How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz?
Ganjor86 730846 1593
Can I turn a cheap DVB-T USB tuner into an SDR receiver, and how can I make it receive shortwave too?
Yes: with an RTL2832U-based DVB-T dongle you can use it as an SDR receiver after replacing the stock DVB-T drivers with the prepared Zadig/libusb drivers and running SDR software like SDR Sharp or HDSDR [#11182116] In normal mode these tuners work roughly from 24 MHz up to about 1700 MHz, so VHF/UHF services, airband, CB, ADS-B, etc. are fine [#13168529] [#12073526] For shortwave below that range, do not connect the antenna straight to the RTL chip; direct sampling is possible but is considered risky and can damage the RTL28xx [#12073526] The safer and better-performing solution in the thread is an upconverter on the antenna input, e.g. based on TA7358/LA1185/LA1186, which users report can extend reception down to roughly 100 kHz–40 MHz [#13135481]
  • #61 12111466
    zabex
    Help: 50
    Rate: 52
    This is the first time I hear this type of modulation and it seems to me that it is something local because, for example, in the vicinity of Poznań, you do not hear anything like that.
    Radar, alarm systems, monitoring ...?
  • Remote button incompatibility and HF converter questions
    #62 12140427
    zygmunt7
    The only disadvantage of this equipment is the remote control, because the glued button layout is this:
    And the actual keyboard layout of the remote is this:
    So the remote has to be programmed from scratch, but the button No. 8 will not work anyway.
    If someone uses the tuner only for SDR, no problem
    Such a converter "Precision HF Up Converter for RTL2832U E4000 R820T RTL SDR DVB-T tuner" is still a bit expensive, because $ 60 with shipping is not cheap ...
    How is it connected? Tuner for usb-b cable, then to the converter and then to the computer?
    What is the minimum frequency going to pick up with this set? 1.8MHz mentioned there or lower?
  • #63 12141817
    zabex
    Help: 50
    Rate: 52
    USB is only for powering this converter. It is connected via SMA connectors to the tuner. The 1.8MHz frequency is not its lowest operating threshold, but the 160m band that is received by the tuner at 101.8MHz (quartz in a 100MHz converter) and similarly for other bands, e.g. 80m - 3.5MHz, is converted to 103.5MHz.
    What's the bottom line? This is a question for the author of the project.
  • #64 12141995
    Ganjor86
    Help: 18
    Rate: 46
    I suspect that the lower limit depends on the lowest frequency at which the mixer operates.
  • #65 12142056
    zabex
    Help: 50
    Rate: 52
    Exactly, and it is not necessary to buy expensive converters right away. For example, I used the LA1186 chip from an old car radio + a few small elements. Zero cost but enough for starters.
  • #66 12142132
    zygmunt7
    It just so happens that I made a NOAA converter for an ordinary radio on LA1186, how to convert it now to receive below 24MHz?
  • #67 12142159
    zabex
    Help: 50
    Rate: 52
    Look for an upconverter on the chip, eg TA7358AP. Compare TA7358 to LA1186 applications. They are a bit different, but if you were doing a NOAA converter, you will definitely handle it. I will just add that the TA7358AP performs worse than the LA1186.
  • Questions about LA1186N replacement and HF antenna filtering
    #68 12142468
    zygmunt7
    Did you mean this layout?
    The author writes that LA1186N can be used instead of TA7358, but nothing says about any modifications, so what, I just put LA instead of TA and that's it?
    The second thing is the antenna, you (zabex) use Discone also for the range below 25MHz?
    Do you use a filter or just the FP6L 5-2400MHz amplifier, because I can see that you have a very clean signal, for example:
    • ta7358_-_hf-to-vhf-upconverter.pdf (200.72 KB) You must be logged in to download this attachment.
  • LA1186N substitution and antenna filter chain
    #69 12143239
    zabex
    Help: 50
    Rate: 52
    Yes that's the pattern. You can substitute LA1186N without any modifications. I have it a bit changed because I didn't like the original one (in the sense of his work). So far, I have only put the filter on the input of the system. Antenna - Filter - Gain - LA. The antenna is a makeshift Long Wire (about 20m of wire stretched behind the house). I use the Discone with the amplifier above the HF band.
  • 31 MHz LA1186 offset enables near-zero-frequency reception
    #70 12152874
    Ganjor86
    Help: 18
    Rate: 46
    I noticed that when using an upconverter on the LA1186 chip, the frequencies are raised by 31MHz, and with the R820T tuner, the lowest frequency on which it works is about 27MHz, so when you have a dongle with R820T and an upconverter on the LA1186, you can get frequencies up to 0hz, which in practice gives nothing but interesting I'm down to low frequencies such a duo is doing reasonably well. Maybe some online video?
  • #71 12152974
    mkpl
    Level 37  
    Help: 306
    Rate: 863
    I think that there is no point in going down lower than those 100kHz. Because it will be nonsense and abstraction ...
  • #72 12153015
    Ganjor86
    Help: 18
    Rate: 46
    A VLF i ELF
  • #73 12155662
    zygmunt7
    VLF - Low frequency reception
    I would try on 15.625kHz "The strength of this signal can provide information about the number of TV sets working in the vicinity (this is the frequency of deflection in the cathode ray tube)".
  • #74 12160233
    zabex
    Help: 50
    Rate: 52
    The last thing I hear in low frequencies is the PR1 at 226KHz.
  • #75 12160360
    Ganjor86
    Help: 18
    Rate: 46
    Or maybe try with a long wave magnetic antenna? 171KHz should be receiving, and if not, it's really between 225 and 171KHz
  • #76 12160637
    zabex
    Help: 50
    Rate: 52
    I had done a loop before, but I connected it again because I did not check the received frequencies so low and unfortunately no effect. It turns out that the lower limit is around 200KHz.
  • dump1090 modification adds aircraft distance calculation
    #77 12248089
    Tommy82
    Help: 455
    Rate: 1074
    lysy1980
    Great advice. Some time ago, when I was trying to do it, I got fixated on the e4000 and the R820T somehow I was pushed out of my head. But I already have the R820T and I am having fun with time
    I'm glad I use it myself sometimes.
    I listen to the air band on the wave field of the open dipole and I can listen to it much better than on the box antenna.
    Unfortunately NOAA linden. Neither in vertical nor horizontal polarization of the dipole.
    I tried to listen to the SP DX RTTY Contest today but on the frequencies available to me either nobody works or the antennas are quite up to ... ;)
    As for asd-b, I was playing with the dump1090 program
    I use an ubunciak
    I do not send to FL so it is one thing for me to decode. In fact, distance is the most effective for me at the moment because I am playing with the antennas.
    I saw a mod for rasbery pi on the web that counted the distance to the plane because I did not find this mod anywhere, I had to breed it myself
    If anyone is interested, you need to modify the interactiveShowData (void) function
    Code: text
    my modification is
    Code: text
    + display
    This is not done as it should, but it does provide basic functionality in interactiv mode by modifying only in one place easy for anyone to repeat.
    The program requires our coordinates to be compiled in, but adding it as a command line parameter would complicate the life of someone who would like to quickly implement this mod.
    The box antenna is bad
    Fortunately, I had a few of these antennas and changed one by adding counterweights at the bottom.
    So the base with the mustache counted on 1090 + the box antenna shortened a bit and we have a GP. But it's best to do this
    http://sp7pki.iq24.pl/default.asp?grupa=3534&temat=157203
    with counterweights.
    Interestingly, the maximum range greater in the direction I have exposed is in the case of the whip itself, but the added counterweights improve the characteristics because it improves the "visibility" of the planes from the covered side.
    I can already see that the weather has a big influence because yesterday evening the maximum distances were up to 230 km and today 170-180 km
    In fact, I could give the antennas one floor higher, i.e. to the roof, but on the one hand, I will probably lose what I will lose on a longer antenna cable. And knocks, which is a little bit more, so to switch the antenna to the roof, it would be a little out of my way.
    Such a chint fits a standard magnetic stand with a screw thread at the com / lpt / vga port. And so you can do interchangeable "whips"
  • #78 12249181
    lysy1980
    Help: 209
    Rate: 324
    To calculate the distance to a still plane and to add the range, for example, to the Planeplotter or Basestation program using the * .out file, the Sbsplotter program is used.
    • sbsplotter1.rar (217.62 KB) You must be logged in to download this attachment.
  • Seeking experiences with the Opendous HF upconverter
    #79 12269103
    FlyBoy
    Help: 107
    Rate: 168
    Hello gentlemen!
    I also started playing with SDR based on a DVB-T to USB adapter. In my case, I have an EZCAP R820T with RTL2832U. So far everything is flickering well, I'm using SDR Sharp. However, I have a question about "up converter", specifically about this project: http://code.google.com/p/opendous/wiki/Upconverter Has anyone made / bought it ready and could write if it is worth bothering about it?
  • #80 12270051
    Tommy82
    Help: 455
    Rate: 1074
    lysy1980
    Well, only I prefer ubuntu on a daily basis and a dump after modification meets my expectations. What's more, it is more flexible from my point of view, because if it came to my mind to throw the toto together with some machine on the roof, it will be toto under Linux control anyway.
  • Two-receiver ADS-B setup with TCP hub forwarding
    #81 12270622
    lysy1980
    Help: 209
    Rate: 324
    I use 2 receivers, one works on Debian Server without X on a disc with VIA EDEN C7 600Mhz (IGEL ThinClient), for decoding I use dump1090 (CPU load max 50% without aggressive option), the other works elsewhere under Windows XP Embedded, decoding using ADSB #, dene from both receivers to the TCP HUB and from here to VRS and FR24, the last ones work under Windows, among others because the mono platform needed to run VRS under Linux does not have to work.
  • #82 12596160
    DjExit
    Help: 10
    Rate: 81
    I am proud of my results. I ordered such a contraption straight from China :D (About PLN 30)
    This is some modified clone of the E4000 (Based on RTL2832U) and to be honest it works great. I listen to CB, uniformed services, FM radio, remote controls, etc. without any problems. It's well over 1Ghz. I recommend this dongle.
    Software is SDRSharp for elevator and GQRX for linux.
  • #83 12605935
    ginger78
    Help: 13
    Rate: 33
    @DjExit, what distribution did you install GQRX on? Have you had problems with the installation? On Mint Mate I can't deal with installing any software for this sdr, librtlsdr is still missing.
  • #84 12606005
    Tommy82
    Help: 455
    Rate: 1074
    librtlsdr is not part of the distribution
  • #85 12610501
    DjExit
    Help: 10
    Rate: 81
    Xubuntu in the latest version, after installing aptem, all if it already had on board.
  • #86 12615465
    zabex
    Help: 50
    Rate: 52
    RTL-SDR / HackRF Live DVD.
    Maybe someone tested this distribution for the R820T?
    PS Ubuntu.
  • #87 12615662
    Tommy82
    Help: 455
    Rate: 1074
    I have on the list of TODO ubuntu-12.04.2-custom-sdr-amd64.iso is probably just that, I even sucked only from the paw which I had intended for this purpose, I could not put together again today and probably I will not get it tomorrow either and will wait until next weekend.
  • #88 12615676
    zabex
    Help: 50
    Rate: 52
    It's a pity because I mean the paw. The weather is good and I am looking for a Live CD not to interfere with the borrowed equipment and to sit at night with RTL and LNB ;)
    I read something else but I will try this distribution as well. Thanks for the help.
  • #89 12615800
    Tommy82
    Help: 455
    Rate: 1074
    I do it a bit differently in the context of your problem, I just have a few disks and depending on the purpose of the hardware, I take the disk and put it in the environment I am interested in.
    But the clapper which I use for various stupid things has failed and is waiting for a transplant; P
  • #90 12615851
    zabex
    Help: 50
    Rate: 52
    I am not so crazy about unix systems, so as a youngster I am looking for something easier that will allow me to run RTL outdoors ;)
The discussion centers on using inexpensive DVB-T USB tuners, particularly those based on the RTL2832U chipset combined with various tuner modules like the R820T and E4000, as software-defined radio (SDR) receivers. These devices, originally intended for digital TV reception, can be repurposed for wideband SDR reception from approximately 25 MHz up to 1.7 GHz, covering amateur radio bands, FM broadcast, airband, ADS-B, and more. Modifications such as direct antenna connection to the RTL2832U chip pins enable reception of lower frequency bands (below 30 MHz), including shortwave, though precautions against electrostatic discharge and signal surges are necessary. Upconverter circuits based on chips like LA1186, LA1185, and TA7358AP are commonly used to extend reception down to HF and VLF bands by frequency shifting signals into the tuner's range. Various software solutions including SDR# (SDR Sharp), HDSDR, and dump1090 are recommended for Windows and Linux platforms, with driver installation often requiring tools like Zadig to replace default DVB-T drivers with RTL-SDR compatible ones. Users report challenges with driver installation, device recognition, and antenna selection, especially for frequencies outside the FM broadcast band. Amplifiers such as the FP6L and antennas like Discone or long wire are suggested to improve reception quality. Mobile and embedded platforms like Raspberry Pi and Android devices with USB OTG support are explored for portable SDR setups. The community shares detailed schematics, installation guides, and troubleshooting tips, emphasizing the cost-effectiveness and versatility of RTL-SDR dongles for radio experimentation and monitoring.
TL;DR: A US$13 RTL-SDR dongle with an R820T tuner covers 24-1762 MHz “Band 24-1762 MHz (no holes)” [Elektroda, zabex, post #12073526] and can be pushed to ≈100 kHz with a 50 MHz up-converter [Elektroda, sb8gapi, post #13074101]
Why it matters: One stick lets hobbyists scan HF, VHF, UHF and ADS-B without big radios.
• R820T native span: 24–1762 MHz [Elektroda, zabex, post #12073526] • Direct-Sampling mod: ≈0.1–28 MHz [Elektroda, methyl, post #13657048] • Typical dongle cost: US$13–15 incl. whip [Elektroda, Ganjor86, post #12076142] • PC spec: USB 2.0 + ≥1.2 GHz CPU [Elektroda, Serwis1, post #13206155] • TA7358 up-converter parts ≈ PLN 15 [Elektroda, sb8gapi, post #13074101]
What frequencies can an un-modified RTL-SDR with R820T cover?
About 24 MHz to 1.76 GHz without gaps [Elektroda, zabex, post #12073526] That spans airband, AIS, ACARS, ADS-B, VHF FM, UHF trunked, LTE and more.
How do I install drivers on Windows XP?
  1. Plug dongle, let Windows load Realtek driver.
  2. Run Zadig v2.1 XP, Menu → Options → List All Devices, choose "Bulk-In Interface 0".
  3. Click Install WINUSB driver. After 5 s SDR# sees “RTL-SDR/USB”. [Elektroda, lysy1980, post #13511327]
I get no DVB-T after installing SDR drivers—normal?
Yes. WINUSB replaces Realtek’s TV driver. Switch USB port or reinstall OEM driver when you need DVB-T reception [Elektroda, lysy1980, post #13511327]
What’s the simplest way to receive 0–30 MHz?
Add a 50 MHz HF up-converter using TA7358 or LA1185. It mixes HF to 50–80 MHz, cost under PLN 15 and sensitivity beats direct sampling [Elektroda, sb8gapi, #13074101; Elektroda, zabex, #12073526].
Can overheating freeze the dongle?
Yes. R820T can reach >60 °C and USB disconnects appear. Resoldering the USB plug and adding small heatsinks stopped lock-ups [Elektroda, mkpl, post #13635115]
Which antenna works best for wideband scans?
An outdoor TV log-periodic or discone on 50 Ω feed covers 50–1300 MHz. For HF add Mini-Whip or 20 m long-wire plus the up-converter [Elektroda, methyl, post #13657048]
Edge case: why does FM broadcast appear at 30 MHz?
Strong local FM images alias into 26–40 MHz when the front-end overloads. Use 88–108 MHz notch or reduce RF gain [Elektroda, mkpl, post #13583266]
Can I scan automatically like a hardware scanner?
Yes. Install the ‘Frequency Manager Scanner’ plug-in for SDR#; it hops user lists at 20 channels /s and logs activity [SDRSharpPlugins].
Is spectrum-analysis possible?
RTL-SDR plus ‘RTL-Power’ or ‘Spektrum’ sweeps 24 MHz–1.7 GHz, 2 MHz steps, ~30 dB dynamic range—handy for EMC checks [majek, 2013].
How do I add HF direct sampling without removing the tuner?
On R820T boards, wire a 1:10 transformer to RTL pins 4-5, select “Direct Sampling Q” in SDR#. This keeps VHF/UHF intact [Elektroda, BOOM i ZONK, post #13914702]
