Choosing a 160m2 smart home system: control, monitoring, management
wyros 14715 21
Which smart home system should I choose for a 160 m² house under construction, with lighting, gates, sockets, heating, intercom, alarm, mobile app, HTTP control, and easy expansion?
For a house at the construction stage, the thread recommends a wired system rather than wireless, and several users steer you away from Fibaro for this case [#15674804][#15670956] Nexwell is the most commonly recommended choice, especially for a new build, and you can find installers through the Nexwell map [#15670956][#15677910] Grenton is another strong option if you want a system you can configure without an installer, with smartphone apps and a good price; it uses serial communication over a twisted pair run point-to-point, ideally with at least 4 wires, and the hardware can be placed in boxes or a cabinet [#15789520][#15930674] Grenton also supports touch panels, Android control, and optional Z-Wave wireless modules for expansion [#15930674] Another wired alternative mentioned is Ampio on CAN bus [#15841715]
  • #1 15667983
    wyros
    Which system should I choose?
    House about 160m2
    I'm at the construction stage so I can do anything.
    Requirements:
    control of lights, gates, electrical sockets,monitoring furnace, underfloor heating circuits, door locks?, video intercom,alarm, maybe sprinklers
    Additional requirements:
    1 touch panel
    mobile applications
    management via HTTP would be appreciated
    I am looking for a compromise between price and quality.
    easy to expand
    Do you recommend wired or wireless systems?
    Thank you in advance for your help
  • #2 15668771
    markopololop
    Level 19  
    Help: 33
    Rate: 33
    Maybe wireless, e.g. Fibaro. In my opinion, wireless systems offer a lot for little money and are also very easy to expand.
  • #4 15674804
    kasprzyk
    Electrician specialist
    Help: 354
    Rate: 671
    Of installers and users, hardly anyone recommends Fibaro any more, but the marketing and momentum is very good.
    I also recommend Nexwell, with a new building only wired installation - wireless would be total stupidity.
  • #5 15677338
    wyros
    Thank you for your answers
    I have had Nexwell in my sights from the very beginning
    Can you recommend any reliable and sensible specialists from the Mazovia region (Piseczno, Warsaw area)
  • #7 15699708
    lukaszrzepinski
    what about the price? For example, Fibaro is quite reasonably priced, and in Norway there is a popular system from the Swedish company Telldus called Tellstick - it costs very little
  • #8 15732088
    PBK
    Home appliances specialist
    Help: 153
    Rate: 459
    there is also the Polish zamel
  • #9 15736128
    Popak
    Moderator on vacation ...
    Help: 97
    Rate: 270
    PBK wrote:
    there is still a Polish zamel
    How under zamel do you want to connect the touch panel and connect to ethernet? ;)
  • #10 15738654
    PBK
    Help: 153
    Rate: 459
    i am not a specialist in this field but I know that Zamel offers smart home systems
  • #11 15738670
    maziar1000
    Rate: 48
    There is also the Polish F&F. There is also a Polish F&F. They have a wide range of equipment, but I don't know what the prices are in relation to the competition, but you can always check, but only the installer has access to the prices unless you search for devices individually
    And you can always do it on the Polish SATEL you will have a 2 in 1 alarm and automation only it does not give all the possibilities but you could have both the touch panel and applications and control by wireless.
  • #12 15739314
    PBK
    Help: 153
    Rate: 459
    with FIBARO cameras and motion detectors with reed switches on doors and windows, does it make sense to additionally charge the Satel alarm?
  • #13 15789520
    Rybczyk
    I was recently faced with such a choice and decided in favour of Grenton www.grenton.pl. It is mainly because of the possibility of configuring the system without an installer, the possibility of creating various applications for smartphones and, last but not least, the price.
  • #14 15841715
    olejopalacz2
    Help: 32
    Rate: 159
    Preferably a wired CAN system , e.g. Ampio
  • #15 15870279
    palacz997
    Don't take any particular system because you will be left with nothing. Do the installation under PLCs.
    I suggest you read https://plcstore.pl/ and phone or skype. I have equipment from them and they helped me design the installation.
  • #16 15870821
    bajtpphu
    Rate: 22
    What is the cost per port on a PLC? I ask because I know of cheaper solutions with a 5 year warranty
  • #17 15872563
    pafciowaw
    Automation specialist
    Help: 480
    Rate: 365
    The PLC gives a 10-year warranty (data and time support...;) :)
    And seriously: what ports?; there are inputs and outputs in the PLC (dedicated and properly protected from damage)
  • #18 15872621
    bajtpphu
    Rate: 22
    When I wrote about the 3 year warranty I meant the finished system. When naming the ports on the controller I meant inputs and outputs. The proposed plc controller is just a controller, but it is far from realizing a smart building installation. By posting I had in mind a ready-made solution under the customer's expectations. Personally, I don't know of a cheaper proven ready-made solution
    Added after 50 [seconds]:
    Mistake 5 year guarantee
  • #19 15930674
    Lukasino
    Rate: 71
    House about 160m2
    I am in the construction stage so I can do anything.
    Requirements:
    1 touch panel
    mobile applications
    easy to expand
    I recently attended a Grenton training course, I was persuaded by a colleague because he would like to install a system and I am more "technical" than him :) . To date I have not installed any home automation systems on anyone else's homes, I have only tested various systems on my own. I can honestly say with my knowledge of computer science and electrical engineering that this system is very interesting compared to the ones I have played with. I like the serial communication (something like CAN in a car), if you are in the process of building it, just pull a twisted pair from point to point (they recommend in series), min 4 wires. The boxes are preferably 70. The hardware is mounted in the boxes or cabinet, you can also use Z-wave wireless solutions. Of course you can use touch panels, remote controls (coming soon), or switches. I was more interested in the part of the training with the configuration of the whole system it is just fabulous. They have a programme where you create different events. Everything is graphical, you don't have to operate in code (but you can). You can configure the whole system to your heart's content (you are only limited by your imagination), and we can fully manage the android app.
    Connecting the system from the technical side is not complicated, but the more advanced configuration in the program is already a higher school of travel, here mathematicians will certainly cope well with the program ).
  • #21 15951675
    Rybczyk
    Lukasino wrote:
    I recently attended a Grenton training course, I was persuaded by a colleague because he wanted to install a system and I am more 'technical' than him :) . Up to now I have not installed any home automation systems for strangers, I have only tested various systems for myself. I can honestly say with my knowledge of computer science and electrical engineering that this system is very interesting compared to the ones I have played with. I like the serial communication (something like CAN in a car), if you are in the process of building it, just pull a twisted pair from point to point (they recommend in series), min 4 wires. The boxes are preferably 70. The hardware is mounted in the boxes or cabinet, you can also use Z-wave wireless solutions. Of course you can use touch panels, remote controls (coming soon), or switches. I was more interested in the part of the training with the configuration of the whole system it is just fabulous. They have a programme where you create different events. Everything is graphical, you don't have to operate in code (but you can). You can configure the whole system to your heart's content (you are only limited by your imagination), and we can fully manage the android app.
    Connecting the system from the technical side is not complicated, but a more advanced configuration in the program is already a higher school of travel, here mathematicians will certainly cope well with the program ).
    I have had Grenton about 2 months and continue to be impressed. Recently, a video from TVP with their system appeared on yt, if someone is curious, they can watch it for themselves. For example, you can see what the interfaces might look like: https://youtu.be/jx5wnFAhRZc
  • #22 16072837
    kasprzyk
    Help: 354
    Rate: 671
    Rybczyk wrote:
    Lukasino wrote:
    I recently attended a Grenton training course, I was persuaded by a colleague because he wanted to install the system and I am more 'technical' than him :) . Up to now I have not installed any home automation systems for strangers, I have only tested various systems for myself. I can honestly say with my knowledge of computer science and electrical engineering that this system is very interesting compared to the ones I have played with. I like the serial communication (something like CAN in a car), if you are in the process of building it, just pull a twisted pair from point to point (they recommend in series), min 4 wires. The boxes are preferably 70. The hardware is mounted in the boxes or cabinet, you can also use Z-wave wireless solutions. Of course you can use touch panels, remote controls (coming soon), or switches. I was more interested in the part of the training with the configuration of the whole system it is just fabulous. They have a programme where you create different events. Everything is graphical, you don't have to operate in code (but you can). You can configure the whole system to your heart's content (you are only limited by your imagination), and we can fully manage the android app.
    I have had Grenton for about 2 months and continue to be impressed. Recently, a video from TVP with their system appeared on yt, if someone is curious, they can watch it for themselves. You can, for example, see what the interfaces might look like: https://youtu.be/jx5wnFAhRZc
    I watched the video, well, I'm impressed by this awake baby - I hope the system distinguishes that it only rolled from side to side ;) :)
    By the way, why do they show the electrical switchboard of a 50 square metre flat in the shell of a building (such is the standard with modern electrical installation without any automation) with the punchings of a completely different switchboard with IB modules ? A potential customer will be fooled by this, and what about electromagnetic compatibility, they have introduced a new standard for routing "high-current" cables with "low-current" cables? , what about the zones for routing the wires themselves, they are doing IB without having a clue about basic electrical principles ? :|
