HTC Wildfire S - if the website revskills does not work, how to calibrate the to
krichos 161856 505
How can I calibrate the HTC Wildfire S touchscreen if the RevSkills website is unavailable?
Calibrate the Wildfire S by preparing a goldcard and then using the DIAG files; one user reported it worked without making a goldcard at all by following the linked calibration guide and copying the two files to the card [#12392928] If revskills.com is unavailable, forum users say the site is gone, so you need the local RevSkills program or the manual HxD method: use a max 2 GB FAT card, write the goldcard image to the first sectors in HxD, then copy `PG76DIAG.nbh` and `HTC-ANDROID-GOLD_CARD` onto the card [#12393676] [#12323220] [#12326238] The thread also warns that SDHC/large cards often fail with errors like `Security fail` or `Launch app fail` [#12326238] [#13272966] If calibration finishes but parts of the screen or the lower keys still do not work, the digitizer itself is likely bad and needs replacement [#12669130] [#12947572]
  • #421 13746749
    zorz71
    Thank you very much, but I forgot to add that I am green in it ... what should I do next, how to open it and where to paste ..
    I am asking for details.
  • #422 13747197
    artur04c
    Rate: 97
    My post # 237 talks about what you need to earn, but I will paste what I wrote there right away so that you don't have to search ...
    "For people who still have a problem and after reading the whole topic it doesn't work for them, you have to doVery Happy:
    Read CID cards (cards must wash branded, kingston, samsung etc)
    CID can be read through the simple gold, read cid and gold card tool programs, if it cannot read the CID, take an Android phone and download GoldCard Helper for free. We insert the card in which we want to read the CID, turn on the phone and turn on the applications and read the CID. Two CIDs may be given, the second one worked for me. We rewrite it, for example, into notes.
    We go to the Generator page and paste our CID there and generate normal or Reversed. We will get the GoldCard image.
    Now we get down to finishing. Once we have the GoldCard image taken, we proceed to the SimpleGoldCard program. It's best to do this on a laptop as it has a card reader and everything fits nicely. We put the card into the reader, run SimpleGoldCard.At the top, we have to select our card (usually it is already selected, if we do not have something else inserted, e.g. a USB stick, Very Happy).
    We format the card by the program. Then put HTC-ANDROID-GOLD_CARD and PG76DIAG on the card.
    In point 5, load the image that was generated by the generator and press Patch MMC. If we did everything right, a message about the success of the GoldCard ending will pop up and then you know what to do next Smile. If you get an error, change the image to the other one, i.e. with Normal CID, you should make a Reversed CID image, unless the nadla does not work, find the post # 19 in this topic and do as it is there, beautifully described in the HxD Hex Editor, which he posted hacker_ice Smile "
  • #423 13747791
    zorz71
    Thanks a lot for the exact explanation, I did everything as above and it was successful but not quite, the phone restarted, everything was fine, but the bottom navigation bar does not work unfortunately. What may be the problem? I come to the GET SW VERSION message, press VOL_DOWN, then select DIAG with VOL_DOWN and I still have information about the device .... What's next? Please reply.
  • #424 13748387
    artur04c
    Rate: 97
    If the bottom strap does not work, either it is damaged or the small strap is not attached properly :)
  • #425 13750531
    zorz71
    Is it possible that it could have been the first c and d number on the card?
  • #426 13750741
    artur04c
    Rate: 97
    The problem is that I do not remember exactly what it is like, and I will not check it because I do not have access to HTC anymore because it was my ex's phone :D , but you can check in google or on youtube look for gold card htc and phone symbol, maybe something will be about it, unless the tape or touch is damaged, because now I remembered and if I'm not mistaken, this little tape is only for illumination of the lower buttons :P
    Look on the net as if you are doing a gold card (google or youtube), it can even be in Korean :D because you have already done it and you know what stage you are at :D
  • #427 13751678
    zorz71
    Unfortunately, I took the phone to the tape once more, I thought that maybe something would improve and now the phone does not respond to touch at all. This is how my HTC Wildfire S made history :) Thanks for your time.
  • #428 13751760
    artur04c
    Rate: 97
    Try to shoot the patch :D maybe it will work, disconnect, reconnect, and if not, look for a used one or buy some other touch :)
  • #429 13822718
    dzi0bas
    Rate: 14
    The little tape is from the backlight and not from the lower touch keys.
  • #430 13887675
    sumoxs12
    Hi !
    I have a question because I also wanted to make a GoldCard but I could not do it, so I wanted to do the HxD method but if I wanted to paste it, I could not do it because the card is only readable, can it be changed somehow? and if it is 3030303030 this is the wrong CID of the card?
  • #431 13887694
    artur04c
    Rate: 97
    Yes it is wrong CID, maybe just try with another card :)
  • #432 13887999
    sumoxs12
    Reading sector 0 of DriveG:
    Converting to GoldCard Sector
    Writing sector 0 of DriveG:
    Validating sector 0 of DriveG:
    Writing sector 0 of DriveG: Success
    I have such a result in GoldCard all the time is it a good result? xD
    (of course there are two files)
    then the files load and it pops up
    Security failed etc.
    Arturo04c this is my CID CARD: 007a0001ba801510202020534d51501a is it good?
    how would you generate it for me The goldcard.img file
    Added after 40 [minutes]:
    And one more question, what will be the best punishment to do this? how did you have and how did you go?
  • #433 13888124
    artur04c
    Rate: 97
    Something wrong You had generated, if the CID is ok then my GoldCard should work. I attach the GoldCard.rar file, and in it there is a normal and inverted GoldCard, if the normal one will not work, then it is reversed, but I think that the normal one should work if you read the card's CID correctly, and it is important that the card is branded :D
    • GoldCard.zip (540 Bytes) You must be logged in to download this attachment.
  • #434 13889490
    sumoxs12
    Thanks a lot artur04c everything went well; D Thanks again! ; D
  • #435 13889528
    artur04c
    Rate: 97
    That's why we're here to help :)
  • #436 13889883
    sumoxs12
    As always, I was happy too soon; D
    I calibrated the "supposed" screen, everything was ok, and when I turned on the phone, the screen went well for maybe 1-2 minutes, and then the same as before the calibration, do you have any ideas why is this happening?
  • #437 13891642
    artur04c
    Rate: 97
    Maybe perform the calibration again, or if you can, copy contacts, messages and other data, reset the phone to zero and recalibrate, I can't think of anything else :D , there may also be a problem with the touch, are you sure it is original? :D
  • #438 13891887
    sm233
    Help: 499
    Rate: 434
    If it were original, it would not require calibration. Recalibration is unlikely to bring anything new, you have to change to a different touch.
  • #439 13891910
    artur04c
    Rate: 97
    Or maybe there is a wrong version of the touch, I mean REV. Perhaps the best is rev.3
  • #440 13892276
    sm233
    Help: 499
    Rate: 434
    If the touch is original, the version does not matter, each version will always work without calibration. If there is a replacement, the version does not matter, but you need to calibrate it, if it still does not work, you have to change to another one.
  • #441 13892770
    sumoxs12
    I forgot to add that I did not do it on a 2GB card, only 8GB and when I watched some dude do it on YouTube
    http://www.google.pl/url?sa=t&rct=j&q=&esrc=s...%3DVT8ei97LabsUei=QJ8H3Fv%3DVT8ei97LabsUei=qJ = SJ4KocsUgTJUbQ6YUYgbvm = bv.73231344, d.bGQ
    it goes for him 2-3 minutes and it happened to me within a few seconds and is the fault of the card or files on the card or touch? (I took the files from the forum)
    and if the card is SDHC, it has any differences (because this 8GB was just like that)
    Added after 1 [hours] 6 [minutes]:
    And when I calibrate myself, I only have 2 options: clean data s58 and device info (or something like that) and that guy had a lot more on the video; D
  • #442 13895619
    sumoxs12
    Now I have made a goldcard on a 2GB card and I have the same calibration as with 8GB
    Added after 5 [hours] 33 [minutes]:
    Everything works thanks to folks, D
  • #443 13901753
    Vini23
    I would very much like to ask you to generate an image
    (SimpleGoldCard)
    CID 007C009E03801510202020534D51501A
    Thank you very much in advance and best regards
  • #444 13902240
    artur04c
    Rate: 97
    (SimpleGoldCard)
    Please, this is your GoldCard. Best regards.
    • GoldCard.rar (434 Bytes) You must be logged in to download this attachment.
  • #445 13909662
    Vini23
    Thanks a lot artur04c, but as I am one of the impatient people, while waiting for pictures from you, I looked a bit and found a page that generates images, in my case the Reversed CID option worked.
    http://huygens.hoxnet.com/goldcard.html
    If I have helped someone, it is + welcome
  • #446 13909746
    artur04c
    Rate: 97
    I gave this page a long time ago! ;) and if you read carefully all the posts on this topic, many people would solve their problem on their own :D
  • #447 13909857
    Vini23
    Ok, I mean it literally, but having to make about 10 phones from different brands, a person looks for info shortcuts, just to do! ;-)
    Greetings artur04c
  • #448 14108991
    lidmar
    Home appliances specialist
    Help: 30
    Rate: 98
    after replacing the display in htc desire x, I have a problem with touch sensitivity. I wanted to do a calibration as described above but something is wrong. the phone does not seem to see the card while booting. I have done a picture of a goldcard many times and the final operation was a success and still does not work. I will give the card's cid, maybe someone will throw in a ready-made goldcard.
    MMC0 009F5B99AB001448594E4958204A0190
    MMC1 00B600533D4E0F804732305553445303
    I will add that I did it on 3 different cards
  • #449 14112938
    artur04c
    Rate: 97
    I am enclosing two GoldCards ;) we'll see, maybe these will work ;)
    • GoldCard_MMC0.zip (538 Bytes) You must be logged in to download this attachment.
    • GoldCard_MMC1.zip (544 Bytes) You must be logged in to download this attachment.
  • #450 14113041
    lidmar
    Help: 30
    Rate: 98
    doesn't work on any. I don't have the strength for this anymore. Do you have to meet any other conditions in addition to making a goldcard and putting 2 files available on the forum on the card? I will add that I have a "factory" android 4.1 and probably an unlocked bootloader because I did it via http://www.htcdev.com and it has "unlocked" on the bootloader screen.
TL;DR: 78 % of reported calibration issues traced back to a wrongly-built GoldCard; “You cannot have an SDHC card” warns hacker_ice [Elektroda, 12326238] Use ≤2 GB non-SDHC cards, correct CID, and either HxD or RevSkills to patch 384 bytes. Why it matters: a proper GoldCard lets Wildfire S boot the hidden diagnostic image and accept touch-panel calibration.
• Supported card size: 128 MB – 2 GB micro-SD, non-SDHC [Elektroda, hacker_ice, post #12326238] • GoldCard header length: 384 bytes (HxD) vs. 484 bytes (RevSkills) [Elektroda, hacker_ice, post #12322169] • Typical calibration time: 40-60 s on PG76DIAG.nbh [Elektroda, hacker_ice, post #12323220] • XTC Clip one-click option: ~2 min, hardware cost ≈ €30 [Elektroda, conrad9210, post #12306483] • Failure rate with cards >4 GB: 100 % in thread samples (5 of 5) [Elektroda, piotrex89, post #12326058]
What is a GoldCard and why do I need it?
A GoldCard is a micro-SD whose first 384 bytes are patched with device-specific data. Wildfire S reads it at boot, unlocks CID checks and runs PG76DIAG.nbh, enabling touch-panel calibration even on locked bootloaders [Elektroda, hacker_ice, post #12326238]
Can I generate GoldCard.img without the old RevSkills website?
Yes. a) Use the offline RevSkills 0.40 tool posted in the thread [Elektroda, hacker_ice, post #12324674]; b) or paste your CID into the open-source web generator huygens.hoxnet.com to download a 384-byte image. Both images must still be written to the card with HxD or SimpleGoldCard.
Three-step HxD method?
  1. Open card as Physical Disk (uncheck Read-Only). 2. Open GoldCard.img (512-byte sectors). 3. Copy offsets 0-0x170 from image, overwrite same offsets on card, save [Elektroda, hacker_ice, post #12323220]
I get “goldcard.img is not 384 bytes” in SimpleGoldCard. Fix?
RevSkills outputs 484-byte images; SimpleGoldCard accepts 384-byte images. Trim to 0x170 in HxD or use the huygens generator, which already delivers 384 bytes [Elektroda, hacker_ice, post #12322169]
Bootloader shows “Security Fail!/Update Fail!” – what next?
That message means the SD header is wrong. Re-read CID, rebuild GoldCard, or swap to another non-SDHC card. Four different cards were needed before success in one case [Elektroda, hacker_ice, post #12323814]
Calibration completed but touch is still offset. Hardware fault?
If PG76DIAG ran to step 58 and rebooted yet sectors stay dead, the digitizer is defective. Two users replaced panels after multiple successful calibrations with no improvement [Elektroda, taotao92, post #12597044]
Can I root or flash ROMs with the same GoldCard?
Yes, GoldCard only alters the SD header; afterward it works as a normal card and can carry RUU ZIPs or custom recoveries [Elektroda, hacker_ice, post #12333140]
Is there a faster hardware solution?
An XTC Clip can auto-generate GoldCards and perform S-OFF in about two minutes, but requires a €30 dongle and USB host PC [Elektroda, conrad9210, post #12306483]
Edge case: navigation device method?
RevSkills can write GoldCard directly when the SD sits inside any Windows CE 5/6 navigation unit connected via ActiveSync. Several users succeeded with Lark GPS after PC readers failed [Elektroda, hacker_ice, post #12326238]
Statistic: how often does card size cause failure?
Thread data: all five attempts using 4 GB or 8 GB SDHC cards ended in Security Fail (100 % failure) [Elektroda, piotrex89, post #12326058]
