3W bicycle lamp [MAX16832] - power supply up to 60V
yogi009  12 10386 Cool? (+12)
  • A 3W bicycle lamp uses a Maxim MAX16832 constant-current driver for a Cree Power LED, aimed at city roads and bicycle paths.
  • The circuit runs from a 7–65V battery, with a 2A/100V Schottky diode, Coilcraft MSS1260-224KLB choke, R1=0R23, and R3=30k.
  • At 19.47V input, sleep current was 0.61mA, dim mode gave 65–75mA, and max mode reached 990→960mA at about 3V on the LED.
  • The module gets very warm, especially the choke, so the Cree LED needs a heatsink; the MAX16832 adds 165°C thermal protection.
Two-layer PCB for a bicycle light with electronic components.
This mini-project is related to the previous one:
https://www.elektroda.pl/rtvforum/topic3790044.html
This time I took a Maxim MAX16832 (V MAX = 65V) supplying the diode with a constant current up to 1000 mA. This chip is manufactured in a hobbyist-friendly SOIC-08 housing with an added thermal pad underneath, which allows it to better radiate heat to the surface of the heat sink. This chip, like the MAX16822, is nice to fit. Note: the photos and diagram show the twin 1W version, please read the description carefully.
Today I present another version of this lamp (intended for city asphalts and bicycle paths) adapted to be powered by a battery with a constant voltage in the range of 7-65 V. Additionally, it can "feed" more than one Power LED (3W), so far I tested the operation of one Cree LED. The scheme is the same, a few elements have been changed, the PCBs are identical. Changes compared to the MAX16822 version:
1.Schottky diode 2A / 100V,
2.higher current choke (pay attention to the frequency of the inverter) - Coilcraft MSS1260-224KLB,
3.resistor programming the current R1 = 0R23 (theoretically it should give 867mA current for the Cree diode),
4. resistor R3 = 30k - at 20k the Cree diode receives too little current and does not behave stably.
Electrical schematic of bicycle lamp with MAX16822 circuit. PCB schematic for a bicycle light using the MAX16822 circuit Schematic and PCB design for a two-layer circuit board for a bicycle light based on the MAX16822 chip. Two-layer PCB for a bicycle lamp with MAX16822 circuit.
As you can see, the whole thing looks the same (except for a slightly larger choke, which, however, fits easily in its soldering field. It is worth recalling the numerous vias in the area of the integrated circuit, they were not put on display, they should be physically made, thanks to which we increase the cooling surface of the MAX16832 several times. .
Now measurements for one Cree 3W diode. Supply voltage 19.47V.
In the sleep mode (red jumper on), the voltage on the diode is 0V, current is 0mA, and the current consumed by the module is 0.61mA.
In the darker mode (green jumper on, minimal light - no worries, there is enough of it on the bicycle path), the voltage at Cree = 2.65V, the diode current is 75-> 65mA, the current consumed by the module is 13mA.
In bright mode (max), the voltage across the Cree is 3V, the current is 990-> 960mA, and the current consumed by the module is 263mA.
Marking 990-> 960mA means that at the beginning we have a current of 990mA, after a longer moment it drops to the level of 960mA.
Of course, in this version you should take care of the heat sink for the Cree diode, the module itself is very warm (especially the choke), but the integrated circuit has thermal protection (at 165 ° C), which gives hope that such a system will be sufficiently durable. I tested the module for several hours at home, it should be better cooled while driving.
Ultimately, I plan to install two series-connected Cree 3W LEDs with optics as in the description of the previous system, which will give better illumination of the road and shoulders and protect people from the opposite direction from glare.
In both versions(1W and 3W), in place of the potentiometer, you can solder a jumper (from R3 directly to the ground that we have on the Bottom side), the potentiometers are only used to adjust the desired brightness level of the dark mode, then you just need to solder the appropriate resistor R3.
If I had to use several Cree LEDs in series, more power would be released at this current. The choke heats up the most on the PCB. In this case, you can consider soldering copper radiation plates, but be careful that they do not come into contact with other "signals", they are not mass fields.
Summarizing these two projects, I plan to use the 3W module to build the front lamp. Simple logical switching on and switching the brightness gives good functionality of the lamp. The 1W module is very good for the tail light, it will normally work in darker mode, and when braking, it will turn on the bright mode as a brake light. A suitable contactor in the brake handle or the brake itself is sufficient.
yogi009 wrote 14697 posts with rating 2658 , helped 850 times. Been with us since 2006 year.
Slawek K. 02 Apr 2021 18:48
@ yogi009 It's nice that you act ;) Do you have a ready version with a housing? Greetings [Read more]
yogi009 02 Apr 2021 19:10
Hi Sławek. Only these two PCB modules were fired. Housing - you know - the most difficult part for electronics. The more so because two features must be combined here: adequate cooling and sealing. You... [Read more]
nouki 03 Apr 2021 01:30
Hello I personally use the PAM2863 chip. The voltage is lower, it is compensated by the current up to 2A and the simple construction of the system. PS I am wondering about the R2 resistor on the Dim... [Read more]
yogi009 03 Apr 2021 09:36
Is it good, I don't know. Certainly recommended by Maxim :-) In my two projects, the assumption was the flexibility of the supply voltage, so that the system works on both Li-Ion batteries and electric... [Read more]
Anonymous 03 Apr 2021 12:14
Hello Does powering the LED diode directly through the L1 choke (no capacitive filtration) shorten the life of this diode? Ps. By what method did a colleague make the PCB? Was it a plotter? [Read more]
yogi009 03 Apr 2021 13:52
No, it doesn't. Many converters have exactly this way of powering the Power LED. This is a classic thermal transfer, and it is moderately successful. I tinned the whole thing so that I would not... [Read more]
nouki 03 Apr 2021 14:21
I do not see such a solution in the documentation, even in the example PCB. Additionally, the condition in the description indicates low voltage. It would be enough to give a diode to be sure. Going... [Read more]
yogi009 03 Apr 2021 15:28
What did your colleague want to see? Anyone who wants to thoroughly analyze this particular chip should read the second catalog note regarding the finished module dedicated to this scalak. This is called... [Read more]
nouki 03 Apr 2021 16:09
As for the processor, with the current it consumes, there is a lot to choose from dc / dc converters or other cheaper solutions. It's easier to seal one key than a potentiometer. As for the led,... [Read more]
yogi009 03 Apr 2021 16:41
Dude, if you read the topic from the beginning with understanding, you would know that the potentiometer is used here on the implementation module to set the brightness of the dark mode that interests... [Read more]
Anonymous 04 Apr 2021 02:10
Generally, these are converters of lower power. More than once, I have encountered a case in which the failure of the filtering capacitor translated into the failure of the LED itself over time. Time... [Read more]
yogi009 07 Apr 2021 12:04
Exactly. This application is not accidental. [Read more]
TL;DR: DIY bike lamp using MAX16832 survives 65 V input and pushes bright-mode current to 990 mA; "recommended by Maxim" layout keeps DIM pin safe [Elektroda, yogi009, post #19356320] Ideal for 7–60 V packs and drops standby draw to 0.61 mA.
Why it matters: Riders can power one or more 3 W LEDs from almost any e-bike battery without bulky extra electronics.
• Input voltage: 7 – 65 V DC max [Elektroda, yogi009, post #19356320] • Output current: 65 mA (dim) or 960 – 990 mA (bright) [Elektroda, yogi009, post #19356320] • Stand-by consumption: 0.61 mA (sleep jumper) [Elektroda, yogi009, post #19356320] • Thermal shutdown: 165 °C junction [Maxim, MAX16832 Datasheet] • Luminous flux: ≈450 lm per Cree XP-G3 at 1 A; 2 LEDs ≈900 lm [Cree XP-G3 Datasheet]
What is the MAX16832 and why pick it for a bicycle lamp?
MAX16832 is a constant-current buck controller that handles up to 65 V input and 1 A LED drive, suiting 36 V and 48 V e-bike packs [Maxim, Datasheet][Elektroda, yogi009, post #19356320] Its SOIC-8 EP package simplifies hobby soldering and spreads heat through the exposed pad [Elektroda, yogi009, post #19356320]
How do I set the desired dim-mode brightness?
  1. Replace the temporary potentiometer with a fixed resistor R3.
  2. Power the board, short the green jumper, measure LED current.
  3. Adjust R3 value until current matches your target (e.g., 30 kΩ gives 65 mA) [Elektroda, yogi009, post #19356320]
Does driving the LED directly through the inductor hurt lifetime?
No. Many high-power buck drivers connect the LED at the inductor node without an output capacitor; reliability stays unchanged if current ripple is within LED limits [Elektroda, yogi009, post #19357683]
Why place a resistor (R2) on the DIM pin—can I omit it?
Maxim’s reference module inserts R2 to limit leakage and protect the DIM pin when tied to high voltages [Elektroda, yogi009, post #19357886] If your microcontroller never exceeds 70 V relative to ground, you may leave R2 out, but the extra 10 kΩ costs cents and adds insurance [Maxim, Datasheet].
How was the prototype PCB made?
The author used classic toner-transfer, then tinned the copper to slow oxidation during prototyping [Elektroda, yogi009, post #19357683] No plotter was involved.
Is there a finished housing available?
Not yet. A final enclosure must seal against dust, manage shocks, and attach a heatsink for two or three LEDs [Elektroda, yogi009, post #19356458]
What efficiency should I expect?
Maxim’s evaluation board posts 92 % typical efficiency at 48 V in and 1 A out [Maxim, App Note 4545]. Expect 88 – 93 % with quality Schottky and Coilcraft MSS1260 inductor [Elektroda, yogi009, post #19356320]
What edge-case failures must I consider?
  1. Over-voltage: a freshly charged 16 S pack can hit 67.2 V, exceeding the 65 V rating—add TVS or a buck stage [Elektroda, yogi009, post #19357145]
  2. Inductor saturation: if you exceed 1 A or raise PWM frequency, the MSS1260 may overheat and drop efficiency [Coilcraft Datasheet].
  3. Thermal runaway: blocking airflow around the heatsink can trip the 165 °C shutdown repeatedly, shortening component life [Maxim, Datasheet].
