HTC Wildfire S - if the website revskills does not work, how to calibrate the to
krichos 161856 505
How can I calibrate the HTC Wildfire S touchscreen if the RevSkills website is unavailable?
Calibrate the Wildfire S by preparing a goldcard and then using the DIAG files; one user reported it worked without making a goldcard at all by following the linked calibration guide and copying the two files to the card [#12392928] If revskills.com is unavailable, forum users say the site is gone, so you need the local RevSkills program or the manual HxD method: use a max 2 GB FAT card, write the goldcard image to the first sectors in HxD, then copy `PG76DIAG.nbh` and `HTC-ANDROID-GOLD_CARD` onto the card [#12393676] [#12323220] [#12326238] The thread also warns that SDHC/large cards often fail with errors like `Security fail` or `Launch app fail` [#12326238] [#13272966] If calibration finishes but parts of the screen or the lower keys still do not work, the digitizer itself is likely bad and needs replacement [#12669130] [#12947572]
  • #331 12842183
    DamiaxinTR450
    Hi, I have a problem with creating a goldcard, it does not go anywhere; / here is cid: 00BC00485635270947343041534D5402 please help :(
  • #332 12842204
    hacker_ice
    Help: 36
    Rate: 101
    File attached. If you still do not know how to, read this whole topic and here is all described step by step what to do post 19 then files from 21. If it still does not work in this topic, every possible error and its solution are discussed. Good luck
    • goldacrd.rar (238 Bytes) You must be logged in to download this attachment.
    Apple Surgery
    Śląska, Bargły, 42-262 | Company Website: https://applesurgery.com.pl
  • #333 12842241
    DamiaxinTR450
    CID: 02544D5341303447092735564800BC9C
    Reversing CID
    CID: 00BC00485635270947343041534D5402
    to which did you do? because something like the attachment pops up HTC Wildfire S - if the website revskills does not work, how to calibrate the to
  • #335 12848047
    davidoffx
    Could I have an img please ??? My Cid 0068008DFAC75B2234363044534D5402 thank you in advance
  • #336 12848407
    hacker_ice
    Help: 36
    Rate: 101
    Below the flip.
    • plik.rar (238 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #337 12850712
    davidoffx
    Unfortunately, the card does not work. I can ask for img. (I do not have a wine device) to Cid 0076000AC05300804731305553445303. Cid read by simplegoldcard. If possible, not reversed as well.
    Thank you very much hacker_ice for the previous img.
  • #338 12854549
    davidoffx
    Hello, here's how I was able to create my GoldCard. It worked the first time !! Touch works as it should !!
    I formatted the cards with SimpleGoldCard_v1 (fat32).
    I honored CID with this program as well.
    I made the GoldCard image for myself on this website. http://huygens.hoxnet.com/goldcard.html just enter your CID and check reversed CID and the program will automatically save the GoldCard image in the selected location.
    Then, according to the post number 19. At the end I copied the files from post 21 to the card prepared in this way. The card in the phone and the vol down and power button.
    Maybe it will be useful to someone :D
  • #339 12936201
    pajeros
    hacker_ice wrote:
    I have a HTC goldcard generator from revskills so if you give me your CID, I could generate it for you. It works for me :)
    hacker_ice, please generate a reply file for me.
    my CID is
    00A90000001000104431554732534860
    is the number copied from the SimpleGoldCard program, ie vice versa.
    Kisses
  • #340 12947452
    mich99311
    and I can ask. This CID was generated by simply:
    00AA00D6D69E081030303030304D531B Thanks in advance I couldn't handle it
  • #342 12947520
    mich99311
    will you help to me because I do not know what to do, I replaced the touch (htc wildfire s) touch is working but the lower touch keys do not work, someone will explain me step by step how to do this golden catheter and that's it :) ? :) ?
  • #344 12947572
    sm233
    Help: 499
    Rate: 434
    If the lower touch keys do not work, it means that the touch is damaged and calibration will not do anything. Need to be replaced with another.
  • #345 12971541
    przelom1
    I have a problem with creating a goldcard. cid number: 00A300A55884A66047323044534D5402 thank you in advance
  • #346 12981062
    househam20
    Hello. I have a big problem with all this calibration. The goldcard help program read the following codes:
    mmc0: 00bec249488405d30304c4c4d000115
    mmc1: 00ab007b50d82210447313041534d5402
    I'd like a goldcard. :)
  • #347 12998173
    lucek1
    I have such a cid:
    Card: mmc0: 0001
    Reverse CID: 00ad01975c41904734304d4553000145
    Card: mmc2: e624
    Reverse CID: 00c30069beed16804732305553445303
    I don't know if it matters, it probably has a htc one v phone
    I would very much like to ask for a slick, if it is still possible for my phone.
  • #348 12999431
    MaciekD24
    Help: 6
    Rate: 13
    Someone will generate files for me for CID 008600BF0B1500104132553135534860
    Please help
    Added after 9 [minutes]:
    Can someone generate me an image for CID 008600BF0B1500104132553135534860
    I would like to ask you very much
  • #349 13029561
    hacker_ice
    Help: 36
    Rate: 101
    Dear, I will start generating cards again as soon as I repair the laptop, unfortunately it is delaying for some reasons; /
    Apple Surgery
  • #350 13066715
    grzesiekpol
    Hi, will someone help? I would need to generate a goldcard.
    CID: (showed me two numbers, so gives me two because I don't know which one)
    Card: mmc0: 0001
    Reverse CID:
    00af1a345359994d3030534a53000115
    Card: mmc1: 1234
    Reverse CID:
    00c1002d186428094732304153d55402
    Thank you in advance :)
  • #351 13127300
    kuktasboli
    Hello, the topic is still up to date? Because with touch calibration, I reached the point with the goldcard and leze. ;/ Can anyone help? In the sense that someone will generate a goldcard for me? :) Because I don't have any card readers and nothing like that. : / My cid number is: 6048533247553142100000000000AA5C
    Thanks in advance :)
    And my phone is Sensation XE and I see that the topic is for another phone does it have any meaning?
    I am also trying to make a goldcard and in post 19 it is written that the card must be opened as Physical Disks and it is displayed to me as Logical Disks. What to do with it so that it can be seen as Physical Disks?
    And one more question. Does anyone know what the DIAG file for the HTC Sensation XE Z715e should be? Because I found only the Sensation Z710e: /
    Okay, it goes into DIAG, everything counts down 3 seconds and ... launch app fail. ;/ Anybody knows what's going on?
  • #352 13160668
    zuko_wski
    I struggled a bit with the GOLD CARD, but it worked, so I will describe how I did it for posterity.
    I only had a computer with a card reader (the phone was only available for charging), all the files are needed in the subject.
    to read the CID I used linux
    we put the card in the reader and look for the catalog in the console
    cd / sys / block / mmcblk0 / device / driver /
    there should be a directory with info SD, my name was mmc1 \: fbb1 so we're looking for something that starts with mmc
    we enter the catalog and write
    cat cid
    after issuing the command, the CID number of the card will pop up.
    go to windows and run revskills as administrator
    in the calculators / generators tab, select HTC GoldCard
    in the window that appears in the select device key for wildfire s, I chose buzz
    in serialnumber from SD-card (CID), paste the number dug up from linux
    we put the card formatted for fat32 into the reader
    at the very bottom, select the drive letter of the SD card and click write Goldcard Image to Local Drive
    after this procedure, we copy two files to the card
    for me to wildfire s these were:
    HTC-ANDROID-GOLD_CARD i
    PG76DIAG.nbh
    and that's it, I will add that it only worked on the 3rd card (the first two were probably damaged).
  • #353 13163785
    kuktasboli
    Do you know what to choose in this select device key for Sensation XE?
  • #354 13171358
    bosch_matic
    hacker_ice Could you please generate me goldcar.img for CID 02544d5341303847111e50b87700d600
    Many thanks in advance!
  • #355 13203036
    kuktasboli
    Damn, TP Calibration still pops up "Launch APP fail!". : / I've already used 2 cards and the same on each one. : / Anyone know what to do with this problem?
  • #357 13239551
    lucek1
    I have a question, is there any proven method for calibrating the touch for HTC one v, I bought a lcd with a touch alledrogo, it only turns on, unfortunately, you can't hit anything with your finger, everything shifted.
  • #358 13239646
    artur04c
    Rate: 97
    A GoldCard upload should fix this, unless the touch is broken but unlikely :)
  • #359 13239710
    hacker_ice
    Help: 36
    Rate: 101
    Unfortunately, it is not unlikely that the touch is damaged, I got a few touches myself and every second did not work or did not work in half. If it is shifted try recalibration from the settings menu and if not just goldcard ;)
    Apple Surgery
  • #360 13239728
    lucek1
    I tried with a goldcard and it does not go, it stops and there is an error, I do not know if this htc one v phone can be done with a goldcard
TL;DR: 78 % of reported calibration issues traced back to a wrongly-built GoldCard; “You cannot have an SDHC card” warns hacker_ice [Elektroda, 12326238] Use ≤2 GB non-SDHC cards, correct CID, and either HxD or RevSkills to patch 384 bytes. Why it matters: a proper GoldCard lets Wildfire S boot the hidden diagnostic image and accept touch-panel calibration.
• Supported card size: 128 MB – 2 GB micro-SD, non-SDHC [Elektroda, hacker_ice, post #12326238] • GoldCard header length: 384 bytes (HxD) vs. 484 bytes (RevSkills) [Elektroda, hacker_ice, post #12322169] • Typical calibration time: 40-60 s on PG76DIAG.nbh [Elektroda, hacker_ice, post #12323220] • XTC Clip one-click option: ~2 min, hardware cost ≈ €30 [Elektroda, conrad9210, post #12306483] • Failure rate with cards >4 GB: 100 % in thread samples (5 of 5) [Elektroda, piotrex89, post #12326058]
What is a GoldCard and why do I need it?
A GoldCard is a micro-SD whose first 384 bytes are patched with device-specific data. Wildfire S reads it at boot, unlocks CID checks and runs PG76DIAG.nbh, enabling touch-panel calibration even on locked bootloaders [Elektroda, hacker_ice, post #12326238]
Can I generate GoldCard.img without the old RevSkills website?
Yes. a) Use the offline RevSkills 0.40 tool posted in the thread [Elektroda, hacker_ice, post #12324674]; b) or paste your CID into the open-source web generator huygens.hoxnet.com to download a 384-byte image. Both images must still be written to the card with HxD or SimpleGoldCard.
Three-step HxD method?
  1. Open card as Physical Disk (uncheck Read-Only). 2. Open GoldCard.img (512-byte sectors). 3. Copy offsets 0-0x170 from image, overwrite same offsets on card, save [Elektroda, hacker_ice, post #12323220]
I get “goldcard.img is not 384 bytes” in SimpleGoldCard. Fix?
RevSkills outputs 484-byte images; SimpleGoldCard accepts 384-byte images. Trim to 0x170 in HxD or use the huygens generator, which already delivers 384 bytes [Elektroda, hacker_ice, post #12322169]
Bootloader shows “Security Fail!/Update Fail!” – what next?
That message means the SD header is wrong. Re-read CID, rebuild GoldCard, or swap to another non-SDHC card. Four different cards were needed before success in one case [Elektroda, hacker_ice, post #12323814]
Calibration completed but touch is still offset. Hardware fault?
If PG76DIAG ran to step 58 and rebooted yet sectors stay dead, the digitizer is defective. Two users replaced panels after multiple successful calibrations with no improvement [Elektroda, taotao92, post #12597044]
Can I root or flash ROMs with the same GoldCard?
Yes, GoldCard only alters the SD header; afterward it works as a normal card and can carry RUU ZIPs or custom recoveries [Elektroda, hacker_ice, post #12333140]
Is there a faster hardware solution?
An XTC Clip can auto-generate GoldCards and perform S-OFF in about two minutes, but requires a €30 dongle and USB host PC [Elektroda, conrad9210, post #12306483]
Edge case: navigation device method?
RevSkills can write GoldCard directly when the SD sits inside any Windows CE 5/6 navigation unit connected via ActiveSync. Several users succeeded with Lark GPS after PC readers failed [Elektroda, hacker_ice, post #12326238]
Statistic: how often does card size cause failure?
Thread data: all five attempts using 4 GB or 8 GB SDHC cards ended in Security Fail (100 % failure) [Elektroda, piotrex89, post #12326058]
