1W bicycle lamp [MAX16822] - power supply up to 60V
yogi009 9783 10
  • A bicycle lamp built around the MAX16822 drives 1–3 Power LEDs from a hub dynamo or battery supply.
  • The circuit uses constant-current LED drive, a double-layer PCB with a spilled-bottom heat sink, and brightness control via PWM or a resistor on the thermal-control pin.
  • At 50V, one 1W LED produced 145 lm at 317.3 mA, while three LEDs in series reached 430 lm at 319.6 mA.
  • Higher supply voltages make MCU-powered PWM inconvenient, and 2–3 LEDs can heat the circuit enough to require good PCB dissipation.
  • Two-layer PCB for a bicycle light with electronic components.
    Some time ago I made a bicycle lamp powered by a bicycle hub dynamo. As such a dynamo in an unloaded state can generate definitely high voltages (up to 100V according to a German source), I was looking for a converter that can withstand high voltages. The choice fell on the chip from Maxim MAX16822 (V MAX = 65V) supplying the diode with a constant current up to 350 mA. This chip is manufactured in a hobbyist-friendly SOIC-08 housing without a thermal pad underneath, in a word, it is nice to install.
    Today I present a new version of this lamp (intended for city asphalts and bicycle paths) adapted to be powered by a battery with a constant voltage in the range of 7-65V. Additionally, it can power more than one Power LED (1W), I tested 1-3 such LEDs. Maybe the schematic and PCB first:
    View of the PCB with the control circuit for a dynamo-powered bike light. Electrical schematic of bicycle lamp with MAX16822 circuit. PCB schematic for a bicycle light using the MAX16822 circuit Schematic and PCB design for a two-layer circuit board for a bicycle light based on the MAX16822 chip. Two-layer PCB for a bicycle lamp with MAX16822 circuit. Two-layer PCB measuring 49.53 mm with visible traces, GND, VCC connections, and components.
    PCB is double-layer, the Bottom layer is a spilled mass that also acts as a heat sink. The emitted amount of heat is not frighteningly large, but with 2-3 LEDs it can heat up the circuit well without proper heat dissipation on the PCB. According to the manufacturer, at 165 ° C there is a sudden current limitation (thermal protection). I have never seen such a mode in practice.
    The system is interesting because in addition to determining the maximum current supplied to the diode (according to the note 0R6 it gives a diode current of 333 mA, in my example I used a 0R64 resistor which theoretically gave a diode current of 310 mA), you can control the brightness using the PWM input (standard in these applications). However, in the case of a higher supply voltage (eg 60V) it is difficult to find a small stabilizer to power the microcontroller (eg Attiny13) generating the PWM signal. And here it turned out that a trick can be used to analogously limit the diode current. It is enough to connect the temperature control input to ground through a resistor, which will reduce the diode current (external thermal protection). The diagram shows a 20 k? resistor and a 100 k? potentiometer, thanks to which we can adjust the brightness of the LED diode in a fairly wide range. During the tests, I came to the conclusion that this 20 k? resistor is enough, and the outputs for the 100 k? potentiometer / resistor can be shorted - we will then get the reduced diode brightness mode. Removal of the green jumper returns the LED to full brightness mode. On the other hand, giving the low state to the PWM input causes the LED to go out (let's call it the "Sleep" mode), then the current consumption is around 1 mA.
    What does it all mean? First of all, we have a simple circuit that can power 1, 2, 3 and maybe more Power LEDs (study the datasheet). Second, the logic switch is a simple jumper (or a small contact switch). Third, we can just as easily set two levels of brightness, e.g.. light for the bike path and light for slightly darker corners. We might as well imagine a red rear light with a brake light option - just install the microswitch in the brake levers or on the brakes themselves. There is no need to use an additional PWM system, although it can of course be done (and obtain e.g. orange hazard lights).
    Now for some quick measurements.
    1. 50V power supply, 1 LED 1W - 145 lm.
    AT LED = 2.78 V (U LED LOW = 2.57 V) - voltage across the LED
    AND LED = 317.3 mA (I. LED LOW = 17.12 mA) - LED currents
    AND INPUT = 26.58 mA (I INPUT LOW = 3.25 mA) - current drawn from the battery
    AND SLEEP = 0.81 mA (I SLEEP LOW = 1.03 mA) - current consumption in "Sleep" mode
    2. 50V power supply, 2 LEDs 1W in series - 290 lm.
    AT LED = 5.51 V (U LED LOW = 5.13V)
    AND LED = 318 mA (I LED LOW = 16.6 mA)
    AND INPUT = 45.2 mA (I INPUT LOW = 5 mA)
    3. 50V power supply, 3 LEDs 1W in series - 430 lm.
    AT LED = 8.27 V (U LED LOW = 7.70 V)
    AND LED = 319.6 mA (I. LED LOW = 15.54 mA)
    AND INPUT = 63.8 mA (I INPUT LOW = 6.64 mA)
    The "LOW" mode is simply a green jumper closed. The "SLEEP" mode is a closed red jumper (low state on PWM input). As you can see, the power consumption is perfectly acceptable. The system is suitable, among others for use on e-bikes up to 60V, I tested it successfully with 54V.
    Soon I will add measurements for lower supply voltages.
    It is worth using interesting Power LED diodes (eg Cree XP-G3 with a brightness of 164 lm / 350 mA) with directional optics so as not to dazzle cyclists and walkers approaching from the opposite direction (round optics 7 ° plus the second elliptical ? 7 °). The effect is really good. Nevertheless, I am already announcing a slightly more powerful, three-diode version of the lamp (current approx. 870 mA - over 1200 lm), I plan to build and test such a module in the near future.
    yogi009
    yogi009 wrote 14697 posts with rating 2658, helped 850 times. Been with us since 2006 year.
  • DC bike lighting with 20,000 µF filtering
    #2 19335494
    Maciek_C
    Help: 14
    Rate: 266
    A very nice thing, unfortunately there are not many good, "non-blinking" lamps at an affordable price on the market, using such a dynamo, so your lamp is an interesting project all the more.
    Do you already have a housing for this?
    I also used to do a lot of good lighting based on the hub dynamo (original Axa companies pulsed terribly) and finally went the easy way - I made a DC installation on the bike, rectifying the output voltage of the generator and filtering with 20,000uF / 35V capacitors.
    I hid the capacitors and the bridge in the steerer tube.
    As a front lamp, I have successfully used such a cheap invention (with an integrated converter) - a 12V 9W work lamp for the price of PLN 30:
    I know, maybe it's a light guerrilla fighter, but it has already traveled about 10,000 km and it serves well.
    After some time, following the blow, I added a motorcycle phone holder to the bike, which allows you to charge the phone from a dynamo (for a trifle PLN 60):
    In addition, the rear light is made on the MC34063 and the whole thing works great.
  • 1W converter suits city paths and tail lights
    #3 19335546
    yogi009
    Help: 850
    Rate: 2658
    First, I will test a two or three times more powerful converter, then I will make a housing. With currents of 330-700 mA (750 mA this will be the next prototype), it is difficult to expect a great effect when driving at night on forest paths. However, in the city and on asphalt, for example, 3 such LEDs in the front should do the job (3 x 3W) - the cited Cree LEDs then give about 980 lumens. It is still not the Chinese 80,000 lumens, because it is also not a converter for higher currents. One Cree XP-G3 diode will take up to 2A of current, which gives an estimated 930 lumens, with three such LEDs we have about 2800 lumens of brightness. Additionally, this series in the "White" light version has a CRI of 90%.
    And this 1-watt converter is very suitable for city paths and asphalts - it is impossible not to see it. You can also make a very bright tail light. For sure the safety level will increase many times, the brightness of such a red LED with a power of 1W is equal to the brightness of mopeds, it is enough to choose the right optics with a slightly wider scattering.
    I know that you can buy everything from a Chinese and usually cheap. But I don't know if it is good. Besides, I prefer (and like) to do something for myself.
  • Dynamo power unlikely to suit night forest riding
    #4 19335573
    conisl
    I don't think it is possible to make a dynamo-powered lamp that would be fine in a night forest. I have seen strong bicycle lamps once, but they are powered by a battery attached to the frame. However, even with them, I wouldn't risk driving outside the city, you can hurt yourself.
    Regards
  • #5 19335579
    yogi009
    Help: 850
    Rate: 2658
    Buddy, read it with understanding. This is not a dynamo powered lamp. I described that one a long time ago, enter "MAX16822" in the forum search engine, you will find the old article.
  • #6 19335602
    conisl
    Do not be angry, but the content of your article does not show how you power the improved version of the lamp.
  • #7 19335640
    Millaka
    Help: 59
    Rate: 228
    And wouldn't it be better to use the dynamo to charge the 18650 and then power the lamp from there?
    Then, for sure, nothing would blink and you could shine even when stationary.
  • Dynamo current too low for 18650 charging
    #8 19335693
    @GUTEK@
    Help: 163
    Rate: 425
    Dynamo has too little current to charge 18650, at least that's my opinion.
    As for the dynamo lamp, you can buy the XC-997C for less than PLN 30 - there are several versions of these lamps, the C version is powered by a dynamo. It is not a miracle, but it has a 1F capacitor inside (if I remember correctly). Thanks to that, it does not blink and it still shines a moment after stopping.
    There is even a video of how it shines - https://www.youtube.com/watch?v=bgCicw9sBFo
  • Battery-powered design suits 24–48V e-bike packs
    #9 19335724
    yogi009
    Help: 850
    Rate: 2658
    Ok, I underlined this in the original article in bold. To all, this is the battery powered version . I am writing about it, among others indicating that it is suitable for most electric bikes that have 24, 36 or 48V batteries.
    I don't know where you're getting that blinking. You will not notice this effect in this construction.
    @GUTEK@ wrote:
    And as for the dynamo lamp, you can buy the XC-997C for less than PLN 30
    This is DIY, which is the section in which we present own designs . Auction portals and their offer are not an authority here.
  • Simple rectifier-and-capacitor lamp from a dynamo
    #10 19360661
    Łukaszoo
    Help: 17
    Rate: 25
    I don't know about a hub dynamo, but a "regular" dynamo in a way behaves like a current source with an efficiency of around 500mA and a maximum voltage depending on how fast we are going.
    Based on this information, I assembled a lamp that had two 3W power LEDs (in series), and from the electronics only a rectifier bridge and a capacitor. It worked great, never failed, the dynamo never gave out a current that was dangerous for those LEDs. At the same time, the LEDs were lit when driving the bike (which is why I was tempted to 2 pcs in series, despite the higher voltage required). Therefore, it seems a bit overcomplicated to me.
    If it was a li-ion battery charger that uses dynamo energy - then it would make the most sense.
  • #11 19365071
    yogi009
    Help: 850
    Rate: 2658
    And this LED is not blinking at low speed? A dedicated inverter, however, has several advantages, it monitors the programmed current, thanks to which it maintains the brightness level at a constant level. Anyway, this is a topic about power ... from batteries or accumulators :-) I wrote this in bold in the first post :-)
A user has developed a bicycle lamp powered by a battery with a constant voltage range of 7-65V, utilizing the MAX16822 chip from Maxim, which can handle up to 65V and supply a constant current of 350 mA. The lamp is designed for urban use and can power multiple 1W Power LEDs, with tests showing it can effectively illuminate city paths. Discussions include the challenges of using hub dynamos, the potential for using a battery to avoid flickering, and the advantages of dedicated inverters for maintaining brightness. Some users share their experiences with alternative lighting solutions and express skepticism about the effectiveness of dynamo-powered lamps in low-speed scenarios.
TL;DR: MAX16822 driver survives 65 V input and delivers 430 lm from 3 × 1 W LEDs while drawing only 63.8 mA (“No blinking even at low speed” [Elektroda, yogi009, post #19365071]). Ideal for 24-48 V e-bike batteries.
Why it matters: It offers a compact, constant-current LED solution for anything from city bikes to e-scooters.
What is the MAX16822 and why use it for a bicycle lamp?
MAX16822 is a step-down LED driver rated to 65 V. It supplies a precise constant current, fits in SOIC-8, and needs no external FET. These traits simplify PCB layout and survive the 54 V batteries found on many e-bikes [Elektroda, yogi009, post #19335724]
What voltage range can the presented circuit accept?
The board runs from any battery between 7 V and 65 V DC, covering 24 V, 36 V and 48 V packs [Elektroda, yogi009, post #19334824]
How many LEDs can I drive, and how bright will it be?
Tested configurations: 1 LED gives 145 lm, 2 LEDs 290 lm, 3 LEDs 430 lm at 317-320 mA each [Elektroda, yogi009, post #19334824] Datasheet allows higher LED counts if forward voltage stays below input minus overhead.
How do I change brightness without a microcontroller?
Ground the thermal-sense pin through 20 kΩ to halve current. Short a jumper to return to full power. Pull PWM pin low to enter sleep mode [Elektroda, yogi009, post #19334824]
Will the lamp flicker when the bike slows down?
No. Constant-current regulation eliminates visible flicker; the author confirms "No blinking even at low speed" [Elektroda, yogi009, post #19365071]
Can I power it directly from a hub dynamo?
Not recommended. An unloaded hub dynamo can exceed 100 V peak, surpassing the 65 V limit and risking IC failure [Elektroda, yogi009, post #19334824]
What thermal precautions are needed?
A copper pour on the bottom layer spreads heat. If PCB temperature hits 165 °C, the IC throttles current to protect itself [Elektroda, yogi009, post #19334824] Keep board in airflow to avoid shutdown.
Could I use this board for a rear brake light?
Yes. Mount a red 1 W LED and wire a brake-lever microswitch to the jumper pads. The switch toggles between low and high brightness for instant brake indication [Elektroda, yogi009, post #19334824]
Is charging an 18650 from the dynamo a better idea?
A typical dynamo supplies ~500 mA but only at speed [Elektroda, Łukaszoo, post #19360661] It struggles to meet a Li-ion charger’s constant-current demand, so direct battery lighting remains simpler.
What failure scenarios should I watch for?
Over-voltage above 65 V, poor soldering on the sense resistor, or blocked airflow can trigger thermal shutdown or permanent IC damage [Elektroda, yogi009, post #19334824]
How do I assemble the board?
  1. Solder MAX16822 and 0R6 sense resistor.
  2. Add inductor, diode, and input/output capacitors.
  3. Place jumpers, then connect LEDs and supply. Follow polarity marks to avoid reverse-voltage damage [Elektroda, yogi009, post #19334824]
Which optics minimize glare for oncoming traffic?
Combine a 7° round lens with a 7°×40° elliptical optic on Cree XP-G3 LEDs to focus the beam and cut dazzle [Elektroda, yogi009, post #19334824]
