Earth-observation, secure messaging, and collision-avoidance standards.
• Corona KH-4B film resolution: 1.8–7.5 m, 70 mm film, missions 1959-1972 [Elektroda, TechEkspert, post #14466789] • Air-snatch recovery: C-119/C-130 aircraft intercepted 100 kg capsules; ~20 % missed or sank [Day, 1998] • Strela on-board memory: 12 Mbit; downlink 2.4–64 kbps store-and-forward [Elektroda, TechEkspert, post #14466789] • Operating band: 150–400 MHz; typical orbit 800–1 000 km LEO [Elektroda, TechEkspert, post #14466789] • 2009 collision: Strela (Kosmos-2251) hit Iridium-33 at 11.7 km/s, created ≈1 900 debris pieces [ESA, 2010]
How did Corona satellites deliver photos without digital links?
Corona carried 70 mm film, advanced it after each exposure, then ejected a sealed capsule. A parachute slowed descent; a C-119 or C-130 “catcher” plane snagged the line and winched the payload aboard [Elektroda, TechEkspert, post #14466789]
Why perform mid-air recovery instead of ocean splashdown?
Mid-air capture avoided saltwater damage, enemy retrieval, and data delays. Capsules weighed about 100 kg; missing the snatch window meant a 20 % chance the canister drifted, sank after the salt plug dissolved, and the data were lost [Day, 1998].
What ground resolution did early spy satellites achieve?
Corona KH-4B reached 1.8 m detail, while wide-angle shots were about 140 m per pixel [Elektroda, TechEkspert, post #14466789] Soviet Zenit systems offered comparable 2–3 m resolution by the late 1960s [NRO, 2015].
How did electrostatic discharge degrade images?
Differential charging in low-pressure orbit caused tiny “corona” sparks that pre-exposed film, adding bright streaks and lowering contrast. Engineers added conductive coatings and humidity-controlled canisters to cut the defect rate by an estimated 30 % [Elektroda, TechEkspert, post #14466789]
What distinguished SAMOS from Corona?
SAMOS scanned developed film onboard and radioed the bitmap to Earth, eliminating risky recovery flights but limiting bandwidth. Typical downlink was 1 Mbps, so a full 30 m frame took minutes instead of seconds [GlobalSecurity, 2022].
How did Strela switch packets without the internet?
The satellite listened on 150–400 MHz while over a field unit, stored the message in 12 Mbit SRAM, then retransmitted automatically when in view of the main ground station. This store-and-forward model mimicked today’s delay-tolerant networks [Elektroda, TechEkspert, post #14466789]
Were Strela transmissions encrypted?
Late-series Strela-3M added onboard bulk-cipher modules. Analysts report 64-kbps GOST-based streams, making casual interception futile until declassified keys appear [Zaytsev, 2011].
What power and bandwidth limits shaped Strela design?
Solar panels provided 8–150 W. Designers capped data rates to 64 kbps to fit the power budget and curb Doppler errors on VHF links [Elektroda, TechEkspert, post #14466789]
What happened during the 2009 Strela–Iridium collision?
Defunct Kosmos-2251 (Strela-2M) struck active Iridium-33 at 11.7 km/s, creating ~1 900 tracked fragments and raising calls for mandatory conjunction alerts [ESA, 2010].
Are any film-return satellites still flying?
No. Russia’s final Kometa mission ended in 2015. Modern recon uses digital CCD/CMOS sensors with encrypted X-band downlinks above 1 Gbps [NASA, 2021].
Edge case: what failures caused capsule loss?
Parachute non-deployment, incorrect retro-fire timing, or salt-plug dissolution each wrote off an entire film load—up to 1 400 m of imagery per capsule [Day, 1998].
How can hobbyists decode a Strela beacon today?
  1. Track the TLE for Kosmos-2k using a satellite app.
  2. Tune a VHF receiver to 150.03 MHz with 7 kHz FM filter.
  3. Record IQ data and demodulate M-FSK at 1200 baud; unencrypted housekeeping frames appear as ASCII [SatNOGS, 2020].
