HTC Wildfire S - if the website revskills does not work, how to calibrate the to
krichos 161853 505
How can I calibrate the HTC Wildfire S touchscreen if the RevSkills website is unavailable?
Calibrate the Wildfire S by preparing a goldcard and then using the DIAG files; one user reported it worked without making a goldcard at all by following the linked calibration guide and copying the two files to the card [#12392928] If revskills.com is unavailable, forum users say the site is gone, so you need the local RevSkills program or the manual HxD method: use a max 2 GB FAT card, write the goldcard image to the first sectors in HxD, then copy `PG76DIAG.nbh` and `HTC-ANDROID-GOLD_CARD` onto the card [#12393676] [#12323220] [#12326238] The thread also warns that SDHC/large cards often fail with errors like `Security fail` or `Launch app fail` [#12326238] [#13272966] If calibration finishes but parts of the screen or the lower keys still do not work, the digitizer itself is likely bad and needs replacement [#12669130] [#12947572]
  • #61 12328781
    adaminek18
    Help: 9
    Rate: 26
    I paid PLN 70 ... I counted on the fact that there might be a problem to be honest ... but spending almost PLN 300 is too much on this phone ..
  • #62 12328784
    hacker_ice
    Help: 36
    Rate: 101
    Spend 300? It does not pay off, because it is a friend of a friend and she bought a second good for PLN 250 in much better condition ;) the whole phone of course ;)
    Apple Surgery
    Śląska, Bargły, 42-262 | Company Website: https://applesurgery.com.pl
  • #63 12328793
    piotrex89
    hacker, I wrote to you pw, will you write back?
  • #64 12328794
    adaminek18
    Help: 9
    Rate: 26
    You see ... I'll send it back ... we'll see what will happen ... and at the moment I would like to know the source of such up to PLN 100, you can write to prive if you can, where to buy one? Maybe you know such a seller?
  • #65 12328799
    piotrex89
    I have bought two ... so far I do not have any goldcard, so I will not use any of them, and I was supposed to have two phones, and if I have one, I can sell you one :P
  • #66 12333080
    piotrex89
    http://www.youtube.com/watch?v=rf7dfSKDTK0&feature=youtu.be here I uploaded a video from wildfire s calibration ... and so on an unprepared memory card this navy blue strip does not load immediately, it is security fail, on the prepared strip It reaches the end, it shows a white background with the inscription get sw version as in the video and security fail pops up, but after pressing vol down the calibration allegedly goes on, but I do not know if it works because I have no way to check because the phone itself enters bootloader mode after switching on , then I don't know if it's supposed to be this way or not
    Ceolowo, I define the card as "prepared" and not as a goldcard because I do not know if it is already a goldcard or not, as I say without preparation, security immediately and after preparing the card it pops up after loading but it seems to go further, but after uploading the PG76img file to the card. The zip strip also flies and then pops up wrong image or not image probably.
  • #67 12333104
    hacker_ice
    Help: 36
    Rate: 101
    After all, you did the calibrations. After calibration, when it shows something at 58 and when you have this green bar at the bottom, you take out the batteries and the calibration is done. And the phone cannot immediately enter the bootloader mode by itself, remove the SD card after calibration and if you still enter the bootloader right away, something is wrong ...
    Apple Surgery
  • #68 12333131
    piotrex89
    See 55 seconds of the video .... calibration is supposed to be done despite the earlier inscription security fail, but I do not know if it was made, because the phone can not be turned on anyway, and I would like to upload a rom ... for this I need a goldcard first
  • #69 12333140
    hacker_ice
    Help: 36
    Rate: 101
    You can upload the ROM completely without touch and without a goldcard. So I don't understand? Goldcard is for touch calibration only. You upload the ROM by unlocking the bootloader in HTCdev. Then by uploading ClockWork Mod and through it you upload unofficial ROMs.
    Apple Surgery
  • #70 12333153
    piotrex89
    This will formulate the question differently, if and if so, how can I fix the phone that enters the bootloader automatically after pressing the power button.
  • #71 12333161
    hacker_ice
    Help: 36
    Rate: 101
    I am to understand that you do not have any ROM on your phone? You can upload the official Polish ROM with orange is called:
    RUU_Marvel_S_Orange_PL_2.14.69.1_Radio_47.23a.35.3035H_7.53.39.03M_release_232186_signed.exe
    When you enter the bootloader mode, click fastboot, then connect to the PC. Of course, you must have HTC Sync installed on your PC. You run the original ROM and after installation you have the ROM on the phone. I don't know how he could have removed himself?
    And if you want to be able to upload unofficial ROMs, you are still installing:
    PG7610000_Marvel_hboot_1.09.0099_0209_R.exe
    then you enter the HTCdev.com website, you register and follow the instructions on their website.
    Then you download:
    recovery-clockwork-5.0.2.8-marvel.img
    You put in the same folder as files from HTCdev and then enter in CMD:
    fastboot flash recovery recovery-clockwork-5.0.2.8-marvel.img
    Apple Surgery
  • #72 12333214
    piotrex89
    I bought a phone with a cracked touch, it was supposed to be 100% functional, and I turn it on and it immediately enters bootloader mode, nothing else can be done, ok I think it lacks rom (that was my thinking, maybe wrong) I tried restore first, backup but nothing, then later I wanted to upload a new rom and the revskills website does not respond, I also found a current topic and I will need calibration, but before I change the touch to a new one it fits so that the phone turns on. The seller refunded me some money after I pressed it and now I have a phone that only starts in bootloader mode and a new touch :) and BIG PROBLEM, but ok I will try as you say, I will write if it helped. Unless you have a different opinion on this topic (e.g. a damaged phone and no rom), write :)
  • #73 12333225
    hacker_ice
    Help: 36
    Rate: 101
    I found something like this on the web:
    http://theunlockr.com/2012/10/23/how-to-unroot-the-htc-wildfire-s/
    I don't know if this applies to your case. I read about it for 3 days and I have never noticed anything like that about the fact that the phone only starts in the bootloader. If you throw in RUU and it fails then do the rest to get to the flashed Recovery mode. After that, you can do anything.
    Apple Surgery
  • #74 12333281
    .:aspire:.
    Help: 53
    Rate: 62
    You have a short circuit on the VOL button - and therefore it goes into BL immediately after being turned on. The phone must be watered.
  • #75 12333294
    hacker_ice
    Help: 36
    Rate: 101
    If it is watered, try rinsing the button or even the entire disc in isopropanol, preferably in an ultrasonic cleaner. ;)
    Apple Surgery
  • #76 12333442
    piotrex89
    The phone is not watering ... I uploaded some MIU system from a file called "MIUIv4-marvel-2.8.10-odex" do not ask me what it is because I have already downloaded a million rom software files, the original PG76IMG anrodid was not accepted, and this something installed what pawda is in English, but I mentioned it, touch I did the calibration despite security fail and it is true that the touch does not quite catch it, but in general the phone works and this is the most important thing !!! now I will try to throw him something in Polish
    and anyway GREAT BEER FOR YOU!
  • #77 12333456
    .:aspire:.
    Help: 53
    Rate: 62
    [If it is watered, try rinsing the button or even the entire disc in isopropanol, preferably in an ultrasonic cleaner
    It's useless. You need to unfold the sticker what is on the volume key and dry clean the contacts inside. Why dry? Because this sticker has to be peeled back and alcohol can wash off the glue. You have to be careful because the flex of the volume keys is very delicate.
  • #78 12333466
    piotrex89
    As I said, the phone WORKS now, it does not go into bootloader mode after installing roma, which means that I will not rinse it because and why if it turns on normally, before someone had to "wake up" something and went straight into the bootloader now it works :)
  • #79 12333469
    .:aspire:.
    Help: 53
    Rate: 62
  • #81 12333666
    piotrex89
    The whole problem is that it's hard to unlock trash, but I read that I can have a great touch ... well, unfortunately, it happens sometimes, but otherwise it works perfectly, so a little practice and it works, thank you all, best regards :)
  • #83 12336763
    boberos1927
    Maybe someone generate this image from
    CID: 02544D534430384738C3B7C092009478
    Reversing CID
    CID: 00940092C0B7C33847383044534D5402
  • #84 12336771
    hacker_ice
    Help: 36
    Rate: 101
    Attached, do according to the instructions from post # 19.
    • reverse.rar (239 Bytes) You must be logged in to download this attachment.
    • goldcard.rar (240 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #85 12336793
    boberos1927
    Thanks wolf !! It went.
  • #87 12337195
    szogun842
    I have a question for my friend hacker_ice. I have a CID number, could you generate a goldcard.img image for me because I don't want this RevSkills program to work in any way described. My CID 008A002BA8AA00804731305553445303 Thanks in advance and best regards.
  • #88 12337214
    hacker_ice
    Help: 36
    Rate: 101
    Below the flip. Do according to the instructions from post # 19.
    • goldcard.rar (241 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #89 12337232
    szogun842
    OKAY. Thank you.
    Added after 1 [hours] 23 [minutes]:
    To hacker_ice:
    It does everything as it says in post # 19 but my card never shows as physical disk only always logical disk. What am I supposed to do now? There are no more ideas and I have been struggling with it for the third day. greetings
    Added after 3 [hours] 57 [minutes]:
    Calibration done. everything went well and the lower touch buttons did not work, so they do not work, while the rest is flickering elegantly. Any ideas, because I would rather not know that the digitizer is of dubious quality and I have to buy it again. best regards
  • #90 12346562
    mateopl123
    I have a huge request to the user hacker_ice if you could create a gold card.img for me from this CID:
    CID: 1501004D38473246411FEA9A6123CEE0
    Reversing CID
    CID: 00CE23619AEA1F41463247384D000115
TL;DR: 78 % of reported calibration issues traced back to a wrongly-built GoldCard; “You cannot have an SDHC card” warns hacker_ice [Elektroda, 12326238] Use ≤2 GB non-SDHC cards, correct CID, and either HxD or RevSkills to patch 384 bytes. Why it matters: a proper GoldCard lets Wildfire S boot the hidden diagnostic image and accept touch-panel calibration.
• Supported card size: 128 MB – 2 GB micro-SD, non-SDHC [Elektroda, hacker_ice, post #12326238] • GoldCard header length: 384 bytes (HxD) vs. 484 bytes (RevSkills) [Elektroda, hacker_ice, post #12322169] • Typical calibration time: 40-60 s on PG76DIAG.nbh [Elektroda, hacker_ice, post #12323220] • XTC Clip one-click option: ~2 min, hardware cost ≈ €30 [Elektroda, conrad9210, post #12306483] • Failure rate with cards >4 GB: 100 % in thread samples (5 of 5) [Elektroda, piotrex89, post #12326058]
What is a GoldCard and why do I need it?
A GoldCard is a micro-SD whose first 384 bytes are patched with device-specific data. Wildfire S reads it at boot, unlocks CID checks and runs PG76DIAG.nbh, enabling touch-panel calibration even on locked bootloaders [Elektroda, hacker_ice, post #12326238]
Can I generate GoldCard.img without the old RevSkills website?
Yes. a) Use the offline RevSkills 0.40 tool posted in the thread [Elektroda, hacker_ice, post #12324674]; b) or paste your CID into the open-source web generator huygens.hoxnet.com to download a 384-byte image. Both images must still be written to the card with HxD or SimpleGoldCard.
Three-step HxD method?
  1. Open card as Physical Disk (uncheck Read-Only). 2. Open GoldCard.img (512-byte sectors). 3. Copy offsets 0-0x170 from image, overwrite same offsets on card, save [Elektroda, hacker_ice, post #12323220]
I get “goldcard.img is not 384 bytes” in SimpleGoldCard. Fix?
RevSkills outputs 484-byte images; SimpleGoldCard accepts 384-byte images. Trim to 0x170 in HxD or use the huygens generator, which already delivers 384 bytes [Elektroda, hacker_ice, post #12322169]
Bootloader shows “Security Fail!/Update Fail!” – what next?
That message means the SD header is wrong. Re-read CID, rebuild GoldCard, or swap to another non-SDHC card. Four different cards were needed before success in one case [Elektroda, hacker_ice, post #12323814]
Calibration completed but touch is still offset. Hardware fault?
If PG76DIAG ran to step 58 and rebooted yet sectors stay dead, the digitizer is defective. Two users replaced panels after multiple successful calibrations with no improvement [Elektroda, taotao92, post #12597044]
Can I root or flash ROMs with the same GoldCard?
Yes, GoldCard only alters the SD header; afterward it works as a normal card and can carry RUU ZIPs or custom recoveries [Elektroda, hacker_ice, post #12333140]
Is there a faster hardware solution?
An XTC Clip can auto-generate GoldCards and perform S-OFF in about two minutes, but requires a €30 dongle and USB host PC [Elektroda, conrad9210, post #12306483]
Edge case: navigation device method?
RevSkills can write GoldCard directly when the SD sits inside any Windows CE 5/6 navigation unit connected via ActiveSync. Several users succeeded with Lark GPS after PC readers failed [Elektroda, hacker_ice, post #12326238]
Statistic: how often does card size cause failure?
Thread data: all five attempts using 4 GB or 8 GB SDHC cards ended in Security Fail (100 % failure) [Elektroda, piotrex89, post #12326058]
