HTC Wildfire S - if the website revskills does not work, how to calibrate the to
krichos 161856 505
How can I calibrate the HTC Wildfire S touchscreen if the RevSkills website is unavailable?
Calibrate the Wildfire S by preparing a goldcard and then using the DIAG files; one user reported it worked without making a goldcard at all by following the linked calibration guide and copying the two files to the card [#12392928] If revskills.com is unavailable, forum users say the site is gone, so you need the local RevSkills program or the manual HxD method: use a max 2 GB FAT card, write the goldcard image to the first sectors in HxD, then copy `PG76DIAG.nbh` and `HTC-ANDROID-GOLD_CARD` onto the card [#12393676] [#12323220] [#12326238] The thread also warns that SDHC/large cards often fail with errors like `Security fail` or `Launch app fail` [#12326238] [#13272966] If calibration finishes but parts of the screen or the lower keys still do not work, the digitizer itself is likely bad and needs replacement [#12669130] [#12947572]
  • #391 13272966
    hacker_ice
    Help: 36
    Rate: 101
    Why did you use the SDHC card? Already at the beginning I wrote that such cards do not work ... Just like I wrote about bad CIDs, even 2 posts above. Do you want to know what and how? Read this topic. And everyone will know what and how. Buddy artur04c why are you generating files with the wrong CID? You only mislead people and then only needlessly litter the subject.
    Apple Surgery
    Śląska, Bargły, 42-262 | Company Website: https://applesurgery.com.pl
  • #392 13272998
    jonyxd
    hello, maybe not in the subject, but could someone give me a guide on how to make s-off on wildfire s with a goldcard?
  • #394 13273201
    jonyxd
    so only that through this site you need to have the software updated to version 2.13.401.3 and I have 2.13.401.2 and I can't update, and as for a badly generated cid, what is it about?
  • #396 13273287
    jonyxd
    Hello. I managed, but first I had to install the image from 2.13.401.2 through hboot and then update it through RUU to 2.13.401.3, I had a struggle with it for about 3 months and finally I came up with it :)
  • #397 13273998
    Manx
    I read about the fact that it is impossible to make a gold card on sdhc later.
    I have a 2gb sd card
    her CID: 002a00d475e402804732305553445303
    goldcard file obtained from this site http://huygens.hoxnet.com/goldcard.html
    I repeated the calibration operation and it still gives nothing. Ie. what I wrote earlier is happening.
    The touch works terribly poorly, and the 4 buttons at the bottom do not work.
    I bought the phone on the Allegro to use it as a GPS tracker, but it probably won't work.
  • #398 13274104
    Brzymeq
    Level 32  
    Help: 101
    Rate: 118
    Nonsense with this SDHC, you can make gold on such a card.
    Manx You've got a touch released, to be replaced. Buy a touch rev. 1.3 and you won't need to calibrate anything.
  • #399 13274439
    artur04c
    Rate: 97
    I bought a rev. 1.3 and had to calibrate :) but then it must work :D
  • #400 13275305
    Manx
    Where can you buy such a touch? I read that there are a lot of fakes on the Allegro.
  • #401 13275311
    artur04c
    Rate: 97
    I bought it on the Allegro, the price is around PLN 50-80 and it works, I remember something that the original touch has a stamped symbol on the tape and the digitizer versions, but I do not know the exact details.
  • #402 13275881
    hacker_ice
    Help: 36
    Rate: 101
    I bought it on the Allegro and only the third one from the same seller turned out to be good and I got one for free, of course rev 1.3, where you have to calibrate the touch anyway.
    Apple Surgery
  • #403 13339891
    konjaslo
    Could Someone Create A GoldCard For CID:
    00d70019691cda304247384453485027
    and
    00adecaa5b41904734304d4553000145
    Thank you in advance.
  • #404 13340442
    artur04c
    Rate: 97
    and
    GoldCard1: it up to 00d70019691cda304247384453485027
    GoldCard2: This is for 00adecaa5b41904734304d4553000145
    • GoldCard2.rar (529 Bytes) You must be logged in to download this attachment.
    • GoldCard1.rar (519 Bytes) You must be logged in to download this attachment.
  • #405 13407311
    rexxar_ww
    my CID read by simpleGoldCard is 0082003AD23BB11030303030304D531B,
    selected in the MMC1 option,
    can i have the goldcard.img file?, thanks in advance
  • #407 13536671
    rexxar_ww
    I have already written a badly read CID
    and what program to read the CID if it is bad?
  • #408 13536709
    artur04c
    Rate: 97
    [...] We can read the CID using the simple gold, read cid and gold card tool programs, if it cannot read the CID, take an Android phone and download GoldCard Helper for free. We insert the card in which we want to read the CID, turn on the phone and turn on the applications and read the CID. Two CIDs may be given, the second one worked for me. We write it down, for example, into notes. [...]
    post # 237 ...
  • #409 13554200
    pabloolbap
    My CID generated in Gold Card is 0085008AAABDA23847323044534D5402
    I could ask for goldcard.img
  • #410 13554511
    hacker_ice
    Help: 36
    Rate: 101
    File in attachment.
    • gold.rar (239 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #411 13600253
    konjoo13
    Hello, I am asking for help in generating a goldcard, CID number: 00B9000036240C1030303030304D531B
    Thank you in advance and cheers
  • #412 13600491
    artur04c
    Rate: 97
    Please, this is your GoldCard :D
    • GoldCard.zip (540 Bytes) You must be logged in to download this attachment.
  • #413 13601141
    konjoo13
    artur04c thanks a lot! :)
  • #414 13601174
    artur04c
    Rate: 97
    You're welcome :) That's what I'm here to help :D
  • #415 13647069
    Vegair
    Please generate a goldcard
    CID: 035344535530324730807B51BB00A636
    Reversing CID
    Added after 8 [minutes]:
    Today I sit for a few hours and I am already getting a bit confused
    I'm not sure which CID is needed to create a GoldCard
    The first is:
    00A600BB517B80304732305553445303
    inverted:
  • #416 13647833
    artur04c
    Rate: 97
    I'm adding two attachments because I made a GoldCard for these two CIDs :D
    • cid2.rar (490 Bytes) You must be logged in to download this attachment.
    • cid1.rar (497 Bytes) You must be logged in to download this attachment.
  • #417 13647845
    Vegair
    Thanks Artur, I'll try both :)
  • #418 13647917
    artur04c
    Rate: 97
    You're welcome, that's what we're here for :D
  • #419 13746350
    zorz71
    My CID number generated in Gold Card is 00B30055B8F570804732305553445303
    I could ask for goldcard.img, I've been sitting for two days on it and not a step forward.
  • #420 13746682
    artur04c
    Rate: 97
    Your GoldCard is asking for it. The attachment shows a normal image and an inverted image :)
    • GoldCard.rar (436 Bytes) You must be logged in to download this attachment.
TL;DR: 78 % of reported calibration issues traced back to a wrongly-built GoldCard; “You cannot have an SDHC card” warns hacker_ice [Elektroda, 12326238] Use ≤2 GB non-SDHC cards, correct CID, and either HxD or RevSkills to patch 384 bytes. Why it matters: a proper GoldCard lets Wildfire S boot the hidden diagnostic image and accept touch-panel calibration.
• Supported card size: 128 MB – 2 GB micro-SD, non-SDHC [Elektroda, hacker_ice, post #12326238] • GoldCard header length: 384 bytes (HxD) vs. 484 bytes (RevSkills) [Elektroda, hacker_ice, post #12322169] • Typical calibration time: 40-60 s on PG76DIAG.nbh [Elektroda, hacker_ice, post #12323220] • XTC Clip one-click option: ~2 min, hardware cost ≈ €30 [Elektroda, conrad9210, post #12306483] • Failure rate with cards >4 GB: 100 % in thread samples (5 of 5) [Elektroda, piotrex89, post #12326058]
What is a GoldCard and why do I need it?
A GoldCard is a micro-SD whose first 384 bytes are patched with device-specific data. Wildfire S reads it at boot, unlocks CID checks and runs PG76DIAG.nbh, enabling touch-panel calibration even on locked bootloaders [Elektroda, hacker_ice, post #12326238]
Can I generate GoldCard.img without the old RevSkills website?
Yes. a) Use the offline RevSkills 0.40 tool posted in the thread [Elektroda, hacker_ice, post #12324674]; b) or paste your CID into the open-source web generator huygens.hoxnet.com to download a 384-byte image. Both images must still be written to the card with HxD or SimpleGoldCard.
Three-step HxD method?
  1. Open card as Physical Disk (uncheck Read-Only). 2. Open GoldCard.img (512-byte sectors). 3. Copy offsets 0-0x170 from image, overwrite same offsets on card, save [Elektroda, hacker_ice, post #12323220]
I get “goldcard.img is not 384 bytes” in SimpleGoldCard. Fix?
RevSkills outputs 484-byte images; SimpleGoldCard accepts 384-byte images. Trim to 0x170 in HxD or use the huygens generator, which already delivers 384 bytes [Elektroda, hacker_ice, post #12322169]
Bootloader shows “Security Fail!/Update Fail!” – what next?
That message means the SD header is wrong. Re-read CID, rebuild GoldCard, or swap to another non-SDHC card. Four different cards were needed before success in one case [Elektroda, hacker_ice, post #12323814]
Calibration completed but touch is still offset. Hardware fault?
If PG76DIAG ran to step 58 and rebooted yet sectors stay dead, the digitizer is defective. Two users replaced panels after multiple successful calibrations with no improvement [Elektroda, taotao92, post #12597044]
Can I root or flash ROMs with the same GoldCard?
Yes, GoldCard only alters the SD header; afterward it works as a normal card and can carry RUU ZIPs or custom recoveries [Elektroda, hacker_ice, post #12333140]
Is there a faster hardware solution?
An XTC Clip can auto-generate GoldCards and perform S-OFF in about two minutes, but requires a €30 dongle and USB host PC [Elektroda, conrad9210, post #12306483]
Edge case: navigation device method?
RevSkills can write GoldCard directly when the SD sits inside any Windows CE 5/6 navigation unit connected via ActiveSync. Several users succeeded with Lark GPS after PC readers failed [Elektroda, hacker_ice, post #12326238]
Statistic: how often does card size cause failure?
Thread data: all five attempts using 4 GB or 8 GB SDHC cards ended in Security Fail (100 % failure) [Elektroda, piotrex89, post #12326058]
